    Colored faces
    15 Posts 7 Posters 1.1k Views 7 Watching
    • T
      tomasz
      Use also:
      face.back_material=
        The two sides of a face have to be treated independently
        face.material = a_material face.back_material = a_material ### or face.back_material = another_material
        As they do not have to be the same.
        Because you usually do not see the back-face inside 3d objects it's usual to leave it 'nil' == the default back-color...
        If a face is inside a group or component definition and it has no material*... then it displays using the group/instance.material ]if any] both *front and back.
        Note that this has not changed the face's material - only the way you see it.
        • pingpinkP
          pingpink
          Thank you very much for your guiding ! It works !
          For Face color
          #                                    Glass
          def gl_green
          model=Sketchup.active_model
          ss=model.selection
          materials=model.materials
          faces=[]
          ss.each{|e|faces << e if e.class==Sketchup;;Face}
          faces.each{|face| face.material=Sketchup;;Color.new(0,250,154)}
          faces.each{|face| face.back_material=Sketchup;;Color.new(0,250,154)}
          faces.each{|face| face.material.alpha = 0.5}
          faces.each{|face| face.back_material.alpha = 0.5}
          For Group color
          #                                    Aluminium
          def al_Light_Bronze
          ss=model.selection
          layers=model.layers
          #Now check what is in the selection... in this example we extract the groups
          groups=[]
          ss.each{|e|groups << e if e.class==Sketchup;;Group}
          #Now process the groups
          m = Sketchup.find_support_file "CW/Textures/Aluminium/AnodizedAluminium_Light-Bronze.jpg", "Plugins"
          groups.each{|group| group.material=material_add_texture("Light-Bronze", m, "*")}
          • Dan RathbunD
            Dan Rathbun
            Change:
            faces=[]
            To:
            faces = ss.grep(Sketchup;;Face)
            The grep method comes from the Enumerable library module, that is mixed into many collection classes.
            The grep method is faster than anyway you could write the same functionality in Ruby.
            Also you are repeating things in loops that only need be done ONCE.
            And using multiple loops when only ONE loop is needed.
            Change:
            To:
            matl = Sketchup;;Color.new(0,250,154)
            matl.alpha = 0.5
            faces.each{|face|
              face.back_material = face.material = matl
            Last.. please use a 2 SPACE indent for code examples here.. TAB characters do not work well with bbCode boxes.
            πŸ’­
            I'm not here much anymore.
            • icehuliI
              icehuli
              little benchmark: windows 8, sketchup 2013 maker, cpu 4900mq
              code:
              require 'benchmark'
              mod = Sketchup.active_model # Open model
              ent = mod.entities # All entities in model
              sel = mod.selection # Current selection
              arr = ent.to_a
              print "sel;",sel.to_a.size,"  ==  ent;",ent.to_a.size
              puts "",arr
              Benchmark.bm(20) do |x|
                x.report("ent.greb")         { 100000.times { faces =  ent.grep(Sketchup;;Edge) } }
                x.report("ent.select,is_a?") { 100000.times { faces =  ent.select{|e| e.is_a?  Sketchup;;Edge } } }
                x.report("ent.select,class") { 100000.times { faces =  ent.select{|e| e.class==Sketchup;;Edge } } }
                x.report("ent.each,is_a?")   { 100000.times { faces=[];ent.each{|e|faces << e if e.is_a?  Sketchup;;Edge} } }
                x.report("ent.each,class")   { 100000.times { faces=[];ent.each{|e|faces << e if e.class==Sketchup;;Edge} } }
                x.report("sel.greb")         { 100000.times { faces =  sel.grep(Sketchup;;Edge) } }
                x.report("sel.select,is_a?") { 100000.times { faces =  sel.select{|e| e.is_a?  Sketchup;;Edge } } }
                x.report("sel.select,class") { 100000.times { faces =  sel.select{|e| e.class==Sketchup;;Edge } } }
                x.report("sel.each,is_a?")   { 100000.times { faces=[];sel.each{|e|faces << e if e.is_a?  Sketchup;;Edge} } }
                x.report("sel.each,class")   { 100000.times { faces=[];sel.each{|e|faces << e if e.class==Sketchup;;Edge} } }
                x.report("arr.greb")         { 100000.times { faces =  arr.grep(Sketchup;;Edge) } }
                x.report("arr.select,is_a?") { 100000.times { faces =  arr.select{|e| e.is_a?  Sketchup;;Edge } } }
                x.report("arr.select,class") { 100000.times { faces =  arr.select{|e| e.class==Sketchup;;Edge } } }
                x.report("arr.each,is_a?")   { 100000.times { faces=[];arr.each{|e|faces << e if e.is_a?  Sketchup;;Edge} } }
                x.report("arr.each,class")   { 100000.times { faces=[];arr.each{|e|faces << e if e.class==Sketchup;;Edge} } }
              result:
                                        user     system      total        real
              ent.greb              0.672000   0.000000   0.672000 (  0.681000)
              ent.select,is_a?      1.329000   0.000000   1.329000 (  1.328000)
              ent.select,class      1.437000   0.000000   1.437000 (  1.445000)
              ent.each,is_a?        1.266000   0.000000   1.266000 (  1.264000)
              ent.each,class        1.390000   0.000000   1.390000 (  1.391000)
              sel.greb              0.657000   0.000000   0.657000 (  0.655000)
              sel.select,is_a?      1.343000   0.000000   1.343000 (  1.330000)
              sel.select,class      1.469000   0.000000   1.469000 (  1.452000)
              sel.each,is_a?        1.250000   0.000000   1.250000 (  1.260000)
              sel.each,class        1.375000   0.000000   1.375000 (  1.386000)
              arr.greb              0.391000   0.000000   0.391000 (  0.401000)
              arr.select,is_a?      0.735000   0.000000   0.735000 (  0.740000)
              arr.select,class      0.860000   0.000000   0.860000 (  0.873000)
              arr.each,is_a?        0.953000   0.000000   0.953000 (  0.960000)
              arr.each,class        1.078000   0.000000   1.078000 (  1.090000)
              data:
              sel;28  ==  ent;28
              #<Sketchup;;Edge;0x18cf0054>
              #<Sketchup;;Edge;0x18cf0018>
              #<Sketchup;;Edge;0x18cf0090>
              #<Sketchup;;Edge;0x18ceffdc>
              #<Sketchup;;Face;0x18cf00cc>
              #<Sketchup;;Group;0x18ce5e4c>
              #<Sketchup;;Edge;0x18eacf64>
              #<Sketchup;;Edge;0x18eacfdc>
              #<Sketchup;;Edge;0x18eacf28>
              #<Sketchup;;Edge;0x18eacfa0>
              #<Sketchup;;Face;0x18ead018>
              #<Sketchup;;Edge;0x18bd1254>
              #<Sketchup;;Edge;0x18bd11dc>
              #<Sketchup;;Edge;0x18bd1218>
              #<Sketchup;;Edge;0x18bd11a0>
              #<Sketchup;;Face;0x18bd1290>
              #<Sketchup;;Edge;0x18bd0bb0>
              #<Sketchup;;Edge;0x18bd0b74>
              #<Sketchup;;Edge;0x18bd0b38>
              #<Sketchup;;Edge;0x18bd0afc>
              #<Sketchup;;Face;0x18bd0bec>
              #<Sketchup;;Edge;0x18bcefb8>
              #<Sketchup;;Edge;0x18bcee8c>
              #<Sketchup;;Edge;0x18bcef7c>
              #<Sketchup;;Edge;0x18bceec8>
              #<Sketchup;;Edge;0x18bcef40>
              #<Sketchup;;Edge;0x18bcef04>
              #<Sketchup;;Face;0x18bceff4>
              • pingpinkP
                pingpink
                I changed a code from your suggestion , but faces change color without transparency.
                What happens ? πŸ˜’
                def gl_green
                    ss=model.selection
                    matl.alpha = 0.5
                    faces.each{|face|
                • jolranJ
                  jolran
                  try changing matl = Sketchup::Color.new(0,250,154) to (0,250,154, 100)
                  and
                  faces.each{|face|
                  edit: Updated code for backface as you wanted. And the 4rth argument is actually not needed in th Color object..
                  • tt_suT
                    tt_su
                    and
                    faces.each{|face|
                    Setting alpha for face material inside the loop is not efficient. It'd be better set outside the loop.
                    • pingpinkP
                      pingpink
                      Thank you so much !!! Love You All' πŸ˜›
                      I changed as your suggestion , Jolran
                      It can change colors of glass now. I appreciate it !
                      There are many colors that I have to revise.
                      I will also change others as your example.
                      def gl_green
                      	ss=model.selection
                          faces.each{|face|
                      Result
                            def gl_green
                                ss=model.selection
                                matl.alpha = 0.5
                                faces.each{|face|
                        No πŸ˜’ You are jumbling up 'material' and 'color'.
                        Make your material then give it a color, alpha etc - then give faces that material...
                        More like this...
                        matl = model.materials.add('gl_green')
                        matl.color = Sketchup;;Color.new(0,250,154)
                        matl.alpha =0 .5
                        faces.each{|face|
                          face.back_material = matl
                        • pingpinkP
                          pingpink
                          Hi , TIG
                          This is correct , right ? I test it and it gives a name of material !!
                          def gl_green
                          	ss=model.selection
                          	matl.alpha =0.5
                          	faces.each{|face|
                          • Dan RathbunD
                            Dan Rathbun
                            He's actually using one of the standard color set.
                              As Dan says you can create and set materials in several ways.
                              face.material='red'
                              works because ' red' is a standard 'color', and a material will be auto-created from that if it doesn't exist.
                              But
                              face.material='redex'
                              might fail because that isn't a standard color - that is unless it already exists in the model.materials, and it has that very name...
                              It's best to try and separate materials and colors in your thought process...
                              Make the new materials up front and then specify them by name after that...
                              ` mat=model.materials.add('redex')
                              mat.color='red'
                              mat.alpha=0.33
                              later
                              face.material=mat
                              or
                              face.material='redex'`
                              etc
                              • pingpinkP
                                pingpink
                                Thank You again Dan and TIG ! . I understand an idea now. πŸ˜„
