    Colored faces
    15 Posts 7 Posters 778 Views 7 Watching
    • pingpinkP Offline
      pingpink
      I was wondering why a code of color only change only normal face , not including back face when I select all faces.Is there any mistakes ?
      def gl_green
      model=Sketchup.active_model
      ss=model.selection
      materials=model.materials
      faces=[]
      ss.each{|e|faces << e if e.class==Sketchup;;Face}
      faces.each{|face| face.material=Sketchup;;Color.new(0,250,154)}
      faces.each{|face| face.material.alpha = 0.5}
        tomasz
        Use also:
        face.back_material=
          The two sides of a face have to be treated independently
          face.material = a_material face.back_material = a_material ### or face.back_material = another_material
          As they do not have to be the same.
          Because you usually do not see the back-face inside 3d objects it's usual to leave it 'nil' == the default back-color...
          If a face is inside a group or component definition and it has no material*... then it displays using the group/instance.material ]if any] both *front and back.
          Note that this has not changed the face's material - only the way you see it.
          • pingpinkP Offline
            pingpink
            Thank you very much for your guiding ! It works !
            For Face color
            #                                    Glass
            def gl_green
            ss=model.selection
            faces=[]
            faces.each{|face| face.back_material=Sketchup;;Color.new(0,250,154)}
            faces.each{|face| face.back_material.alpha = 0.5}
            For Group color
            #                                    Aluminium
            def al_Light_Bronze
            ss=model.selection
            layers=model.layers
            #Now check what is in the selection... in this example we extract the groups
            groups=[]
            ss.each{|e|groups << e if e.class==Sketchup;;Group}
            #Now process the groups
            m = Sketchup.find_support_file "CW/Textures/Aluminium/AnodizedAluminium_Light-Bronze.jpg", "Plugins"
            groups.each{|group| group.material=material_add_texture("Light-Bronze", m, "*")}
            • Dan RathbunD Offline
              Dan Rathbun
              Change:
              faces=[]
              To:
              faces = ss.grep(Sketchup;;Face)
              The grep method comes from the Enumerable library module, that is mixed into many collection classes.
              The grep method is faster than anyway you could write the same functionality in Ruby.
              Also you are repeating things in loops that only need be done ONCE.
              And using multiple loops when only ONE loop is needed.
              Change:
              To:
              matl = Sketchup;;Color.new(0,250,154)
              matl.alpha = 0.5
              faces.each{|face|
                face.back_material = face.material = matl
              Last.. please use a 2 SPACE indent for code examples here.. TAB characters do not work well with bbCode boxes.
              πŸ’­
              I'm not here much anymore.
              • icehuliI Offline
                icehuli
                little benchmark: windows 8, sketchup 2013 maker, cpu 4900mq
                code:
                require 'benchmark'
                mod = Sketchup.active_model # Open model
                ent = mod.entities # All entities in model
                sel = mod.selection # Current selection
                arr = ent.to_a
                print "sel;",sel.to_a.size,"  ==  ent;",ent.to_a.size
                puts "",arr
                Benchmark.bm(20) do |x|
                  x.report("ent.greb")         { 100000.times { faces =  ent.grep(Sketchup;;Edge) } }
                  x.report("ent.select,is_a?") { 100000.times { faces =  ent.select{|e| e.is_a?  Sketchup;;Edge } } }
                  x.report("ent.select,class") { 100000.times { faces =  ent.select{|e| e.class==Sketchup;;Edge } } }
                  x.report("ent.each,is_a?")   { 100000.times { faces=[];ent.each{|e|faces << e if e.is_a?  Sketchup;;Edge} } }
                  x.report("ent.each,class")   { 100000.times { faces=[];ent.each{|e|faces << e if e.class==Sketchup;;Edge} } }
                  x.report("sel.greb")         { 100000.times { faces =  sel.grep(Sketchup;;Edge) } }
                  x.report("sel.select,is_a?") { 100000.times { faces =  sel.select{|e| e.is_a?  Sketchup;;Edge } } }
                  x.report("sel.select,class") { 100000.times { faces =  sel.select{|e| e.class==Sketchup;;Edge } } }
                  x.report("sel.each,is_a?")   { 100000.times { faces=[];sel.each{|e|faces << e if e.is_a?  Sketchup;;Edge} } }
                  x.report("sel.each,class")   { 100000.times { faces=[];sel.each{|e|faces << e if e.class==Sketchup;;Edge} } }
                  x.report("arr.greb")         { 100000.times { faces =  arr.grep(Sketchup;;Edge) } }
                  x.report("arr.select,is_a?") { 100000.times { faces =  arr.select{|e| e.is_a?  Sketchup;;Edge } } }
                  x.report("arr.select,class") { 100000.times { faces =  arr.select{|e| e.class==Sketchup;;Edge } } }
                  x.report("arr.each,is_a?")   { 100000.times { faces=[];arr.each{|e|faces << e if e.is_a?  Sketchup;;Edge} } }
                  x.report("arr.each,class")   { 100000.times { faces=[];arr.each{|e|faces << e if e.class==Sketchup;;Edge} } }
                result:
                                          user     system      total        real
                ent.greb              0.672000   0.000000   0.672000 (  0.681000)
                ent.select,is_a?      1.329000   0.000000   1.329000 (  1.328000)
                ent.select,class      1.437000   0.000000   1.437000 (  1.445000)
                ent.each,is_a?        1.266000   0.000000   1.266000 (  1.264000)
                ent.each,class        1.390000   0.000000   1.390000 (  1.391000)
                sel.greb              0.657000   0.000000   0.657000 (  0.655000)
                sel.select,is_a?      1.343000   0.000000   1.343000 (  1.330000)
                sel.select,class      1.469000   0.000000   1.469000 (  1.452000)
                sel.each,is_a?        1.250000   0.000000   1.250000 (  1.260000)
                sel.each,class        1.375000   0.000000   1.375000 (  1.386000)
                arr.greb              0.391000   0.000000   0.391000 (  0.401000)
                arr.select,is_a?      0.735000   0.000000   0.735000 (  0.740000)
                arr.select,class      0.860000   0.000000   0.860000 (  0.873000)
                arr.each,is_a?        0.953000   0.000000   0.953000 (  0.960000)
                arr.each,class        1.078000   0.000000   1.078000 (  1.090000)
                data:
                sel;28  ==  ent;28
                #<Sketchup;;Edge;0x18cf0054>
                #<Sketchup;;Edge;0x18cf0018>
                #<Sketchup;;Edge;0x18cf0090>
                #<Sketchup;;Edge;0x18ceffdc>
                #<Sketchup;;Face;0x18cf00cc>
                #<Sketchup;;Group;0x18ce5e4c>
                #<Sketchup;;Edge;0x18eacf64>
                #<Sketchup;;Edge;0x18eacfdc>
                #<Sketchup;;Edge;0x18eacf28>
                #<Sketchup;;Edge;0x18eacfa0>
                #<Sketchup;;Face;0x18ead018>
                #<Sketchup;;Edge;0x18bd1254>
                #<Sketchup;;Edge;0x18bd11dc>
                #<Sketchup;;Edge;0x18bd1218>
                #<Sketchup;;Edge;0x18bd11a0>
                #<Sketchup;;Face;0x18bd1290>
                #<Sketchup;;Edge;0x18bd0bb0>
                #<Sketchup;;Edge;0x18bd0b74>
                #<Sketchup;;Edge;0x18bd0b38>
                #<Sketchup;;Edge;0x18bd0afc>
                #<Sketchup;;Face;0x18bd0bec>
                #<Sketchup;;Edge;0x18bcefb8>
                #<Sketchup;;Edge;0x18bcee8c>
                #<Sketchup;;Edge;0x18bcef7c>
                #<Sketchup;;Edge;0x18bceec8>
                #<Sketchup;;Edge;0x18bcef40>
                #<Sketchup;;Edge;0x18bcef04>
                #<Sketchup;;Face;0x18bceff4>
                • pingpinkP Offline
                  pingpink
                  I changed a code from your suggestion , but faces change color without transparency.
                  What happens ? πŸ˜’
                  def gl_green
                      ss=model.selection
                      matl.alpha = 0.5
                      faces.each{|face|
                  • jolranJ Offline
                    jolran
                    try changing matl = Sketchup::Color.new(0,250,154) to (0,250,154, 100)
                    and
                    faces.each{|face|
                    edit: Updated code for backface as you wanted. And the 4rth argument is actually not needed in th Color object..
                    • tt_suT Offline
                      tt_su
                      and
                      faces.each{|face|
                      Setting alpha for face material inside the loop is not efficient. It'd be better set outside the loop.
                      • pingpinkP Offline
                        pingpink
                        Thank you so much !!! Love You All' πŸ˜›
                        I changed as your suggestion , Jolran
                        It can change colors of glass now. I appreciate it !
                        There are many colors that I have to revise.
                        I will also change others as your example.
                        def gl_green
                        	ss=model.selection
                            faces.each{|face|
                        Result
                              def gl_green
                                  ss=model.selection
                                  matl.alpha = 0.5
                                  faces.each{|face|
                          No πŸ˜’ You are jumbling up 'material' and 'color'.
                          Make your material then give it a color, alpha etc - then give faces that material...
                          More like this...
                          matl = model.materials.add('gl_green')
                          matl.color = Sketchup;;Color.new(0,250,154)
                          matl.alpha =0 .5
                          faces.each{|face|
                            face.back_material = matl
                          • pingpinkP Offline
                            pingpink
                            Hi , TIG
                            This is correct , right ? I test it and it gives a name of material !!
                            def gl_green
                            	ss=model.selection
                            	matl.alpha =0.5
                            	faces.each{|face|
                              Dan Rathbun
                              He's actually using one of the standard color set.
                                As Dan says you can create and set materials in several ways.
                                face.material='red'
                                works because ' red' is a standard 'color', and a material will be auto-created from that if it doesn't exist.
                                But
                                face.material='redex'
                                might fail because that isn't a standard color - that is unless it already exists in the model.materials, and it has that very name...
                                It's best to try and separate materials and colors in your thought process...
                                Make the new materials up front and then specify them by name after that...
                                ` mat=model.materials.add('redex')
                                mat.color='red'
                                mat.alpha=0.33
                                later
                                face.material=mat
                                or
                                face.material='redex'`
                                etc
                                • pingpinkP Offline
                                  pingpink
                                  Thank You again Dan and TIG ! . I understand an idea now. πŸ˜„
