    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Transform a texture into another texture in an animation!
    9 Posts 6 Posters 472 Views 6 Watching
      decumano
      Transform a texture into another texture in an animation, is it possible?
      I use the keyframe animation plugin to create little animation. Usually, if I want to change a texture in another one I prepare 2 copies of the same object and make the second overlay the first... but now I'd like to make something different: the same object changing texture during the animation.. using just one object and not 2 copies.
      I hope I explained.
      I now, i could make 2 identical animation with different texture and than match them in post-processing... but I'd like to make it in 1 animation..
      What do you think?
        decumano
        No one for my question?
        I hope I was clear... I wish that a material is transformed into another with a fade.
        Help meee. Thanks
          Pherim
          I am quite certain that this is not possible in Sketchup. Probably someone would have said so by now, if it was.
            johnsenior1973
            I vaguely remember a preview post of a plugin that allowed animated gif's to be used in SU models, but I don't remember ever seeing it coming out. I figure they couldn't manage to get it to work. I think the example they used was of a fireplace.
              decumano
              pherim, maybe you're right.
              john thank you, i'll try to find that post, but honestly I think, as you said, that plugin doesn't work. If it worked now someone would have suggest it here.
              thanks
                ImageAnimator ?
                http://sketchucation.com/forums/viewtopic.php?p=293677#p293677
                this animates Images, but not Textures...
                  Lightup ?
                  • BoxB Offline
                    Animatex might be just what you need.
                    http://sketchucation.com/forums/viewtopic.php?p=472554#p472554
                      decumano
                      Well! Well! Well!
                      Thank you all! Now I have found the solution!
                      I'll try all your suggestions to find the perfect one for my animation.
                      I think the fade effect I need, is something I must prepare before and then use with those plugins.... yes!
                      Thank you so much!
