    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Moving lines with the arrow key?
    20 Posts 9 Posters 1.5k Views 9 Watching
    • KathrynGK Offline
      KathrynG
      Hmmm... shows how much I still have to learn. I will have to try that. Re what I am trying to accomplish - attached is my last render, from the beginning to the end, and which I was quite happy with. (Event design and production.) The main issues I have are centering objects on top of another, and I find that the snapping does not always work for me? Sometimes it is just to move a chair an umph closer to a table or move something along the blue axis just a hair,Screen Shot 2013-11-08 at 8.12.21 AM.png etc. It's not the big moves I have a problem with, but the tiny ones. Well... nudges. Remember even though I have had SketchUp for around four years, I am still very much a novice.
      "With SketchUp - Rome could have been built in a day!"
        A touch of paradise? ๐Ÿ˜„
        but apparently it is only for Windows and I use a Mac. Quel dommage.
        That is very curious! ๐Ÿ˜ฎ
        Because it's a simple Flash animation, so you must see it even on a mac if you have a Flash player inside your navigator! ๐Ÿค“
        • KathrynGK Offline
          KathrynG
          No I did not mean the video, I meant the actual plug-in Mover2 ๐Ÿ˜„
            ah damned again ๐Ÿ˜ฎ
            on a PC. I do not have a way of supporting Mac users at this time.
            Have you try it ?
            Normally a plugin must work on any plateform!
            If not
            Seems you must ask to Tig or other Ruby guru if they can make something for you!
            • wind-borneW Offline
              wind-borne
              JS Move will work with a Mac though not as described inside file, also works more consistent if you hold modifier/s down.
              After you enter distance
              Option left/right for x axis
              Control up/down for y axis
              Option up/down for z axis
              Holding down command also .1x
              Holding down shift also 10x
              404 Not Found
              (www.pixero.com)
              "To read between the lines was easier than to follow the text."OSX 10.11.6
              %(#BF80BF)[SU 8 pro
              • KathrynGK Offline
                KathrynG
                Screen Shot 2013-11-24 at 6.11.12 PM.pngSorry, maybe there has been a newer version than the one I Googled, but this is what I read, so did not bother to go any further? Just figured I was out of luck. The part about not supporting Mac users? [attachment=0]
                  but...
                  Have you try it ?
                  • KathrynGK Offline
                    KathrynG
                    No - and I will definitely do it tomorrow, sadly tonight I am working on another deadline and will probably be here for hours yet. I always take platform disclaimers at face value though, and as you saw in my screen shot, it definitely said that it does not support the Mac. But... if you think it will be OK, I will try and see what happens.
                    • BoxB Offline
                      I hope you are understanding how to move things correctly and not just trying to click and drag.
                      • KathrynGK Offline
                        KathrynG
                        Yes ๐Ÿ˜„ Took a while for me to remember to change methods when switching between SU and PS, but I just have not "got" that whole snapping and inferencing thing finely tuned. Well... practice makes perfect they say, and it is just sad that I can never find the time to practice enough and then when I find myself with a deadline start to regret not telling ye olde family to make their own dinner for a week or so, and give me some extra time to practice and do some more "studying"! The joys of running a home and trying to do all this stuff as well. And they are all spoiled rotten... ๐Ÿ˜‰
                          raineysky
                          KathrynG,
                          Beautiful render!!! And I hear what you are saying about nudge. Sometimes I work between Powerpoint and Sketchup and find myself trying to hold down the CTRL button and "nudge" with the arrows keys in Sketchup like I do in Powerpoint....It would be a nice native feature.
                          • KathrynGK Offline
                            KathrynG
                            Thank you ๐Ÿ˜„ The problem is that I get where I need to go, but I know that what takes me three hours to do, should only be taking maybe an hour if my SU skills were not so inadequate. My new year's resolution - take, actually steal some time from whatever I am doing every day to devote at least an hour to doing it right! This is why I tried to find some actual get in the car and go to classes, as then there is no way to say - well... maybe later.
                            Have a nice evening.
