    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 156.9k Views 85 Watching
    • JQLJ Offline
      JQL
      Amazing plugin pgarmyn!
      I will try it for sure, simply not right now as I'm right in the middle of designing on some of my own SectionCutFaces.
      I have a couple of questions though:
      I suppose those sections have guides as above section geometry... What happens when I "delete all guides"? Will they show up automatically when I go to section scene?
      I can see in the videos your section auto updates, will I be able to draw on the section and my drawing sticks in it or will it disappear? I am used to do it to detail construction docs and generate floor areas. If I'd keep doing that can I lock a specific section?
      What if I accidentaly/on purpose delete guides? Will I be able to refresh only the guides on section so I can have the hand drawn section with hidden lines?
      Thanks for what seems to be a bombshell!
      JQL
      www.casca.pt
      Visit us on facebook!
        pgarmyn
        I have a couple of questions......!
        JQL
        When you delete all guides, you will have to recalculate (update) the RichSection.
        ....draw on the section... : If you don't draw in the __section-group or __projection-group; You will also have to exclude your section-data by using a scene for 'layers to section/project'.
        ....refresh only the guides.... : You could make two RichSections (aligned): one with only 'project' swtitched on, the other with only 'section' switched on; You will have to make yourself a scene to combine the layers of the two RichSections
        Thank you for your interest Joรฃo, and good luck ๐Ÿ˜„
          pgarmyn
          @rich o brien said:
          Indigo respect Section Cuts
          Thanks for the info. That's really a plus for SU-users.
          • W Offline
            wat
            • doush-007D Offline
              doush-007
              god please you ๐Ÿ˜
              • soloS Offline
                Rich, can you confirm that Indigo works with this plugin?
                Then I guess I'd like to know how Indigo can do it and other cannot.
                • takesh hT Offline
                  takesh h
                  pgarmyn,
                  Tour de force! ๐Ÿ˜ฎ
                  Videos look marvelous too... however, is it working properly for everybody else?
                  So far I'm getting no result from the plugin.
                  It makes cuts and shows the dialog box, but never generated sections with materials.
                  IOW it is working like native SU section tool, although it does generate automatically named scenes.
                  I'm on Win7, Dell XPS8500, Intel Corei7-3770 3.4GHz, 12GB RAM, SketchUp8.
                  Any help? โ“
                  • I Offline
                    ivreich
                    Great plugin!
                    Is it possible for different solids/groups/components to be assigned different hatch properties so that you can show different hatch patterns with the same section cut?? Like Revit's section box?
                    That would be awesome...
                    Joel
                      LionByDesign
                      This plugin is exactly what I need! ๐Ÿ˜
                        pgarmyn
                        @takesh h said:
                        pgarmyn,
                        Tour de force! ๐Ÿ˜ฎ
                        So far I'm getting no result from the plugin.....
                        Any help? โ“
                        It should work on SU8. (It works for me)
                        You are the first after 160 downloads. Are there other people having problems?
                        Do you use components or groups? Are they closed in the sectionplan?
                        Test it with a Solid without changing any parameter in the dialog box?
                        Is there any error on the Ruby panel?
                          pgarmyn
                          @ivreich said:
                          Great plugin!
                          Joel
                          YES ๐Ÿ˜„ the 2nd video is showing that ๐Ÿ˜„
                          Use RichSection materials 'by layer' or 'by nature' or a combination.
                          Every RichSection can also have different section materials, by using a different 'prefix'
                          ๐Ÿ˜„
                          • micioneM Offline
                            micione
                            Report a conflict with "offset.rb."
                            attached file.
                            offset.rb
                              doush-007
                              Hello,
                              i install the plugin but it doesn't appear any where , i searched in toolbar menu , any idea ?
                              I am using sketchup 2013.
                                pgarmyn
                                attached file.
                                Ok, thanks. I will try to fix that. It will take some time.... โ—
                                  pgarmyn
                                  @doush-007 said:
                                  Hello,
                                  A new plugin must be activated in the menu 'window/preferences',
                                  a panel opens, select 'extensions' and activate 'RichSection'.
                                    doush-007
                                    thanks a lot ๐Ÿ˜„
                                      pgarmyn
                                      attached file.
                                      Offset.rb is not a standalone plugin (Can be called by other plugins). It is from Rick Wilson, created in 2004.
                                      What's happening โ“ How do you know there is a conflict โ“
                                      What other plugin is using offset.rb ? (Probably anther plugin from Rick Wilson) โ“
                                        Because your code is all encrypted we don't know what it does.
                                        If it has any 'offset; methods within it that are not encapsulated in your module/class methods, then your 'offset()' method might well clash with the bald scripted 'offet.rb' by RickW, if users have that loading with other scripts.
                                        Your code must not interfere with base class/module/methods or other's scripts that load as helpers - these are things like offset.rb, progressbar.rb and so on... It's easy enough to recast your own versions within your own modules so there is no overlap with other scripts... ๐Ÿ˜’
                                          pgarmyn
                                          About my code:
                                          • Every method, variable, ... is declared within module PiGa ; module RSection ; end ; end
                                          • No basic classes or modified or extended.
                                            And this is the case for the loader PiGa_RichSection.rb, and the main ruby RichSection.rbs
                                          That wasn't yet good practice in 2004 (Looking in code of offset.rb)
                                          I scanned my code : there is no method 'offset' or anything else named 'offset'
                                          So, if there is something โ“ The problem is not there.
                                          Please, micione tell me....
                                          What's happening ? How do you know there is a conflict ?
                                          • micioneM Offline
                                            micione
                                            pgarmyn,
                                            "offset.rb" is used by other tools of Rick Wilson (eg "windowizer").
                                            What happens:
                                            Your tool applies the first section, then it stops, stuck.
                                            Any attempt to use the "move tool" on the section, it causes BugSplat.
                                            Only by removing "offset.rb" your tool starts working again.
                                            In order to identify the conflict, must be eliminated (one by one) all installed plugins. And this is what I did.
                                            I hope I was helpful.
                                            P.S. perhaps seek the advice of Rick Wilson?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 17 / 20
