    How to use shape as template to cut holes?
    18 Posts 6 Posters 2.6k Views 6 Watching
      mikedd
      Excellent! Thank you, I got the job to make it.
        Good work.
          mikedd
          From Sketchup to the real-deal.
          Due to costs and time restraints the holes didn't make it to the actual job, but it turned out nice
            Good work.
              mikedd
              @dave r said:
              Good work.
              Thanks Dave!
              • cottyC Offline
                cotty
                Another way: (multi) hole on solid, see this screencast.
                my SketchUp gallery
                  mikedd
                  That is fast and easy, installing now. Thank you.
                  • cottyC Offline
                    cotty
                    If you want to use the multi hole tool, the hole components must have the "cut hole option" active (and this is difficult to find in the documentation)
                    my SketchUp gallery
                      mrossk
                      I was just gonna ask about the holes!
                      https://www.mkaplanfinefurniture.com/
                        mikedd
                        Yeah, it would have meant making a jig for the router then cut the holes out, round off the holes and then sanded them. Plywood is a pain in the butt to sand, I wish I had a router bit that could sand and cut at the same time- that would be a great time saver.
