    How to use shape as template to cut holes?
    18 Posts 6 Posters 2.6k Views 6 Watching
      mikedd
      kids steps.jpgThank you very much. I'm wondering without starting from the beginning if I can do this.
      The oval cut outs will be hand grabs near the top of the side panels (stair stringers), 5 on one side and 5 on the other.
      Could I cut the 5 ovals on one side and the 5 on the other so they willkids steps.jpg be an exact match.
        The answer is yes. How easily depends upon how you drew the model. If I were drawing it the side pieces would be instances of the same component and the right one would be flipped (mirrored) compared to the left. Then cutting the openings in one would result in identical openings being cut in the other.
        If you used groups or didn't do anything but draw the geometry, things get more complicated but it can still be done.
        Instances of the same component
        Ovals laid out on one instance. You can see them on the other at the same time.
        After using Push/Pull on the faces inside the ovals.
          mikedd
          Excellent! Thank you, I got the job to make it.
            Good work.
              mikedd
              From Sketchup to the real-deal.
              Due to costs and time restraints the holes didn't make it to the actual job, but it turned out nice
                Good work.
                  mikedd
                  @dave r said:
                  Good work.
                  Thanks Dave!
                  • cottyC Offline
                    cotty
                    Another way: (multi) hole on solid, see this screencast.
                    my SketchUp gallery
                      mikedd
                      That is fast and easy, installing now. Thank you.
                      • cottyC Offline
                        cotty
                        If you want to use the multi hole tool, the hole components must have the "cut hole option" active (and this is difficult to find in the documentation)
                        my SketchUp gallery
                          mrossk
                          I was just gonna ask about the holes!
                          https://www.mkaplanfinefurniture.com/
                            mikedd
                            Yeah, it would have meant making a jig for the router then cut the holes out, round off the holes and then sanded them. Plywood is a pain in the butt to sand, I wish I had a router bit that could sand and cut at the same time- that would be a great time saver.
