    SketchUp and OSX Mavericks....
    83 Posts 22 Posters 16.0k Views 22 Watching
      slbaumgartner
      @tig said:
      Correcting the typo in the remote version does not change things anyway - the remote still fails with Mavericks... but the local version succeeds [with the unnecessary 'allow' method removed, on with the typo corrected or the typo intact]
      BUT the weird thing is that if you try the [corrected OR typo-ed] tests on a pre-Maverick MAC or a PC, then both the local and remote versions perform just fine, as if the 'allow' and/or typo is ignored and the 'allow' is 'an irrelevance' ๐Ÿ˜’
      OK, this just keeps getting weirder ๐Ÿ˜ฎ On my Mavericks Mac, TIG.remote works just fine after the typo is corrected. What the bleep is going on????
      • Chris FullmerC Offline
        That is what we're seeing here as well Steve. From what we're seeing this all boils down to either having not included the allow_actions_from_host either not being implemented at all, or having been implemented with bad syntax (a url vs a domain string), or a typo.
        It appears no other OS, other than Mavericks, actually pays any attention to this method. That is what my quick testing is showing. I'm very open to hear about exceptions to these findings or issues that might be different.
          slbaumgartner
          Whew, at least I might not be losing my mind
          I read the documentation for this method multiple of times and I am not at all sure I understand it ๐Ÿ˜ฒ What sort of "actions" could take place on a "host remote from the host where the WebDialog exists"? That seems to say that an action callback could be routed to a remote host? How? The skp: protocol handler is part of the WebDialog code running on the local host...very confused...
            slbaumgartner
            After playing around with this a bit more, I may have answered my own question. On my Mavericks Mac, the skp:callback from TIG.remote fails with the now familiar error message if the call to allow_actions_from_host is omitted or invoked with a bad argument when the WebDialog is set up by Ruby (which is what Chris said before, I just didn't understand).
            So, the concern isn't about executing an action on a remote host, it is about preventing skp: callbacks when the WebDialog contents were loaded from a remote host and might be malicious. Restricting the callbacks to pages from only trusted domains registered with this method then makes sense.
            Which, of course, doesn't answer the question of why this method is ignored on most OS's and suddenly started working in Mavericks! But that will have to be answered by the Trimble SketchUp engineers, since the rest of us have no insight as to how this part of WebDialog is implemented.
            As a note to the Trimble engineers: it would have been a lot easier for us outsiders to track this down if the error message was clearer. The message reports the full URL of the callback that it doesn't like (which is why we see the skp:callback@ part), and calls it an "Invalid URL" whereas it is actually a prohibited callback from a page that wasn't vetted by the Ruby code.
              So to recap... ๐Ÿ˜„ ๐Ÿ˜•
              If a webdialog uses a remote url and it uses allow_actions_from_host(string) and that 'string' is somehow incorrectly formed, then it is ignored by all OSs which continue to operate correctly with its callbacks - except for Mavericks which always fails !
              But with a correctly formed 'string' that is a 'domain' Maverick succeeds too.
              Mavericks will fail if the dialog is using a remote url BUT it does not include a allow_actions_from_host(string), or of course if it is used and the 'string' is not a proper 'domain'.
              In the case of SketchThis's dialog that host 'string' [given by the web-developer] included an initial http:// - making it a 'url' rather than a 'domain', with all OSs it had previously worked OK anyway, but now it failed when used with the new Mavericks...
              This 'string' has now been corrected in the SketchThis code, it is now a 'domain' without an initial http://, and it now works correctly with the SketchThis dialog callbacks.
              In contrast with the SketchUcation's Plugin Store dialog that 'string' was already correctly formed as a 'domain', and therefore it worked on ALL OSs, including Mavericks.
              So anyone experiencing issues like this with remote url dialogs Mavericks-only should check that their dialog includes the allow_actions_from_host(string) AND that it has a good 'string' that is a 'domain' and not a 'url' [or a typo!]...
              This good-practice will also future-proof their code against any IE updates that might replicate the somewhat excessive care that is now taken by Maverick's version of Safari...
              ๐Ÿ˜’
                DidierML
                I have experienced a few bugs. I'm not entirely if they are related to Mavericks, but they seem to have appeared after the update.
                • My tool palettes ( Layers, Style, Scenes, etc ) don't "stick" together anymore. When I click on them to enlarge, they just dissociate from the others, which is pretty annoying.
                • I have experienced a few other visual bugs while using Mission Control (with the gestures) ; palettes don't come back as they should, or just slower performances.
                • mariochaM Offline
                  mariocha
                  @tig said:
                  So to recap... ๐Ÿ˜„ ๐Ÿ˜• ...
                  So anyone experiencing issues like this with remote url dialogs Mavericks-only should check that their dialog includes the allow_actions_from_host(string) AND that it has a good 'string' that is a 'domain' and not a 'url' [or a typo!]... ... ๐Ÿ˜’
                  Hum... will this also correct the "Java Script disabled" problem ?
                  %(#008000)[Mario C.
                    Regular Polygon
                    Hi Mariocha,
                    I think it will. Keyframe Animation reports that error when it can't connect to the server. The web dialog that would connect is probably failing because I didn't implement the WebDialog.allow_actions_from_host method. I'll release an update as soon as I have a chance. Perhaps you could test it for me -- I don't have a computer with Mavericks.
                    My SketchUp Plugins
                      Make sure you pass the method a valid domain-name - NOT the http:// address...
                      That 'type' error and also typos in a seeming correct domain-name etc caused difficult to track-down issues [with Mavericks only] when included in some other scripts that use that method ๐Ÿ˜’
                        ayala80
                        hi, i tried to import a .dwg file to sketch up and this warning appears instantly: "warning, importer not found".
                        thanks.
                        I'm running sketch up pro 8 on Mac osx 10.9, and the .dwg file is 2010.
                          pichuco
                          In my case (SU 8 PRO& Mavericks) I can't import DWG files. A dialog appears saying: Alert, importer not found. Also I noticed that the Palettes don't work as expected. Very sad don't know what to do ?
                          • mariochaM Offline
                            mariocha
                            .... Perhaps you could test it for me -- I don't have a computer with Mavericks.
                            I will sure be glad to give it a try, Doug.
                            Your plugin is a must for me.
                            updt: Received a beta, works just fine. โ˜€ ๐Ÿ˜„
                            updt: New version 1.8.4 available on the Regular Polygon website.
                            %(#008000)[Mario C.
                            • mariochaM Offline
                              mariocha
                              Just for info.
                              Here there is no problem importing dwg files, on both my computers under Maverick.
                              %(#008000)[Mario C.
                              • mariochaM Offline
                                mariocha
                                • My tool palettes ( Layers, Style, Scenes, etc ) don't "stick" together anymore. When I click on them to enlarge, they just dissociate from the others, which is pretty annoying. ...
                                It is indeed pretty annoying. It was a very appreciated feature. Hoping a maintenance update will correct that ! Please ?
                                updt: My wish for the new year !
                                %(#008000)[Mario C.
                                • H Offline
                                  hambuild
                                  @martychristoffel said:
                                  I'm running into palettes that are no longer "sticky" since upgrading to Mavericks. To be more precise, although the palettes do snap to one another, when expanding one such as the Layers palette, it opens underneath the minimized Styles, Scenes, etc. instead of having those palettes remain connected to the Layers pane. When minimizing them down to their title bars, they can also lose their relative association to other palettes.
                                  ME Too!
                                  • mariochaM Offline
                                    mariocha
                                    2014 Sticky palettes are back !!!
                                    Now how about bringing back thumbnail icon of SkUp files in Finder. Was there up to v8. So practical.
                                    Anyway very happy with v2014. Full congrats to the SU team ! ๐Ÿ˜„
                                    %(#008000)[Mario C.
                                    • 4 / 5
