    SketchUp and OSX Mavericks....
    83 Posts 22 Posters 17.1k Views 22 Watching
    • Chris FullmerC Offline
      Yeah, the developer's forum is a good place for it I think.
      Still looking into it on our end, nothing new to add to the discussion yet.
        It's already in the Devs' forum ๐Ÿ˜‰
          I just had my mind blown โ˜€
            slbaumgartner
            For what it's worth, I just noticed that the same typo was present in both the TIG.remote and TIG.local methods, but only the TIG.remote failed due to the typo. Does allow_actions_from_host() look at previously loaded pages to see whether that host is used by any of them? How does the SketchThis ruby obtain the host URL it passes to this method?
              slbaumgartner
              faster than a speeding bullet...
                And of course the local version didn't need the' allow' anyway - it was a web-guy/Eric tinkering with my original ruby ๐Ÿ˜’
                Correcting the typo in the remote version does not change things anyway - the remote still fails with Mavericks... but the local version succeeds [with the unnecessary 'allow' method removed, on with the typo corrected or the typo intact]
                BUT the weird thing is that if you try the [corrected OR typo-ed] tests on a pre-Maverick MAC or a PC, then both the local and remote versions perform just fine, as if the 'allow' and/or typo is ignored and the 'allow' is 'an irrelevance' ๐Ÿ˜’
                • H Offline
                  honkinberry
                  Actually, it does just seem to be exactly that, allow_actions_from_host.
                  I had noticed with V6 that it was ignored, so I never implemented it.
                  But in my remote WebDialog, which is failing, I simply add an allow_actions_from_host, and suddenly now it's working again.
                  --J
                    I'll jump in now, I concur that it all appears to be related to the dlg.allow_actions_from_host method. I think its possible that Win and OS have not actually been honoring that method. But Mavericks now suddenly does.
                    So if people are not using it, it will dis-allow certain actions with remote websites and throw that error.
                    If you do use it (which you really should now), make sure you have the syntax correct. You should be giving it a domain, not a url. example: dlg.allow_actions_from_host("http://www.sketchup.com") is not correct, it should be dlg.allow_actions_from_host"www.sketchup.com"
                    Now I'm curious to know if that is enough to fix all/any of the problems, or are people still seeing other problems?
                      slbaumgartner
                      OK, this just keeps getting weirder ๐Ÿ˜ฎ On my Mavericks Mac, TIG.remote works just fine after the typo is corrected. What the bleep is going on????
                        That is what we're seeing here as well Steve. From what we're seeing this all boils down to either having not included the allow_actions_from_host either not being implemented at all, or having been implemented with bad syntax (a url vs a domain string), or a typo.
                        It appears no other OS, other than Mavericks, actually pays any attention to this method. That is what my quick testing is showing. I'm very open to hear about exceptions to these findings or issues that might be different.
                          slbaumgartner
                          Whew, at least I might not be losing my mind
                          I read the documentation for this method multiple of times and I am not at all sure I understand it ๐Ÿ˜ฒ What sort of "actions" could take place on a "host remote from the host where the WebDialog exists"? That seems to say that an action callback could be routed to a remote host? How? The skp: protocol handler is part of the WebDialog code running on the local host...very confused...
                            slbaumgartner
                            After playing around with this a bit more, I may have answered my own question. On my Mavericks Mac, the skp:callback from TIG.remote fails with the now familiar error message if the call to allow_actions_from_host is omitted or invoked with a bad argument when the WebDialog is set up by Ruby (which is what Chris said before, I just didn't understand).
                            So, the concern isn't about executing an action on a remote host, it is about preventing skp: callbacks when the WebDialog contents were loaded from a remote host and might be malicious. Restricting the callbacks to pages from only trusted domains registered with this method then makes sense.
                            Which, of course, doesn't answer the question of why this method is ignored on most OS's and suddenly started working in Mavericks! But that will have to be answered by the Trimble SketchUp engineers, since the rest of us have no insight as to how this part of WebDialog is implemented.
                            As a note to the Trimble engineers: it would have been a lot easier for us outsiders to track this down if the error message was clearer. The message reports the full URL of the callback that it doesn't like (which is why we see the skp:callback@ part), and calls it an "Invalid URL" whereas it is actually a prohibited callback from a page that wasn't vetted by the Ruby code.
                              So to recap... ๐Ÿ˜„ ๐Ÿ˜•
                              If a webdialog uses a remote url and it uses allow_actions_from_host(string) and that 'string' is somehow incorrectly formed, then it is ignored by all OSs which continue to operate correctly with its callbacks - except for Mavericks which always fails !
                              But with a correctly formed 'string' that is a 'domain' Maverick succeeds too.
                              Mavericks will fail if the dialog is using a remote url BUT it does not include a allow_actions_from_host(string), or of course if it is used and the 'string' is not a proper 'domain'.
                              In the case of SketchThis's dialog that host 'string' [given by the web-developer] included an initial http:// - making it a 'url' rather than a 'domain', with all OSs it had previously worked OK anyway, but now it failed when used with the new Mavericks...
                              This 'string' has now been corrected in the SketchThis code, it is now a 'domain' without an initial http://, and it now works correctly with the SketchThis dialog callbacks.
                              In contrast with the SketchUcation's Plugin Store dialog that 'string' was already correctly formed as a 'domain', and therefore it worked on ALL OSs, including Mavericks.
                              So anyone experiencing issues like this with remote url dialogs Mavericks-only should check that their dialog includes the allow_actions_from_host(string) AND that it has a good 'string' that is a 'domain' and not a 'url' [or a typo!]...
                              This good-practice will also future-proof their code against any IE updates that might replicate the somewhat excessive care that is now taken by Maverick's version of Safari...
                              ๐Ÿ˜’
                                DidierML
                                I have experienced a few bugs. I'm not entirely if they are related to Mavericks, but they seem to have appeared after the update.
                                • My tool palettes ( Layers, Style, Scenes, etc ) don't "stick" together anymore. When I click on them to enlarge, they just dissociate from the others, which is pretty annoying.
                                • I have experienced a few other visual bugs while using Mission Control (with the gestures) ; palettes don't come back as they should, or just slower performances.
                                • mariochaM Offline
                                  mariocha
                                  @tig said:
                                  So to recap... ๐Ÿ˜„ ๐Ÿ˜• ...
                                  So anyone experiencing issues like this with remote url dialogs Mavericks-only should check that their dialog includes the allow_actions_from_host(string) AND that it has a good 'string' that is a 'domain' and not a 'url' [or a typo!]... ... ๐Ÿ˜’
                                  Hum... will this also correct the "Java Script disabled" problem ?
                                  %(#008000)[Mario C.
                                    Regular Polygon
                                    Hi Mariocha,
                                    I think it will. Keyframe Animation reports that error when it can't connect to the server. The web dialog that would connect is probably failing because I didn't implement the WebDialog.allow_actions_from_host method. I'll release an update as soon as I have a chance. Perhaps you could test it for me -- I don't have a computer with Mavericks.
                                    My SketchUp Plugins
                                      Make sure you pass the method a valid domain-name - NOT the http:// address...
                                      That 'type' error and also typos in a seeming correct domain-name etc caused difficult to track-down issues [with Mavericks only] when included in some other scripts that use that method ๐Ÿ˜’
                                        ayala80
                                        hi, i tried to import a .dwg file to sketch up and this warning appears instantly: "warning, importer not found".
                                        thanks.
                                        I'm running sketch up pro 8 on Mac osx 10.9, and the .dwg file is 2010.
                                          pichuco
                                          In my case (SU 8 PRO& Mavericks) I can't import DWG files. A dialog appears saying: Alert, importer not found. Also I noticed that the Palettes don't work as expected. Very sad don't know what to do ?
                                          • mariochaM Offline
                                            mariocha
                                            .... Perhaps you could test it for me -- I don't have a computer with Mavericks.
                                            I will sure be glad to give it a try, Doug.
                                            Your plugin is a must for me.
                                            updt: Received a beta, works just fine. โ˜€ ๐Ÿ˜„
                                            updt: New version 1.8.4 available on the Regular Polygon website.
                                            %(#008000)[Mario C.
                                            • 4 / 5
