    Shadows not showing
    6 Posts 4 Posters 426 Views 4 Watching
      timdean
      Hi, I am using 2013 Pro on Mac and despite tinkering with every setting I can think of after reading various articles on the subject, I cannot get shadows to project on the ground, or even clearly on surfaces as I have seen in others' architectural models. All that happens as I slide time and date is a subtle variation in shading on surfaces until it blacks out. Any suggestions?
      • cottyC Offline
        cotty
        Is the checkbox "on ground" activated in the shadow settings window?
        (Is your geometry over the ground plane (blue z=0)?)
        my SketchUp gallery
          timdean
          Hi Cotty,
          Thanks for the reply. Here's a screen shot of a current project. Shadows on ground is checked - although greyed out.
          • cottyC Offline
            cotty
            In windows, there is a toggle button in this window which turns on shadows...
            my SketchUp gallery
            • gillesG Offline
              gilles
              Also it seems that part of your building is under the red axis, this part will not cast shadows on the ground.
              • Wo3DanW Offline
                Wo3Dan
                @timdean said:
                ......I cannot get shadows to project on the ground, or even clearly on surfaces as I have seen in others' architectural models. All that happens as I slide time and date is a subtle variation in shading on surfaces until it blacks out. Any suggestions?
                Where are your axes? See if reset is available if you right click on an axes in empty space. (Ground plane [R/G] for some reason could very well be 100m above your modeling space).
