    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 246.2k Views 84 Watching
      rv1974
      How could I solve this?
        @rv1974 said:
        How could I solve this?...
        This is odd... 😕
        What's your IE version, SketchUp version etc... ?
        Check your Internet Options are set sensibly to allow javascript to run, communication back and forth with www sites etc.
        The SCF dialog page is failing to load at its first hurdle when it checks your login cookie, using a js function loaded from the server-side js to which it passes the cookie data read in by the Ruby-side...
        Have you set your Security permissions to the Plugins folder to FULL, and SketchUp.exe Compatibility to always run as administrator etc ?
        Have you been able to access the dialog previously ?
        What has changed ?
        • G
          Gábor
          You can try to erase the cookie.dat file in yor user's folder's ~/AppData/Local/SCF subfolder. Restart the pluginstore. You should be prompted for login. If everything goes well, you'll be able to use the pluginstore. My suspition is that this file is corrupted.
          If it won't help, let's wait for TIG. 😄
          (Meanwhile TIG arrived...)
            If the cookie file is not there at all OR it exists and it is read-in but its contents do not match a server-side encrypted register then you are asked to log-in again, then the cookie file is rewritten/made with suitable data, you can then access the page thereafter.
            If the cookie file is read-in and its contents do match a server-side encrypted register then you are free to access the page immediately.
            I don't see this as a cookie issue.
            The js error message tells us that the function 'loginCookieData()' is somehow missing - this suggests that the server-side js is not loading, and/or its related missing as a callback - the Ruby code must be loading otherwise the web-dialog wouldn't appear at all ?
            • G
              Gábor
              If the .js is not loading then I would like to know what pluginstore version is used?
              Can it be a cache issue with the .js file?
                You can get the Version of the SketchUcation toolset from the Preferences > Extensions entry details - the most recent one should be 2.0.0
                • P
                  Pherim
                  This is really great, I love how easy it is now to install and update plugins! Really a great piece of work!
                  However, the updating functions in "My Plugins" doesn't seem to work. I saw today that there was a new version of Fredo6's Bezier Spline and still the Window was empty, when I activated "check for updates". I have to wait until other plugins get updated in order to find out whether this also applies to them. I'm running Sketchup 2013 Free version on Windows 7 64bit and I just noticed that apparently I don't have Internet Explorer installed (must have uninstalled it some time but forgot about it). But the plugin still works, except for the update function.
                    Is that a complaint about the tool, Pherim?
                    Why not install Internet Explorer and make sure you keep it up to date? Then the tool would work for you. It's a well known thing that SketchUp uses Internet Explorer for contact with the outside world.
                    • P
                      Pherim
                      It's not a complaint, the tool is great, this was just one thing I noticed, and I was not sure whether this was a problem with the tool or with internet explorer, and apart from that it worked perfectly fine even though I had not installed internet explorer. That's what confused me. Well, I will try installing IE and then try the updating function again once a plugin is updated. Apart from that, I am really amazed about the tool, which made organizing my plugins so much easier. Thanks a lot for this!
                      • G
                        Gábor
                        Could you please explain in more detail what is happening?
                        When you change the dropdown to "My Plugins", you should see a list of all plugins what you installed or downloaded from the pluginstore. Is that the case?
                        When you check the checkbox "Check for updates", you should see a filtered version of this list. Only those plugins should show up, what have an update since you downloaded them. If none of the downloaded plugins have an update, you get an empty list (a blank page). Is that what is happening?
                        If there are updates in this list, when you click on the install update button near the plugin entry, the new version of the plugin should be installed. Is that what is happening?
                        • C
                          CL
                          When you change the dropdown to "My Plugins", you should see a list of all plugins what you installed or downloaded from the pluginstore. Is that the case? In my case yes, I see all my downloaded plugins.
                          When you check the checkbox "Check for updates", you should see a filtered version of this list. Only those plugins should show up, what have an update since you downloaded them. If none of the downloaded plugins have an update, you get an empty list (a blank page). Is that what is happening? When I filter, I get an empty list and I know Fredos plugins need updating.
                          If there are updates in this list, when you click on the install update button near the plugin entry, the new version of the plugin should be installed. Is that what is happening? Can't say, as nothing ever appears.
                          I have chosen not to activate IE on my system. I don't use it. I could activate it and possibly remove the issue, but I'm happy enough to keep it as a test bed if you want it. Surely it should be possible to use the sketchucation plugin without full subjugation to microsoft, but if not I'm not too bothered.
                          • G
                            Gábor
                            Thannk you for the answer.
                            • BoxB
                              I have the same result and I do have IE.
                              I hadn't noticed before but when fredos update tool told me I need to update I checked and I get nothing in the list.
                              • G
                                Gábor
                                @box said:
                                ..... I get nothing in the list.
                                It is because all your plugins are up to date. But now that I realized that it might be misleading, I'll change the code to output some explanation instead of a blank page.
                                Edit: Done.
                                • BoxB
                                  But my plugins are not up to date.
                                  • G
                                    Gábor
                                    Have you installed them through the Pluginstore Plugin install function? In other words: Are they in your "My plugins" list when you don't check the checkbox?
                                    • BoxB
                                      Yes they are in the list, I think I see the reason though. I have more than one computer and I have updated those plugins on a different one, so the tool is registering that I have downloaded the latest, but it doesn't know that I haven't done it on this PC.
                                      • G
                                        Gábor
                                        @box said:
                                        .... I have more than one computer and I have updated those plugins on a different one, so the tool is registering that I have downloaded the latest, ....
                                        Yep, you're right. That could be a problem, as the server only registers the users and not what machine are they from.
                                        Maybe we will find an other way to look for updates in the next version of the pluginstore with TIG. Until then it works as the server registers what was the latest downloded plugin by the user and compares that to the current version of the plugin in the pluginstore.
                                          DOD3R
                                          Error Loading File !SketchUcation_loader.rb
                                          premature end of regular expression: /^C:/Users/ì$
                                          my username on the computer contains character ý can i somehow overcome this problem or does it mean OS reinstall?
                                          • P
                                            Pherim
                                            Ok I don't know why exactly CL answered to this question that was directed to me, but it doesn't matter.
                                            I have installed IE since my last post, but this did not change the issue, even though there was one plugin which should have been displayed as in need for an update (Tools on Surface). However, I got the empty list, just as before. But I will have to wait until another plugin is updated in order to confirm this because I already installed the update.
                                            So yes, I see the list of all downloaded plugins, but when I click "Check for updates" the list was empty even though I should have at least one update. It looked identical to the screenshot posted by Box. But I use the plugin store only on one machine, so his conditions don't apply.
                                            At the moment I see the message that all my plugins are up to date. Will report back as soon as one receives an update.
                                            • 19
                                            • 20
                                            • 8 / 20
