    Newbie w/ a new hobbie
    35 Posts 5 Posters 1.8k Views 5 Watching
      Coach_Travis
      @box said:
      What dave means shows clearly in your dugout, the white on the outside is the front of the face and the blueish colour on the stairs etc is the back face.
      Front and back of the faces tells the software what is going on. Often back faces won't render properly.
      So, this doesn't mean they are not conplaner. It shows that I drew the back side of a face (Black), when it should have been the front of the face (White)? If this is correct how did I do this? Is it because I used the push/pull tool? Should I have deleted the bottom and redrew it so it would be the front face?
        Coach_Travis
        I think I understand what you are both saying? Would this be the correct fix? I made the floor of the dugout with the front face up.
        http://i1055.photobucket.com/albums/s512/31BX/Correction.png
        • BoxB Offline
          Yep, so if the Grass, for example, was blueish before you painted it then it is back to front.
            Coach_Travis
            What causes this? I drew lines coplanar using the axis. Why did it automatically put the back face on the top?
            • BoxB Offline
              When you draw a square on the ground Sketchup assumes you are going to extrude it, so it makes the back face up.
                Coach_Travis
                Ahhh, it expect that you are going to make some type of 3D shape this that being the inside. How would you alleviate this? Would you draw that outline like I did then push/pull up a predetermined length?
                • BoxB Offline
                  Right click on it an select reverse face.
                    Coach_Travis
                    Well crap, if I would have known it was that easy πŸŽ‰. Thank you for the tip.
                      Yes, it does. It would probably be easiest to start on top of a box. You could draw your outline and use Push/Pull as you suggest.
                        Coach_Travis
                        Does this look better?
                        http://i1055.photobucket.com/albums/s512/31BX/TotalFix.png
                          That looks good. Remember under Edit there's a item for Delete Guides. Use it once in awhile to declutter your model space. I set up a keyboard short cut for that.
                          As for the back face color, the one in the style you're using can be difficult to discern as different from the shaded white surfaces. I created my own default style with a green back face color. It's a color I'd be unlikely to use in my models but it is easily seen even if it's only a few pixels on the screen.
                            Coach_Travis
                            Dave - Thank you for the tips. The thing about baseball fields is the guides are used for multiple things. I will need most of those lines in the future.
                            You are right about the face colors. Sometimes I can not tell if it is a shade or not. I am going to change my face colors.
                            • BoxB Offline
                              You can turn the visibility of Guides on and off, View menu/Guides
                                Coach_Travis
                                Box - Thanks for the tip.
                                • BoxB Offline
                                  Another small tip before you go too far. Make sure you know about Groups and Components and how they separate geometry and make repetition easy.
                                    Coach_Travis
                                    Yeah, I need to research that more.
                                      Coach_Travis
                                      Dave - Changing the face color really assisted. Thank you again.
                                        Coach_Travis
                                        I got the batter's boxes and catcher's box done this morning.
                                          Coach_Travis
                                          Is there a way to copy the dugout on the first base side and paste it to the third base side?
                                          • BoxB Offline
                                            Yes, there are many ways. One of the most basic is to select the geometry of the dugout and use Copy and Paste.
                                            But SU makes it easier, many tools allow you to move and copy things at the same time.
                                            The Move tool for example, if you select geometry, then using the Move tool, Hold down CRTL and click then move and it will create a copy of what you have selected. The same works with the rotate tool, so you could find the center of your field and rotate a copy of the dugout to the new position.
                                            This then brings you to components, if you make the dugout a component it becomes it's own little package of geometry that won't stick to anything. You can then copy it to the other position and any edits to one will happen to the other.
