    Keep background from frame buffer
    renderpluginsextensions
    8 Posts 5 Posters 680 Views 5 Watching
    • TampaPowersT Offline
      TampaPowers
      How do i save the background image v-ray shows in the frame buffer?
      Sketchup Community Discord
        rspierenburg
        If you render it once and set it to save a .vrimg file you can reload that image back into the frame buffer.
        • V Offline
          valerostudio
          Are you asking about the actual image that appears in the background of your render?
          • andybotA Offline
            andybot
            If you save as a .jpg, it will save the background.
              TampaPowers
              Saving as .jpg seems to do what i want, but is there a way to get that result with .png?
              • andybotA Offline
                andybot
                If you deselect the alpha channel in your "channels" options, then it should save a "flattened" image with the background. What I do if I want the png, is to save both, and I can use the jpg as the background and overlay the better resolution png over top of it.
                • Z Offline
                  Zylescozar19
                  Save it to .jpeg then go to Photoshop save it again to .png. goodluck!
                  • andybotA Offline
                    andybot
                    The problem with the jpg saved from vray is that it is compressed and is lower quality than the png file. You will end up with a lower quality png file with your suggested method.
