    1.3k Posts 299 Posters 2.5m Views 297 Watching
      daloop
      Hi everybody,
      I have the same problem as Missy_X a few posts above.
      Whenever I activate one of the Curviloft functions in SU2013 (Windows 7, 64Bit), the "Curviloft: Temporary" window pops up immediately. I don't get the usual Fredo-Bar on top of the editor and the plug-in does not work. I can select edges behind the popup, but there's no preview and no lofting.
      The Ruby console shows nothing at all. I do have all the latest versions (including libFredo 6.5.2) installed.
      This is going on for a few days now. The plugins used to work fine. My current workflow relies on setting up 3D-Bezier curves and skinning them with Curviloft.
      Any help would be greatly appreciated.
      • fredo6F Offline
        @daloop,
        Could you post an exmaple of the error traces (there is the button in the temporary window to export the trace file).
        Thanks very much
          daloop
          Thanks for your support.
          Sorry, but I can't find any buttons on the window:
          • fredo6F Offline
            Then, could you post the model you are working on.
              daloop
              OK, here we go:
              Bezier12.zip
              • fredo6F Offline
                @daloop
                Curviloft does not know how to skin continuous loops. You should use TGI3d for that (or maybe Soap Skin & Bubble).
                With Curviloft Skinning, you need to cut the contour into 4 pieces. This can be achieved by creating small breaker segments as shown in the picture.
                Then, you can skin the shape.
                Daloop - Bezier12.skp
                  daloop
                  Hi Fredo,
                  Thanks again.
                  To see if I got it right: If the tool stops working and I only get the temporary window, I have to break up the curve.
                  May I humbly suggest a future version of Curviloft that behaves a bit more gracefully?
                  Attached is a lofted version I did last week. It is much more along the lines I need, as it is less concave than yours. It could be, though, that I broke the curve by lofting another, adjacent surface. But not into more than 2 pieces.
                  Loft13.zip
                  Any idea how to control the concavity? I can't change the Bezier curves, as they have real-world constraints.
                  I did try Soap Skin & Bubble but I like the Curviloft surface better.
                    I would respectfully disagree with you. Curviloft works just fine and is graceful as it is. It does exactly what Fredo said it does in the first post of this thread.
                    Curviloft is a script dedicated to Loft and Skinning, that is, generation of surfaces from contours.
                    • Loft by Spline joins separate contours, open or closed, by smooth splines
                    • Loft along Path joins contours, along a given rail curve.
                    • Skinning create surfaces bounded by 4 or 3 contiguous contours
                    The plugin can't help that the user doesn't set up the curves correctly.
                    Add some additional curves to define the concavity you desire.
                      daloop
                      Hi Dave,
                      Curviloft doesn't need your defense. The tool is a great piece of code and it does what is described in the docs.
                      Still, if I feed it a curve it can't compute it sometimes goes into a state where I only see the temporary window, even if I use it on other geometry that should loft just fine. And this state is even retained between restarts of SU.
                      I thought this could maybe qualify as a useability issue, if not as a bug, even if the behaviour was produced by user error.
                      Thanks for the suggestion. I do know, that I could even draw each and every face manually in 3D space to get the surface I want.
                      I was just hoping that Curviloft could maybe spare me from that tedium and as it already produced a nice surface with this Bezier curve in the past, I wondered why it stopped doing so.
                      I'm still learning the ins and outs of modeling in SU, so if a plugin gives me a nice result and saves me a few modeling steps, it is very welcome.
                        daloop
                        @daloop said:
                        [attachment=0:3mxjzsa4]<!-- ia0 -->Loft13.zip<!-- ia0 -->[/attachment:3mxjzsa4]
                        If I remember correctly, I did this with the loft-by-spline and not the skinning tool.
                        • jgbJ Offline
                          jgb
                          I use Curviloft a lot, I LOVE it. Can't be without it. ๐Ÿ˜ ๐Ÿ˜
                          But it does have some limitations and quirks. ๐Ÿ˜ฒ
                          One of the quirks I have learned to work around is CL's occasional failure to form some curves even when the perimeter seems fully intact and pristine. I can only attribute its fail to loft due to the connecting geometry in my model. Most likely due to very tiny undetectable fragments and/or gaps. Most times it works, but sometimes I need to do this.....
                          I select all the lines in my perimeter that failed to loft, and move/copy them some distance away in an axis direction, in free space. Fixing it in free space is far easier than in-situ.
                          CL will then loft in most cases. ๐Ÿ˜ฎ I simply move the group back in place.
                          However, sometimes it will still fail, so I look for changes in colors at endpoints. That usually signals a problem at the vertex and/or with the adjoining lines. I do a left/right select on only one side of the vertex and capture everything that touches the vertex, and delete. It also captures one line as well, leaving a gap. I do an endpoint to endpoint line draw and try CL again. Repeat until success.
                          However when you move the lofted group back into place, and explode it, you will need to redraw many connecting lines in the adjoining geometry, as those lines will have endpointed on the deleted entities. Your primary clue is failed faces touching the lofted curve.
                          ๐Ÿ’ญ Please note that the biggest cause of tiny line fragments and tiny gaps is Intersect. So if you are lofting any part of a previously intersected geometry, expect problems.
                          ๐Ÿ’ญ Another big cause of tiny endpoint gaps is drawing a line from point A to B where B is ever so slightly off axis to A and the dreaded "Constrained by" message was not heeded. You need to make sure you draw endpoint to endpoint.
                          If you do get the "Constrained by" message going from A to B, then Escape, and draw B to A. It will work then.
                          jgb
                          • cottyC Offline
                            cotty
                            After your explanations I'm not sure if it is really the plugin ๐Ÿ˜•
                            my SketchUp gallery
                            • fredo6F Offline
                              To all,
                              I need to revisit Curviloft to better control situations where the geometry has a problem (remember that it is still a beta).
                              In some cases, Curviloft may not perform the generation of shape, but usually there is an error message in the console.
                              I'll check however if this is always the case.
                              • fredo6F Offline
                                [attachment=0:2ad9ldbh]<!-- ia0 -->Loft13.zip<!-- ia0 -->[/attachment:2ad9ldbh]
                                I am not clear how you could have used Loft along Path for generating this shape (I see no path and no base shape).
                                With Skinning, Curviloft consider that sharp angles in the contour are taken as breaker until it can cut the contour in 3 or 4 pieces.
                                Anyway, as I told you, the best plugin for this kind of potatoid shape is certainly TGI3D. It uses another algorithm which is more adapted when the contour is continuously smooth.
                                  daloop
                                  Thanks for the tip, but I tried TGI3D. The Training Edition won't mesh my curves and there is no money for software in the budget for this project.
                                  Anyway, thanks for your great plugins and your support. I hope you will continue to develop them. An updated version of your Bezier tools would be nice. They are very powerful but can be a bit finnicky, handling-wise.
                                  • jgbJ Offline
                                    jgb
                                    I can show you many examples of its limitations and quirks. I'm sure you could too, if you use it a lot.
                                    The problem I wrote of is not really an example, in that the perimeter geometry is a user problem, not a CL problem. But how CL handles some perimeter problems does exemplify its "limitations and quirks".
                                    In that case, why would CL not skin a selected perimeter in-situ with other geometry, yet skin that EXACT same perimeter selection when copied away from any other geometry? Doesn't happen all the time, but not often enough to sense an underlying pattern.
                                    jgb
                                    • N Offline
                                      nilogog
                                      ...after a few hours trying to make it come up in Sketchup13, yes very happy!Fullscreen capture 24112013 111540 AM.bmp.jpg
                                      • fredo6F Offline
                                        NEW RELEASE: Curviloft v1.3a - 27 Nov 13
                                        Curviloft 1.3a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                          TheDevil
                                          Hey Fredo Wow Great Plug in but I am trying to make a ship Hull...kinda like your profile picture shows. since most people use the loft to the most in building ships or planes or cars to name a few can you show a tutorial or maybe even explain how one would make a ship hull for say like a pirate ship...anyway good tutorials still tryng to figure out the plugin
                                          • jgbJ Offline
                                            jgb
                                            It really all boils down to what you have to define the curves needed to generate a loft.
                                            For a ship, you need to define the deck curve (waterlines), the keel curve (buttock lines) and at least 1 (preferably 2 or 3) curves defining the shape of the hull (station lines).
                                            Do a 1/2 hull only. When done, make the loft a component, then copy and flip it for the other side. That way edits to one side are reflected to the other side.
                                            Best practice is to make the 1/2 hull in 3 pieces. The bow section, the hull section, which is usually a straight extrusion for a "pirate ship" type hull, and then the stern section. Merge the 3 sections into one 1/2 hull.
                                            When you create the perimeter curves, pay extra attention to the endpoints where the 3 curves meet. They MUST be attached at the same endpoint. A "constrained" point will NOT loft.
                                            Try to maintain a very similar length of all the defining curve segments, or you will end up with a myriad of tiny triangles.
                                            If you need more help, post here again.
                                            jgb
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 65
                                            • 66
                                            • 39 / 66
