    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • cmeedC
      cmeed
      Hello Again - potential bug....
      I opened my work from last night this morning - a popup saying the new version was out - downloaded
      • closed layer panel (as nothing had changed) -
        -opened Layer panel again - could see there were new features - tried options, from the new pull down - nothing happened
      • tried new 'move selection to highlighted area' didn't seem to work
        -closed Su
        _open SU
      • opened layer Panel
        -All groups gone 😞
        Layers still present
      But
      'Options' and 'move selection to highlighted layer' now work as expected. and I'm supposing the rest works too
      (also when turning off render toolbar there's a big gap at the top.... suggest this render feature goes at the bottom no need to give such high status, you're going to use it for a short period while layers all the time....just a thought)
      No Big issue for me on this project as I've finished but you better see if anyone else has had a problem
      Keep up the great work - Fantastic plugin has changed my work flow tremendously
      -just thought about your 'move to selected layer' how about 'move and rename' mmmmm interesting - you might be stepping on 'rename by layer plugin' toes but maybe you could get together - they work as a great accompaniment
      c
      • cmeedC
        cmeed
        updating a scene using a shortcut (in my case 'p')with Layer Panel Open now works - great stuff
        Cheers
        c
        • jiminy-billy-bobJ
          jiminy-billy-bob
          @cmeed said:
          -All groups gone 😞
          This is a real problem πŸ˜• I'll need to add a debug mode so that users can check if groups are gone for good, or if there is just a bug displaying them. Could you send me the file ? (Even without geometry)
          I was able to reproduce that, it seems to be a CSS problem, I'll release a fix soon.
          Nope, Renderiza's plugin works great, no need to replicate the work πŸ˜„
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Cheers
            c
            Great ! Don't know what was causing that, but I'm glad you don't have the issue anymore.
            • jiminy-billy-bobJ
              jiminy-billy-bob
              Also, I see that the menu button is invisible on IE9, I'll try to fix it.
              • cmeedC
                cmeed
                Nope, Renderiza's plugin works great, no need to replicate the work πŸ˜„[/quote]
                all I'm saying is, ergonomically it would be better.... Thats all πŸ˜‰
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Can anyone confirm this ?
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    New version 0.5.1 beta !
                    Changelog :
                    • Fix gap at the top when hiding the render toolbar
                    Download in the plugin store !
                    • plesiosaurP
                      plesiosaur
                      Any plans to add Thea to the Render list? Thanks
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        @cmeed said:
                        -All groups gone 😞
                        The groups unique IDs are still present in your file, but they are not listed by Layers Panel serialized string. Don't know why...
                        Were layers still sorted, or did they revert back to Sketchup's default sorting ?
                        Did anyone else experienced this ?
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          See this :
                          Actually, if it works with Thea on day, it'll behave differently. You will probably have an option directly inside Thea allowing you to choose if you want to render with Layers Panel feature or not. But you won't render from within Layers Panel as you do with Vray/Maxwell/etc. This is due to the way Thea is designed. I can't trigger the render from my plugin.
                          I gave evrything to Tomasz to make it work, the ball is on his side now πŸ˜‰ So if you badly want this feature, you should get in touch with him !
                          πŸ˜„
                          • cmeedC
                            cmeed
                            @cmeed said:
                            -All groups gone 😞
                            The layers were not in any order.
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              Maybe the order they were created ? (Which is SU's default)
                              • ElibjrE
                                Elibjr
                                Any thought to adding Render[in], IRender-nXt or Shaderlight to the list? This is such a great plugin! Thank you for all your work.
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  Same case as Thea, I have to contact the developers.
                                  • Bob JamesB
                                    Bob James
                                    Any progress with regard to solving the problem with the interference with the saving of scenes?
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      Working on it πŸ˜‰
                                      • jiminy-billy-bobJ
                                        jiminy-billy-bob
                                        Bug found : When a group is moved to be nested in another group, we can't rename it. We have to restart Layers Panel.
                                        Working on a fix.
                                        • unclebimU
                                          unclebim
                                          Great plugin, I have integrated it immediately in my workflow. However I noticed following issues (bugs?):
                                          1. In SU 8 it displayed the outdated IE version message and did not allow the scroll. Since ver. 0.5 it does not display this message but only shows render engines in the window and no layers or layer groups at all. In SU 2013 this problem does not exist.
                                          2. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work when pasting a group/component from another SU file, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                                          Hope that helps.
                                          Thank you for your great plugin, it is so useful.
                                          • jiminy-billy-bobJ
                                            jiminy-billy-bob
                                            What's your IE version ?
                                            @unclebim said:
                                            1. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                                            Weird. Does it work when Layers Panel is installed but closed ?
                                            • 11
                                            • 33
                                            • 34
                                            • 9 / 34
