    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      New version 0.5.1 beta !
      Changelog :
      • Fix gap at the top when hiding the render toolbar
      Download in the plugin store !
      • plesiosaurP Offline
        plesiosaur
        Any plans to add Thea to the Render list? Thanks
          jiminy-billy-bob
          @cmeed said:
          -All groups gone 😞
          The groups unique IDs are still present in your file, but they are not listed by Layers Panel serialized string. Don't know why...
          Were layers still sorted, or did they revert back to Sketchup's default sorting ?
          Did anyone else experienced this ?
            jiminy-billy-bob
            See this :
            @jiminy-billy-bob said:
            Actually, if it works with Thea on day, it'll behave differently. You will probably have an option directly inside Thea allowing you to choose if you want to render with Layers Panel feature or not. But you won't render from within Layers Panel as you do with Vray/Maxwell/etc. This is due to the way Thea is designed. I can't trigger the render from my plugin.
            I gave evrything to Tomasz to make it work, the ball is on his side now πŸ˜‰ So if you badly want this feature, you should get in touch with him !
            πŸ˜„
            • cmeedC Offline
              cmeed
              @cmeed said:
              -All groups gone 😞
              The layers were not in any order.
                jiminy-billy-bob
                Maybe the order they were created ? (Which is SU's default)
                • ElibjrE Offline
                  Elibjr
                  Any thought to adding Render[in], IRender-nXt or Shaderlight to the list? This is such a great plugin! Thank you for all your work.
                    jiminy-billy-bob
                    Same case as Thea, I have to contact the developers.
                    • Bob JamesB Offline
                      Bob James
                      Any progress with regard to solving the problem with the interference with the saving of scenes?
                        jiminy-billy-bob
                        Working on it πŸ˜‰
                          jiminy-billy-bob
                          Bug found : When a group is moved to be nested in another group, we can't rename it. We have to restart Layers Panel.
                          Working on a fix.
                          • unclebimU Offline
                            unclebim
                            Great plugin, I have integrated it immediately in my workflow. However I noticed following issues (bugs?):
                            1. In SU 8 it displayed the outdated IE version message and did not allow the scroll. Since ver. 0.5 it does not display this message but only shows render engines in the window and no layers or layer groups at all. In SU 2013 this problem does not exist.
                            2. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work when pasting a group/component from another SU file, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                            Hope that helps.
                            Thank you for your great plugin, it is so useful.
                              jiminy-billy-bob
                              What's your IE version ?
                              @unclebim said:
                              1. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                              Weird. Does it work when Layers Panel is installed but closed ?
                                Bob James
                                This started happening for me after ver 0.5
                                • danchoD Offline
                                  dancho
                                  I was installed your plugin and it is nice how its work in new file, but with
                                  my actual project I can't see layer list with your plugin.
                                  Secont, will be fine that you can put a possibility to show/hide panel like old layer window, click on the top of window.
                                  Here is screen capture:
                                  THX
                                  Daniel
                                  old and new layer window
                                    jiminy-billy-bob
                                    All the time ? With all kind of objects ? Even when LP is closed ?
                                    I really don't see what could cause that... And I can't reproduce it.
                                      jiminy-billy-bob
                                      You're not the first to experience this.
                                      Could you send me the file by PM ? (Even with all the content deleted, keeping only the layers) The best would be a version of the file that was never saved since LP was installed.
                                      That's not possible, unfortunatly 😞
                                      • tt_suT Offline
                                        tt_su
                                        Workaround suggestion, size the window and leave a small clickable header in the HTML itself.
                                          jiminy-billy-bob
                                          I guess I could do that, thanks πŸ˜„
                                          But still not dockable, though
                                            jiminy-billy-bob
                                            Try to change scene.
                                            • 11
                                            • 33
                                            • 34
                                            • 9 / 34
