    Raising Curves
    7 Posts 3 Posters 566 Views 3 Watching
      Jarhead
      Hey guys,
      I haven't been able to find a solution to this (at least not a quick one)... If I have an offset set of curves that I want to create, say, a curb by raising up one of the curves, the triangulated face that are formed are generally very un-neat. I basically use road layouts I draw up in AutoCAD & then simply fill in the faces in SketchUp & drop the road down...
      Anyone know if this is easy as it gets, or is there a workaround, plugin, or area of my brain I can't seem to access πŸ‘Š
      Imagine a road with a lot of curves..... 😲
      What I basically start with
      How SketchUp interprets it
      I have to fill in/flip all the edges
      What I wanted in the first place
      • ely862meE
        ely862me
        I think there is a plugin that connects the edges/curves before you raise the geometry, that way it won't get messed up.
        That is a problem I am dealing with it too. Sometimes it helps if you connect the ends of the curves.
        Elisei (sketchupper)
        Come and See EliseiDesign
          TIG's Split Tools
          • ely862meE
            ely862me
            Yep, that seems to be it . Thanks , I've just installed it !
            Back to the initial point, you could also create/raise just the profiles and then connect them with Curviloft http://sketchucation.com/forums/viewtopic.php?p=248195#p248195 .
              Jarhead
              Thanks for the info guys. Rock star. I'll give the TIG-Split tools a try & let you know how it works out. http://sketchucation.com/forums/viewtopic.php?p=377338#p377338 Seems as though that would maybe work best? I create the outlines of my curbs in AutoCAD 1st, sometimes large road systems, so not sure how curviloft would react πŸ˜„
              Sample of extents of roads
                Jarhead
                Hey guys, turns out TIG's Split Donut works the best. If you have a "donut" road (really just a hole in the middle of any shape). Does it in seconds! 😍 Thanks for the help http://sketchucation.com/forums/viewtopic.php?p=386601#p386601 Great job TIG
                • ely862meE
                  ely862me
                  Yep, just with donuts, and same amount of segments, then it is useless . I tried curviloft with a larger model and it works ok .
