    Thea Render v1.3 Technology Preview (Teaser Trailer)
    extensions
    34 Posts 12 Posters 4.7k Views 12 Watching
    • N Offline
      notareal
      Heads up from Thea Render Technology Preview. Related forum topic is here.
      Dear friends,
      something big is on the way and that is our next edition v1.3 (codename: Presto Square or Presto^2 for short).
      And we have prepared a teaser trailer showing the improvements coming out! We simply cannot express how much excited
      and proud we feel and I believe that you can understand why, just by seeing the video.
      Best wishes
      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
      • Rich O BrienR Online
        Wow!
          Appetizing sushis! β˜€
          • soloS Offline
            Bloody awesome, I just cannot believe the pace of innovation from these guys.
              jaceguay
              Nice.
                lamandrion
                damn... i should have bought an nvidia card instead of ati...
                • N Offline
                  notareal
                  Well... It's always possible to sell it while it do have some valua and grab a GeForce GTX Titan card πŸ˜‰
                  • GarethG Offline
                    Gareth
                    That's because they are OCD, never sleep, and live in a strange world called the 'Mediterranean Triangle'......ships often go missing around there....!!
                    • soloS Offline
                      10 minutes gpu cpu, used radial blur 15% to get hazy look. BSD 25 tracing depth.
                      No post processing.
                      Thea 1.3 is amazingly fast, this is an interior, and they are normally slow to render, exteriors render in seconds to a couple of minutes.
                      • soloS Offline
                        Here is a test that will tax any render engine, true sub surface scattering kills render times, however the new engine GPU + CPU does it fast.
                        • N Offline
                          notareal
                          Some more news from Thea Technology Preview; Micro Roughness.
                          http://www.thearender.com/forum/viewtopic.php?f=17&t=13379&p=92671
                          Dear friends,
                          we start from the very last thing shown in our technology preview trailer. Micro Roughness! πŸ˜„
                          Let's start with a photo to see the phenomenon in real life:
                          What we perceive with the above image is that the reflections change with the viewing angle. While looking in front of the monitor, we see blurry reflections, looking from a shallow angle, the reflections are getting very sharp.
                          The phenomenon seen above is actually not having two expressions, one for normal viewing angle and one for shallow viewing angle. But instead, the reflections vary from blurred to sharp gradually as the viewing angle goes from normal to shallow. Here is a gif animated image, where the reflections gradually blur as the viewer moves further away (note the gif quality is not very good due to the compression of the format).
                          (Might require a click to view correctly)
                          An explanation of the phenomenon is related to the decrease of the apparent roughness as the viewer goes from normal to shallow viewing angle along with the presence of a very sharp reflection that becomes very strong at shallow angles.
                          Please, study further about this novel solution in Thea Render, with rendered example images at the related post http://www.thearender.com/forum/viewtopic.php?f=17&t=13379
                          • N Offline
                            notareal
                            More news from Thea Render 1.3 technology previews; Presto GPU SSS/Volumetrics Support
                            Dear friends,
                            one of the things most requested after publishing Presto v1.2 was sub-surface scattering (SSS) and volumetrics support.
                            To be honest, I had this as a relatively low priority for the things to be added in Presto. But I was persuaded at the end, that this is a first class feature that we should not be missing.
                            As you know, Thea unbiased core (TR1/TR2) gives volumetrics and SSS of highest accuracy. Initially, we thought of making use some approximation models for SSS for Presto, so that to deliver highest efficiency. But at the end, due to Presto being a progressive engine, and having already the experience to deliver the real SSS, we decided that realism is all that matters. And we were happy to find out that Presto delivers this realism very very fast.
                            Below, you can see some samples of scenery with one or more SSS materials. And we are talking about renders converged quickly, with the real thing, real SSS without approximations. The results should speak for themselves.
                            Best wishes
                            You can find GPU SSS/Volumetrics examples at related topic at Thea Render forum http://www.thearender.com/forum/viewtopic.php?f=17&t=13419
                            • soloS Offline
                              This one blows my mind still.
                              http://www.thearender.com/forum/download/file.php?id=18980
                              • marked001M Offline
                                marked001
                                Any recommendations on a mid-range Nvidia GPU?? $150ish maybe?
                                Currently, I've got an AMD Radeon HD 7570.
                                http://www.revision21vis.com
                                instagram: revi21on
                                • soloS Offline
                                  I'd suggest something like this, a little above your price but 3gb ram is good (more the better)
                                  Amazon.com: EVGA GeForce GTX 660 SUPERCLOCKED 3072MB GDDR5 DVI mHDMI Graphics Card 03G-P4-2666-KR : Electronics
                                  (www.amazon.com)
                                  http://ecx.images-amazon.com/images/I/81lYiMnmhPL._SL1500_.jpg
                                  • CarlohC Offline
                                    Carloh
                                    ummmmph....it get's harder and harder to choose. i don't know if i should make the maxwell upgrade to V3, or get thea 1.3 πŸ˜•
                                      marked001
                                      (www.amazon.com)
                                      How'd I know it was going to be more expensive πŸ˜„ thanks Pete...more ram the better, got it.
                                      instagram: revi21on
                                      • StinkieS Offline
                                        Stinkie
                                        Simply wait until the Maxwell V3 demo is out. Then test both apps extensively.
                                        • CarlohC Offline
                                          Carloh
                                          yes i guess that's the way to go...but i don't think that maxwell will improve its speed this much to compete against thea, and speed is a thing that always have been bothering me when working with maxwell.
                                          • CarlohC Offline
                                            Carloh
                                            I see that there was a nice discount at the release of version 1.2...will there be such a discount at the 1.3 release?
