    My first run of vray 1.6
    renderpluginsextensions
    27 Posts 10 Posters 4.4k Views 10 Watching
      timmyd2283
      i used vray 1.6 using my home computer. same model but i tried adjust the IEs settings to 150000 for intensity.. and thats the only time that it went brighter..
      • stefanqS Offline
        stefanq
        Guys, I love to use IES lights all the time, and I remember when it was hell to me to set-up v-ray. Spend many hours on the web, trying to find solutions. I got A hint on Nomeradona's awesome blog, where it was something about units. The long-short story is, I work in mm, but when I'm using IES lights, just before I hit the render button, I switch the sketchup units to inches. I don't touch the IES parameters. Everything looks correct.
        Here is an example:
          cuttingedge
          really nice render there Stefanq.. and the IES effect is really effective.
            jackwatson
            @valerostudio said:
            Domelight Tips-
            Hi guys,
            I've tried switching off the GI and BI, and bringing the gamma of the domelight map down to 0.75 but am still having some trouble with lighting. The shadows are still quite weak and behave strangely as you can see around the fence and on the grass on the right hand side.
            Any ideas what's going on would be a great help. Thank!
            Here's the image with gamma set to 1.0
            And here's with gamma set to 0.75
            Using a hdri from peter guthrie
            EDIT:
            The only thing I can think of doing is rendering a version using GI/BI set up to cast the shadows I want, check override materials, and add the result as a layer in photoshop with 'multiply' setting to create the shadows I want - but obviously less post-production is better ^^
            • V Offline
              valerostudio
              There is no need to do that. Which Gunthrie HDRI are you using? If the sun is hidden behind clouds, then this is an overcast HDRI and will no produce a direct shadow, just like real life. Try the HDRI I sent a link to, this worked perfectly for me. If you get the same issue with this HDRI, then I can look at your file.
                jackwatson
                I was using the HDRI called "1808 Blue Sky White Clouds", where the sun is very visible but there is some cloud. Also the sun is quite low so maybe this is having an effect too. Switching to the other HDRI did make a big difference. Thanks for all the help - you seem to be answering my posts left, right and centre! Hero!
                • V Offline
                  valerostudio
                  That file looks like it should be fine. You're using a hi-res unblurred version?
                  • V Offline
                    valerostudio
                    Make sure the rotation of the HDRI texture is setup so that the sun is casting on your facade. Post a screenshot of your HDRI and dome light settings if you can.
                      cuttingedge
                      Here is an example:
                      Is Vray still on inches by default? Will it not adjust automatically, when you change units.
                      The solution you shared here is fine, but once I need to revise the model, I have to again go back to my mm settings in order to be precise. and then switch back to inches again to do a test render. That sounds more than a little inconvenient.
                      • dkendigD Offline
                        dkendig
                        I thought we had fixed that...
                        Devin Kendig
                        Developer
                        • 2 / 2
