    What's your beginners tip?
    305 Posts 169 Posters 352.0k Views 169 Watching
    • ariesmarzA Offline
      ariesmarz
      @gaieus said:
      Here maybe? http://www.chaosgroup.com/en/2/downloads.html?s=v-ray-sketchup
      (need to be registered and logged in)
      Thank you sir
      • BlastfurnaceB Offline
        Blastfurnace
        This may be hard to explain but a little known tip I use is what I call "move without selection" It works on cylinders to make cones...
        Draw a circle.
        Pull it up into a cylinder.
        Rotate so you can see the top.
        Now with nothing selected choose the MOVE tool
        Now hover your tool around the top edge.
        If the edge turns blue you are NOT on a cardinal point and if you move, the circle will move in the direction you move it.
        BUT if your point is there as an endpoint and the circle is NOT blue you ARE on a cardinal point.
        Moving from there causes the circle to get smaller or larger.
        i use this method to make cones rapidly.
          That's scaling with Cardinal Points and it is is both handy and it seems, little known. You won't get a perfect cone but it'll be close. It works for polygons, too.
            Blastfurnace
            Scaling with cardinal points is certainly a more accurate term than mine. πŸ˜„ Wanna try something difficult? Try to find it explained without knowing what its called! Takes a bit of googling.
            i didn't know about the polygon part. I'll have to play with that.
            M
            • dukejazzD Offline
              dukejazz
              Tip_dj no 15
              Plugins - InputBox type
              The opening of a ruby plug-in with a InputBox usually opens in the center of SU window.
              But if you open a sub window of SU like Outliner and select the top bar.
              Then running a plug-in with a InputBox again, now center on the sub window of the outliner
              Why is this important to know?
              Some times a plug-in cover up what you need to see especially a large InputBox
              πŸ˜› -dj
                jerrymich
                Best tip came from Dave R. (moderator). Change your styles to where the back face is a contrasting color, i.e. green or something similar to make it much easier to see when you have faces that are reversed. Thanks Dave.
                • mortenstorgaardM Offline
                  mortenstorgaard
                  @chris fullmer said:
                  Always use a 3 button mouse with SketchUp. None of those single button Mac mice....stupidest invention ever.
                  And use shortcut keys.
                  Thanks πŸ˜„ love my mac stuff, but guess youre right πŸ˜„ πŸ˜•
                  Morten
                  //nordiskspil boardgames
                    local
                    Hi!
                    How can I size an angle formed by two lines?
                    There is this video?
                    (Sorry, google translator)
                    • Rafferty94R Offline
                      Rafferty94
                      @local do you mean how to measure the angle between two lines?
                        local
                        Can be measured by the 'Protractor' tools, but is not scaled.
                          Rafferty94
                          Measure using the protractor and then using the rotate tool, rotate the line you wish to move around to match the construction line given by the protractor tool? :-S
                            local
                            It's Okay.
                            How to scaled (Dimensions)?
                              local
                              In AutoCAD:
                                Rafferty94
                                Anyone can jump in on this but I don't think there is a way to input angle dimensions in SU.
                                Chris Fullmer has created a free plugin called ShapeBender that seems quite good at shaping text to a curve or arc.
                                If whatever you need this for is just going to be used to see the dimension then I would suggest drawing and arc between the two points and then curving the text (The dimensions of the angle) to the curve.
                                http://sketchucation.com/forums/viewtopic.php?f=180&t=18210&st=0&sk=t&sd=a&hilit=bender
                                  local
                                  I understand. I think there is a faster way.
                                  thanks
                                  • BoxB Offline
                                    There is an Angular Dimension tool available.
                                    http://sketchucation.com/forums/viewtopic.php?p=376893#p376893
                                      CL
                                      My tip would be to make sure you know what scale you are working in. If you start with something downloaded from the warehouse that is a random size, everything else can go pearshaped. You start adjusting things by eye to look right and then find there is nothing you can actually put a tapemeasure on, no known dimensions.
                                      • GarethG Offline
                                        Gareth
                                        My tip is :
                                        Be patient, or become one...!
                                        • dlscapeD Offline
                                          dlscape
                                          I've tried reading through a lot of these "Beginners Tips" posts, but there are a LOT, so please excuse me if this has already been posted...
                                          Imagine you want to delete a large number of small objects, like the segments to a curved line for example. If they are isolated from other parts of your model it's easy to group select and mass delete. If they are tucked away amongst other objects it can get pretty tedious clicking each one with the eraser tool or trying to select and hide the rest of your model.
                                          My tip is; did you know you can click and hold the eraser tool to paint multiple objects, easily selecting lots of fiddly objects, then when you release the mouse button they all delete πŸ˜„
                                          This has saved me thousands of mouse clicks cleaning up models, I hope it does the same for you!
                                          Merry Christmas!
                                          James
                                            billkeck
                                            After creating your first object learn the value of placing it within a container (group or component).
                                            • 15
                                            • 16
                                            • 4 / 16
