    What's your beginners tip?
    305 Posts 169 Posters 421.8k Views 169 Watching
    • dukejazzD Offline
      dukejazz
      Tip_dj no 15
      Plugins - InputBox type
      The opening of a ruby plug-in with a InputBox usually opens in the center of SU window.
      But if you open a sub window of SU like Outliner and select the top bar.
      Then running a plug-in with a InputBox again, now center on the sub window of the outliner
      Why is this important to know?
      Some times a plug-in cover up what you need to see especially a large InputBox
      😛 -dj
        jerrymich
        Best tip came from Dave R. (moderator). Change your styles to where the back face is a contrasting color, i.e. green or something similar to make it much easier to see when you have faces that are reversed. Thanks Dave.
        • mortenstorgaardM Offline
          mortenstorgaard
          @chris fullmer said:
          Always use a 3 button mouse with SketchUp. None of those single button Mac mice....stupidest invention ever.
          And use shortcut keys.
          Thanks 😄 love my mac stuff, but guess youre right 😄 😕
          Morten
          //nordiskspil boardgames
            local
            Hi!
            How can I size an angle formed by two lines?
            There is this video?
            (Sorry, google translator)
            • Rafferty94R Offline
              Rafferty94
              @local do you mean how to measure the angle between two lines?
                local
                Can be measured by the 'Protractor' tools, but is not scaled.
                  Rafferty94
                  Measure using the protractor and then using the rotate tool, rotate the line you wish to move around to match the construction line given by the protractor tool? :-S
                    local
                    It's Okay.
                    How to scaled (Dimensions)?
                      local
                      In AutoCAD:
                        Rafferty94
                        Anyone can jump in on this but I don't think there is a way to input angle dimensions in SU.
                        Chris Fullmer has created a free plugin called ShapeBender that seems quite good at shaping text to a curve or arc.
                        If whatever you need this for is just going to be used to see the dimension then I would suggest drawing and arc between the two points and then curving the text (The dimensions of the angle) to the curve.
                        404 Not Found
                        (sketchucation.com)
                          local
                          I understand. I think there is a faster way.
                          thanks
                          • BoxB Offline
                            There is an Angular Dimension tool available.
                            http://sketchucation.com/forums/viewtopic.php?p=376893#p376893
                              CL
                              My tip would be to make sure you know what scale you are working in. If you start with something downloaded from the warehouse that is a random size, everything else can go pearshaped. You start adjusting things by eye to look right and then find there is nothing you can actually put a tapemeasure on, no known dimensions.
                              • GarethG Offline
                                Gareth
                                My tip is :
                                Be patient, or become one...!
                                • dlscapeD Offline
                                  dlscape
                                  I've tried reading through a lot of these "Beginners Tips" posts, but there are a LOT, so please excuse me if this has already been posted...
                                  Imagine you want to delete a large number of small objects, like the segments to a curved line for example. If they are isolated from other parts of your model it's easy to group select and mass delete. If they are tucked away amongst other objects it can get pretty tedious clicking each one with the eraser tool or trying to select and hide the rest of your model.
                                  My tip is; did you know you can click and hold the eraser tool to paint multiple objects, easily selecting lots of fiddly objects, then when you release the mouse button they all delete 😄
                                  This has saved me thousands of mouse clicks cleaning up models, I hope it does the same for you!
                                  Merry Christmas!
                                  James
                                    billkeck
                                    After creating your first object learn the value of placing it within a container (group or component).
                                    • DanielD Offline
                                      Daniel
                                      I would suggest always working at full scale. If you download something from the warehouse that is not sized properly (been there!), resize it the best you can to make it so (done that!).
                                      My avatar is an anachronism.
                                      • BoxB Offline
                                        Full scale isn't always correct, for example if you are making parts for a watch or something very small it pays to work at a larger scale to avoid the tiny face issue and scale down when complete.
                                        • Phillip HP Offline
                                          Phillip H
                                          To be filed under, "The blind leading the blind"; a beginner's advice to beginners.
                                          Having started learning SU solo, a very trial and error approach (mostly error), I found I spent more time fixing mistakes than I did on modeling or learning 'best practices'. My tip is simply this: Learn from the people who have gone before you. Stick to the basics first. Actually DO the tip or exercise you read. Rinse and repeat as necessary. Knowing is doing and doing is knowing. Your skill level will advance much more quickly if you do. Mine certainly has.
                                          As I post this, I am going back through my models and applying what I have learned here. My hat is off to you SketchUcation instructors and old hands. Lot of good stuff on these pages. Thank you for your contributions.
                                          Phillip
                                          HP EliteBook 8440p Intel® Dual Core™ i7 M620@ 2.67 4GB RAM
                                          NVIDIA NVS 3100, 512 MB
                                          Windows® 8.1 64 bit
                                          SketchUp Pro 2015 version 15.3.331 64-bit
                                          • HornOxxH Offline
                                            HornOxx
                                            next playing around and having fun:
                                            if you make a model, never use Layer 0 !!!
                                            never trust a skinny cook
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
