    Curviloft (Beta) Plugin Tutorial
    45 Posts 21 Posters 60.6k Views 21 Watching
    • brookefoxB Offline
      brookefox
      When I've got the transitions previewed (in black), I find I am unable to orbit to really inspect the thing (like you do, Rich, in your demo tuts). If I try the operation is cancelled. Is there a secret?
      ~ Brooke
        lapx
        Charly,
        I have an irregular column shape I'm trying to make using curviloft. Stitching the circle and the shapes together should have worked but it did not. Do the segments on each shape have to be equal in number?
        also the top of the planter is not flat it should be from with a curve in the z plane. Not certain how I would construct this.
        How can this be done? See attached skp file.
        column.skp
          Lapx
          Is this the result you seek?
          Select the three 'profiles' of edges and run CurviLoft.
          The initial result might be somewhat twisted, because the top circle's 'start' is rotated relative the the 'starts' of the other curves... but you can easily relocate that point around the curve in the tool.... before committing to the form...
            brookefox
            The start point may not matter depending on the Vx setting.
            Note the black previews which if I orbit during, causes the whole operation to be discarded.
            The first pics show 1,2,3 from the bottom up.
            Here from the top down.
            ~ Brooke
            • micioneM Offline
              micione
              Hi all,
              Watching this tutorial, I found the window (red arrow) in the photo.
              Does anybody know tell me the path to find it?
              Thanks in advance
              • micioneM Offline
                micione
                Sorry,
                photo.
                • charly2008C Offline
                  charly2008
                  Hi Roberto,
                  you will find it in the Tools menu.
                  Charly
                  • micioneM Offline
                    micione
                    Charly,
                    Thank you very much.
                    (I tried to send a private message, but evidently you have not received).
                      ccs1987
                      Awesome tutorials
                      Sketchup 8 pro
                      Vray
                      Intel Xeon W3520 2.67Ghz
                      12Gb Ram
                      Nvdia Quadro FX 1800
                      • LanaL Offline
                        Lana
                        Very good . I learned a lot here . Thank you all .
                        • sketchartist023S Offline
                          sketchartist023
                          I have not been able to manipulate the GUI interface with this tool, so I am left with overlapping issues in my model 😕 I am not sure what to do, but wow this tool is amazing so far! My concept is taking a plane lettering and then using a half circle guide flow to reform it to a rectangle below the lettering facing the same direction. SO, just a morphed half loop from letter to poly. But always get overlapping and face issues since I cannot use the points on the GUI. I wish I could do this stuff above! Will keep trying 😄
                            If you'd like help, upload an example SKP file so we can see what you are trying to do.
                            • 3 / 3
