    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.6k Views 109 Watching
    • cmeedC Offline
      cmeed
      @jiminy-billy-bob said:
      When you had the problem, did you restart sketchup after installing the plugin ?
      If you manage to reproduce the bug, I would be glad if you gave me the intructions.
      Yes i restarted - they didn't appear right away! they appeared after i'd worked on the model for a bit. then i noticed. I'll keep my eyes open when next time the occasion crops up.
      Great to see this Plugin. especially the "add layer visible only in this scene" - touch!!
      c
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        If you have an old copy of the file that you didn't open after you installed Layers Panel, it would be great if you could PM it to me πŸ˜„
        • cmeedC Offline
          cmeed
          I've just had a bugsplat - was it from this plugin? its new on my computer..... also new, the latest version of su was downloaded this morning
          the major thing is i can't open the file now. "unexpected file format"!!!! Any Help?
          arrgh
          c
            jiminy-billy-bob
            Did you try disabling/uninstalling the plugin ?
            • cmeedC Offline
              cmeed
              everything was working well (the group names was the only thing) I was working inside a group outliner was open and then i got the bugsplat. I dont normally get bugsplats so its funny.
              I didn't uninstall or do anything witht the plugin.
              did you mean to uninstall it and try opening the files? as I've tried opening themon my Mac (no "Layers {abel" plugin) and still not luck - It happened on my pc
              opening .skb and .skp result with Unexpected file format.
              • kenK Offline
                ken
                I have had the same problem as cmeed. The unexpected file format. Luckily for me I had a backup or I would have lost the file.
                Note, I have the plugin TIG: Archiver v2.0 which is a life saver.
                http://sketchucation.com/forums/viewtopic.php?p=149749#p149749
                Thanks for your plugin.
                Ken
                  jiminy-billy-bob
                  Holy sh...
                  I'll try to reproduce the bug. That's a big problem if it corrupts files... πŸ˜• I'm so sorry, I hope you didn't lose your work.
                  I'll add a warning in the first post.
                    jiminy-billy-bob
                    cmeed, can you check if you still have the dump/log files produced by the bugsplat ?
                    • cmeedC Offline
                      cmeed
                      I have started again (this time with archiver as cover)
                      c
                      • ElibjrE Offline
                        Elibjr
                        Oh wow, this is truly a nice plugin. I wished that the standard layers toolbar worked this way. Now I want to install in on both my laptop and the desktop machine. This is one of the cleanest plugins I have used. Great work Jiminy. My top 10 now.
                        Elibjr
                          Ben Ritter
                          I appreciate your generosity in sharing this plugin
                            jiminy-billy-bob
                            Thanks everybody for your kind words, comments and feedback ! I really appriciate it.
                            • kenK Offline
                              ken
                              I have 4 layers that are in my template. I wanted to get this under a group, so I could turn all the layers off at once. They are xlines, markcenter, workplane and cline. When I try saving a template file, I get unexpected file format and the program closes. On trying to open Sketchup again, I get the failed to open template file. Sketchup open but not with the template file that I saved.
                              However, when I open the standby template file, saved as a regular file, and then try to save this file as a template with the name I used above, I get the file exist and do you wish to over write the file. So something was saved.
                              Just trying to keep you abreast.
                              Ken
                                jiminy-billy-bob
                                Thanks Ken, I'll look into that.
                                  jiminy-billy-bob
                                  New version 0.3.1 beta !
                                  Changelog :
                                  • Fix group names disappearing
                                  Download in the plugin store !
                                    jiminy-billy-bob
                                    Ken, were these 4 layers created before you installed the plugin ? What happen when you create a new file, create the same layers, and try to save it as template ?
                                    If you find a way to reproduce the bug every time, that would be really great ! πŸ˜„ I could propably debug this
                                    • kenK Offline
                                      ken
                                      Well OK, I noticed that there were other versions of this plugin in my plugin folder. So I deleted all files associated with this plugin and did a re-install. It now appears to be working. I can save a template file, and re-open and have the four layers still there and in the group I added.
                                      Hope this helps.
                                      Ken
                                      • X Offline
                                        xkalvisx
                                        I hope you have ever done:
                                        Group - visible
                                        Group - invisible
                                        Should operate in a single click
                                        Thank you
                                          jiminy-billy-bob
                                          What do you mean ? You can already hide/show groups with a single click.
                                            jiminy-billy-bob
                                            Hope this helps.
                                            Ken
                                            Great ! I'm glad it works now.
                                            But did you have the corrupt template multiple times ? I mean, was it just one time or was it systematic ?
                                            EDIT : When you say you had multiple versions installed, was it a beta (layer_panel.rb) and an old alpha version (Layers Panel.rb) ? Otherwise, I don't understand how you can have multiple versions
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 33
                                            • 34
                                            • 15 / 34
