    Yellowish Strange arcs in exterior render
    renderpluginsextensions
    6 Posts 5 Posters 590 Views 5 Watching
      mostafa999
      Hi all I noticed when I render an exterior scene I get some yellowish arcs in areas with indirect light, I have attached two pics 1R&2R, 1R is the original render, 2R I put the original image on photoshop and increased colour vibrance to see the effect better
      Original
      Increased the colour vibrance in photoshop so you can see the effect clearly
        What rendering app?
          mostafa999
          @dave r said:
          What rendering app?
          vray sketchup, Adaptive DMC image sampler, irradiance Primary engine, light cache secondary engine
            Gwint
            I have the same problem ...http://sketchucation.com/forums/viewtopic.php?f=322&t=53929
            • andybotA Offline
              andybot
              change the color of your box to a light gray. Vray will have difficulty with pure white color.
              Also do realize that there are only 256 levels of gray (in the 8bit RGB color space), so if you increase the contrast in an image like that, you will start to see the transition between different levels of gray.
              • dcauldwellD Offline
                dcauldwell
                To me this looks like jpg artifacts. Outputting as a png file should see that 'rainbow' shading disappear.
                David
                Sketchup 2017
                (vray 2.00)
