    Question about Faces in SketchUp?
    3 Posts 3 Posters 309 Views 3 Watching
      bob-designer
      1.The face on component 1 is touching or interfacing with the face on
      component 2.
      2.The face on component 2 covers the whole face of component 1 and it will not
      be visable on the finished model.
      3.I usually delete the touching face on component 1 where it interfaces with
      component 2.
      4.I delete faces where this condition happens in order to reduce the number
      of face as it relates to rendering.
      5.Is this a good procedure? I also delete the faces to stop the "flashing"
      caused by two faces interfaceing with each other.
      Thanks for your help, Bob
        Will be normal with a "single" object, but very curious with different Components because a component without a face will be "no solid" so maybe some problem !
        Delete double faces of a component is normal (there is plugins for that !
        Clean Up by Thomthom and remove internal faces by Wikii
          If you are applying flat components onto faces then you will get 'z-fighting'.
          Give the component correctly oriented axes and gluing/cutting behavior - it them 'removes' the face behind it, even as you move the instance...
          If you are applying it onto a face that is inside another component or group it cannot cut, so 'z-fighting' reappears.
          An Image never 'z-fights' even when applied onto another face directly.
          Depending on your object could a rectangular image be used inside the component definition ?
