    3D Max file to Sketchup?
    14 Posts 7 Posters 39.1k Views 7 Watching
      bhbarchitects
      You can import .obj into sketchup using a plugin.
      Never tried importing more than non textured image
      • Z Offline
        Zylescozar19
        What plug-in is that?
        • KrisidiousK Offline
          Krisidious
          get the sketchucation plugin installer and it will have one from Tig and one from some other place if you just search in the installer box for .obj
          By: Kristoff Rand
            Krisidious
            404 Not Found
            (sketchucation.com)
            By: Kristoff Rand
            • Z Offline
              Zylescozar19
              Already downloaded the .obj importer plugin but it does only imported a obj. file not a max.
              I also know that max can export a .obj file but i dont have max to do that. So i need to find alternative way to import a 3d files that i have into sketchup.
              I have problem here. (see attached) Importing 3d files lack of materials? ❓
              is there any solution to solve this?
              from 3D Studio Model this is the image
              Imported to sketchup
              • andybotA Offline
                andybot
                @zylescozar19 said:
                Hello guys,
                Does anyone knows how to import 3d max file to sketchup?
                As i know Sketchup can export 3d files. But Does it import 3d max files too?
                Any solution for this?
                Thank you in advance.
                Godspeed SketchUcation. β˜€
                .max files you will have to open in 3DStudio and convert to either 3ds or obj. There is no way to directly convert .max files into SU afaik.
                • andybotA Offline
                  andybot
                  Re: .max file per my above response.
                  For the texture - just use the texture to backfaces tool that's part of thomthom's uv toolkit. Then the tree model will look as it should.
                  Also, when you select all the leaves, you can hide just the edges so you only see faces. Again, another useful plugin for that is TT's selection toys πŸ˜„
                  • Z Offline
                    Zylescozar19
                    Another problem here Importing 3d files causes object to disarrange ❓
                    images ref. 3d file
                    imported to sketchup
                    • andybotA Offline
                      andybot
                      yup, happens 😞
                      I wish there was a direct solution, but I haven't seen it.
                      (Or if there are not too many pieces off in space, just fix it in SU.)
                      edit: nevermind about Blender, it depends on the file. If anyone knows of a surefire way to fix a 3ds file, would love to hear about it too. πŸ˜•
                      • Z Offline
                        Zylescozar19
                        Thanks andy for the reply. Already solve this problem.
                          Macho3001
                          Dear Zylescozar
                          Could you please mention how you solved the disarranged problem? I am facing this severely and could use any help from you/ anyone else. Many thanks in advance.
                          Macho3001
                          3DADS
                          'Leadership, by Design'
                          3rd Dimension, Architecture Design Studio
                          • N Offline
                            numerobis
                            You could try "Reset XForm". This should normally solve the problem of displaced geometry.
                            https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/3DSMax/files/GUID-B98414B9-4F28-45F4-A1F4-9DA994548ED9-htm.html
                              cheriyan
                              If you have 3ds max installed you can install a plugin called SketchUp exporter for 3ds Max. With this you can convert your .max file to .skp file with all textures. For reference kindly check this link, http://www.simlab-soft.com/3d-plugins/SketchUp-from-3DS-main.aspx315
