    ⌛ Sale Ending | 30% Off Profile Builder 4 ends 30th September
    3D Max file to Sketchup?
    14 Posts 7 Posters 38.4k Views 7 Watching
    • Z Offline
      Zylescozar19
      Hello guys,
      Does anyone knows how to import 3d max file to sketchup?
      As i know Sketchup can export 3d files. But Does it import 3d max files too?
      Any solution for this?
      Thank you in advance.
      Godspeed SketchUcation. ☀
        bhbarchitects
        You can import .obj into sketchup using a plugin.
        Never tried importing more than non textured image
        • Z Offline
          Zylescozar19
          What plug-in is that?
          • KrisidiousK Offline
            Krisidious
            get the sketchucation plugin installer and it will have one from Tig and one from some other place if you just search in the installer box for .obj
            By: Kristoff Rand
              Krisidious
              Plugin Store Download | SketchUcation
              Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
              (sketchucation.com)
              By: Kristoff Rand
              • Z Offline
                Zylescozar19
                Already downloaded the .obj importer plugin but it does only imported a obj. file not a max.
                I also know that max can export a .obj file but i dont have max to do that. So i need to find alternative way to import a 3d files that i have into sketchup.
                I have problem here. (see attached) Importing 3d files lack of materials? ❓
                is there any solution to solve this?
                from 3D Studio Model this is the image
                Imported to sketchup
                • andybotA Offline
                  andybot
                  @zylescozar19 said:
                  Hello guys,
                  .max files you will have to open in 3DStudio and convert to either 3ds or obj. There is no way to directly convert .max files into SU afaik.
                  • andybotA Offline
                    andybot
                    Re: .max file per my above response.
                    For the texture - just use the texture to backfaces tool that's part of thomthom's uv toolkit. Then the tree model will look as it should.
                    Also, when you select all the leaves, you can hide just the edges so you only see faces. Again, another useful plugin for that is TT's selection toys 😄
                    • Z Offline
                      Zylescozar19
                      Another problem here Importing 3d files causes object to disarrange ❓
                      images ref. 3d file
                      imported to sketchup
                      • andybotA Offline
                        andybot
                        yup, happens 😞
                        I wish there was a direct solution, but I haven't seen it.
                        (Or if there are not too many pieces off in space, just fix it in SU.)
                        edit: nevermind about Blender, it depends on the file. If anyone knows of a surefire way to fix a 3ds file, would love to hear about it too. 😕
                        • Z Offline
                          Zylescozar19
                          Thanks andy for the reply. Already solve this problem.
                            Macho3001
                            Dear Zylescozar
                            Could you please mention how you solved the disarranged problem? I am facing this severely and could use any help from you/ anyone else. Many thanks in advance.
                            Macho3001
                            3DADS
                            'Leadership, by Design'
                            3rd Dimension, Architecture Design Studio
                            • N Offline
                              numerobis
                              You could try "Reset XForm". This should normally solve the problem of displaced geometry.
                              Error
                              (knowledge.autodesk.com)
                                cheriyan
                                If you have 3ds max installed you can install a plugin called SketchUp exporter for 3ds Max. With this you can convert your .max file to .skp file with all textures. For reference kindly check this link, http://www.simlab-soft.com/3d-plugins/SketchUp-from-3DS-main.aspx315
