    SketchyPhysics 3.2 Need bug reports!
    36 Posts 24 Posters 19.3k Views 24 Watching
    • Y Offline
      yonic
      Uh... well... I used SP for 2 years... but now that I donwloaded the new version of SP, I founded a bug...
      On SketchUp 8 Pro, when I use the Joint Connector, in SketchyPhysics 3.2, the cursor turns white somehow, when it should be black. When I hold the CTRL key the plus (+) mark does not appear near the cursor...
      And so, connecting joints don't work anymore.
      I tried to follow the message of NotSoNaff, but nothing works.
        Don East
        Is there a fix for SketchyPhysics 3.2 so it will run on a computer that says you need 3.2. Every time I load 3.2 it shows that I still have 3.1. I finally have created a car with motors attached to each wheel. This model will move in a straight line and I can successfully change speeds of the motors. However whenever I ad another function i.e. a hinge on the front wheels to have the car turn, the model falls apart. It appears that adding any new functions to the successful moving model just negates the first setup. Where can I find good tutorials for the use of this program. I've seen amazing videos of models doing great things with SketchyPhysics i.e. a jeep traveling across ruff terrain. I would like to master these things. Please help.
        Don
        http://sketchupbydawn.blogspot.com/
          tspco
          Hi Don, OK when you add another ie a hinge so a car turns, first thing is don't use a hinge use a servo. What I did at first, was hit all the tutorials I could find, and get other people's models from the warehouse, take them apart see what makes them "tick".
          I have done OK, using this procedure. there is one tutorial in particular, that helped me out immensely. look at this.
          http://www.youtube.com/watch?v=71NlDJlA9S0
          watch this perhaps even save it and watch it again, when needed.
          This video will get you started.
          Let me know if I can help you out.
          SU make 2017, /Twilight Render Hobby
          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
            Don East
            tspco, I have been working with the YouTube video you listed. An it's the one I'm having the problems following. It works fine until I put on the servo and then the model falls apart. It's like the servo planed over the other hinge or motor just negates all the previous setup. Any thoughts?
            Don
              tspco
              in this case the hinges are grouped to the boxes, servos are connected to boxes, then the rear motors and the servos are grouped to the body, then it "should work". please note the difference between grouped and connected.PM me for more
              just a thought, grouping the motors and servos to the body should be the last thing you do before running the simulation. If it works great if not post your model to me in a pm and I will try to troubleshoot it. just the skp please. SP is a tough one to learn what is connected to what and what is connected to what. Again pleaase PM me for more that way this thread stays as it was OK
              • DesertRavenD Offline
                DesertRaven
                Hey Chris are you still out there? Never found an answer about the error message in this thread!?
                simplicity is the ultimate sophistication
                • Dan RathbunD Offline
                  Dan Rathbun
                  Chris..
                  there appear to be at least 117 issues logged,... none have been acknowledged that I can see.
                  Google Code Archive - Long-term storage for Google Code Project Hosting.
                  (code.google.com)
                  I'm not here much anymore.
                  • Bryan KB Offline
                    I've lost the joint tools.
                      aldenkr
                      I have been having a repeating problem when playing sketchyphysics, it will play for a short time then I receive Microsoft visual c++ runtime error, has requested a shut down in an unusual way contact applications providers for update. This the only time I receive this error, that is only when sketchyphysics is running or trying to. no other applications have this problem.
                      Is there any answers or suggestions
                      Help please
                      • jojo9J Offline
                        jojo9
                        i get following errors with the last version 3.2 (Dec, Mac)
                        what for a symbol? i found no corresponding files in my Sketchy Physics folder
                        always the same Reset dialog, when i push reset
                        start position, with everything (simple hinge joint) correctly aligned
                        strange out-balanced end position, when i simply push Play/Pause. I have to put my car in a 45 degr. position so that everything works correctly.
                        • 2 / 2
