    We need spellcheck for Layout!
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    10 Posts 6 Posters 24.3k Views 6 Watching
    • davidmreinboldD Offline
      davidmreinbold
      Has anyone ever wondered why the largest software company in the world which extensively relies on accurate spelling has not included a spellchecker in its own design software Layout? Can't be that hard to implement I imagine!?! There is nothing worse than printing of an entire set of plan documentation only to find a small spello within the title block on every page....
      We need spell check for Windows Users...please!**
      I hope that the Trimblers will be able to finally fix it.
      Cheers
      David
        Anton_S
        Hello,
        I use latest notepad++ and it can spell-check your script. It's also good at trimming trailing space and turning tabs to space.
        In Google Chrome I use spell cheking extention to correct my errors in posts.
          davidmreinbold
          I haven't really spelled it out correctly...we need spell check specifically for Layout!
          • TIGT Online
            I think it would be a good idea in principle... but for all locales ?
            If you prepare your standard notes in a wordprocessor [RTF] that's likely to include a spell-checker...
            OR on windows I also use AutoHotKeys which corrects common misspelling as you type, in ANY application...
            • KrisidiousK Offline
              Krisidious
              WHATCHU TALKIN BOUT WILLIS? Now I gotta go research this.
              By: Kristoff Rand
              • TIGT Online
                Get AutoHoyKeys from http://www.autohotkey.com/ - download and install.
                Put the folder [made form the attached ZIP] into say 'My Documents'... then shortcut the two .ahk files into your StartUp folder, and restart your PC.
                Now you'll get WinKey+Delete to empty the RecycleBin without a prompt AND better still AutoCorrect to fix out any common misspelling in any app... You can adjust the text-list to suit your needs...
                AutoHotKeys.zip
                  Krisidious
                  AWESOME...
                  By: Kristoff Rand
                    davidmreinbold
                    Thanks Tig & Krisidious
                    Just had a look at Autohotkey. However I decided to go with a nifty little software (644kb) called TinySpell.
                    This is a great "as-you-type" correction tool which automatically learns from your mistakes adding your preferred corrections to a windows wide dictionary that applies to all programs and browsers. It is very customizable too... see screen shot.
                    Custom Settings
                    have attached a trial zip, which can be unlocked for U$10, well worth it...it's a keeper! 😍
                    I still think an inbuilt spell check within Layout is a must.
                    Thanks again for putting the heads together on this.
                    tisp+1944.zip
                    • mwdsM Offline
                      mwds
                      This is an older subject but still relevant today; Please, an integrated spell check for Layout.
                      • LinearGraphsL Offline
                        LinearGraphs
                        [attachment=0:ti2qux0b]<!-- ia0 -->ScreenShot Tiny spell.jpg<!-- ia0 -->[/attachment:ti2qux0b]
                        How did you make it work in Layout?
