    Plugin for Wires, Cables, Ropes, Strings, Etc?
    17 Posts 9 Posters 14.5k Views 9 Watching
    • sdmitchS
      sdmitch
      just what does this "stringy, ropey, cable-y etc type geometry" look like. Please post a picture or model illustrating them.
      http://sdmitch.blogspot.com/
        Just take any section 😉
        http://www.polyloop.net/attachment.php?attachmentid=31353&d=1278260573
          Memory Clone can also help you 😉
          here a base module Rotate * 9 ° and move 20
          At each click you make a new level 😉
          • K
            Kanastrous
            Thanks! Just getting into working with curviloft now, which looks very useful. Advice and images much appreciated.
            • KrisidiousK
              Krisidious
              Catenary curves with the Wire Tool.
              ERROR: The request could not be satisfied
              (extensions.sketchup.com)
              By: Kristoff Rand
              • K
                Kanastrous
                thanks Kristoff!
                • KrisidiousK
                  Krisidious
                  I don't know why you're thanking me except to be polite... As usual I didn't read the whole post and didn't see you had already found this one. I'm notorious for just reading post titles. Sorry.
                  By: Kristoff Rand
                  • K
                    Kanastrous
                    You took a moment to help - sure, I'm happy to say 'thanks.' I did find a suitable tool earlier but the response is still appreciated!
                    • mitcorbM
                      mitcorb
                      Try TIGs Tube Along Path. yes you have to create the path using maybe Fredo6's BezierSpline tool and then make the tube with minimal faces for file economy. There is also Pipe Along Path that specifies wall thickness if you need it for conduit for your cable.
                      Edit: This is an image using arcs but you can use bezier and other curves.
                        Helix around Curve by Albertsoft
                        • K
                          Kanastrous
                          Those look wonderful. Thanks again, I will definitely get to working with those tools!
                            DavorP
                            Is there a geometry aware tool for cables? Fox example if you have a table lamp and a wall outlet and you know cable is 6ft long - is there a tool where you would select endpoints, enter lenght and have it randomly generate cable between the two points, accounting for geometry and gravity? I'd pay if there was such plugin to buy.
                            • soloS
                              That would be very cool, I believe I have seen something like that in Blender and I'm sure one of our amazing plugin guys could write something similar in SU.
                              • gillesG
                                gilles
                                Don't know about such plugin, Fredo's bz tools can help.
                                Look at the real world and try to reproduce.
                                • cottyC
                                  cotty
                                  Like this?
                                  my SketchUp gallery
                                  • soloS
                                    @cotty said:
                                    Like this?
                                    Hmm, not seen that before, I was also thinking more like a drape.
