Rbz extensions
Hi guys I cant use rbz plugins in su.Anyone can help?? please
Why can't you use them? You've given us nothing to use to help you out. They do work in SU8 unless you haven't upgraded to at least the second maintenance release.
Do you have the Install Extension button under Preferences>Extensions?
Yeah you are right I beg your pardon Im really inexperienced about these matters...
I dont have that install extension button under preferences extensions. -
So you have the original release of SU8. Update to the last release and you'll have the Install Extension button. Then you'll be able to install RBZ files with the best of them.
Okey,
So I downloaded some rbz plug ins, but I don't know what I am doing wrong as they wont install even after reading the instructions.
I use SU2013. I have looked through all the pull downs and buttons can't find any such as install feature.
Am I blind or am I looking in the wrong places.Thank you
Window >> Preferences >> Extensions >> Install Extension... [button]
Recommend also to download the SketchUcation Plugin Store toolset, to make it easy to install and manage your plugins... cheers!
Thank you Renderiza,
That made life easier.....
