    [Plugin]T2H_Stretch_By_Area v1.2.3(Aug 25,2013)
    30 Posts 21 Posters 58.5k Views 21 Watching
    • srxS Offline
      srx
      Very useful plugin! Thank you! ๐Ÿ˜„
      I'd like to have it in Autocad.
      www.saurus.rs
        Seems a very cool one! โ˜€
          a4chitect
          very nice, would be perfect if it only scaled/rotated linear components and keep the original component definition
          thank you for sharing!!
          • JQLJ Offline
            JQL
            Amazing plugin tak2hata! Thanks,
            I noticed that if I use you plugin in a group with some components where I pick a selection where some are stretched but some are just moved along the vector, the plugin creates unique components for all selected instances.
            Is it possible to make the plugin behave as it does if the components are not grouped?
            Best regards and thank you again!
            www.casca.pt
            Visit us on facebook!
            • BoxB Offline
              Yet another outstanding plugin.
              • V Offline
                Vicspa
                Very useful, thank you. ๐Ÿ‘
                  treviso
                  Great!!!
                  Will be perfect if sensitive with osnap geometry when clicking move direction
                  • ElibjrE Offline
                    Elibjr
                    Thank you so much! This is better than the AutoCAD stretch. Can't wait to really get into using it.
                      tawny
                      Thanks you, like the demonstration.
                      • JQLJ Offline
                        JQL
                        Tak2Hata,
                        When working inside a component/group if we use your plugin to stretch a small portion of the group, it selects everything inside the group but also outside it. This makes it very prone to create unexpected results. Is it somehow possible to affect only that wich is within the active context?
                        Thank you very much and best regards,
                        JQL
                        www.casca.pt
                          tak2hata
                          @jql said:
                          Tak2Hata,
                          JQL
                          Hi,JQL.
                          It is possible.
                          But now my right hand does not work fine for two weeks.
                          Please wait.
                          by TAK2HATA
                          • JQLJ Offline
                            JQL
                            Hi Tak2Hata,
                            Thanks for your generous reply. Please have no rush as it was just a suggestion for improvement on an already very useful plugin.
                            I hope you get well soon and best regards,
                            JQL
                            www.casca.pt
                              tak2hata
                              Hi,All.
                              I update this version to 1.2.2.
                              Only Modify the entities in active editting group/components.
                              ArcCurve modify as curve.
                              Draw Snap points.
                              And BugFix.
                              My right hand is not completely fixed,yet.
                              So,I edited small changes of this script.
                              by TAK2HATA
                                rv1974
                                I'll be damned! This is amazing (and seems to be stable)tool! ๐Ÿ˜ฎ
                                At last, after long dead period we've got something estimable in the Plugins forum.
                                Many thanks tak2hata!
                                  rv1974
                                  some minor bug: stretch doesn't work in this case.
                                  P.S. My humble request: multiple stretch a-la Acad's one (with Shift key).
                                  aaa21.skp
                                    lmfboy
                                    why i can't upload this plugin after i put it in the plugin folder?
                                      How did you go about putting it in the Plugins folder? Did you just paste the .rbz file into Plugins? If so, that the wrong way to do it. You need to use Install Extension under Preferences>Extensions.
                                      Complete your profile with your SketchUp and operating system versions.
                                        Ben Ritter
                                        Thank you for your generosity
                                          tak2hata
                                          Hi,rv1974.
                                          I will correct this bug.
                                          I think that adding function multiple stretch is difficult.
                                          So it takes long time.Please wait.
                                          Hi,lmfboy.
                                          I agree with Dave.
                                          Thanks Dave.
                                          Hi,Ben.
                                          Enjoy it.
                                          by TAK2HATA
                                            tak2hata
                                            Hi,everyone.
                                            I update this version to 1.2.3 in Aug25,2013.
                                            Bugfix abot selecting vertices in curve.
                                            by TAK2HATA
