    [Plugin] QuadFaceTools
    680 Posts 116 Posters 772.0k Views 116 Watching
      That's a bug in the first release of SketchUp 2013. There is a new versiono out that fixes this. Go to sketchup.com and download SketchUp again.
      • jo-keJ
        jo-ke
        Can I overwrite the old version or should I reinstall everything new?
        http://www.zz7.de
          Just install over the old one.
            Mra
            Confirmed. THanks thomthom.
            And thanks Trimblefor letting us all knwo about the patched 2013! πŸ˜’
            • jo-keJ
              jo-ke
              Yes that solved the problem
              Thank you
              http://www.zz7.de
              • ziiarZ
                ziiar
                Is there any way to over-scale? I would like the stone texture to match (or at least get close to) the scale of the cube.
                http://imageshack.us/a/img96/3663/vyw0.jpg
                I'm still trying to texture stone aches like what you did for your UV Toolkit thread. Is it possible/easier to do with that plugin? I couldn't figure out how to do it.
                http://sketchucation.com/forums/download/file.php?id=37073&mode=view/rokbox.jpg
                  "over-scale"? Not sure what you mean by that, but you adjust the size/scale of the UV mapping by using the red and green lines you get after picking origin and direction of the mapping. You see example of that in the videos.
                  Sent from my LT25i using Tapatalk 2
                  • ziiarZ
                    ziiar
                    Sorry, let me clarify. I want to control the texture right in SketchUp like this, where the texture goes past the face:
                    http://imageshack.us/a/img197/7456/x0tg.jpg
                    As you can see, It's easy enough to do with a square face, but I'm now trying to do this with arching textures. I realize this could be achieved by cropping the image beforehand, but given the nature of the project I'm working on, it would be so much better to do it right in SketchUp.
                      Ah - I see now. Yea, there is no way to scaling the UV mapping to extend beyond the model geometry using the tool handles. But you can specify scaling using the VCB - either using units relative to the texture size or absolute dimensions. A little bit of guesswork, but a couple of adjustment and it should be possible to get close.
                      • ziiarZ
                        ziiar
                        Sorry to be a pain but as I went to test that out I hit another problem.
                        I can't even get the texture to apply at all. I got it to work yesterday. I haven't updated anything in SketchUp. I still get the red and green lines but no texture gets applied. At first I thought it was being applied to the other side of the face but there's nothing showing up on either side. I rebooted, reinstalled Quadface tools, it's still the same. Updated to TT_Lib2-2.8.0, still the same.
                          Do you have the material you want to apply selected?
                          • ziiarZ
                            ziiar
                            Yes. If nothing is selected I get an error reading "No textured material selected."
                            If I apply the material elsewhere it won't give an error, but only if I select the material in the "In Model" category. If I select it from my imported texture library it will give me "selected material is not in the model."
                            I also tried another method like what you did in one of your UV videos by dragging in a texture directly, exploding it, and using the eye dropper to select, but that didn't work either.
                              hm.. I'm not entirely sure what might be going on. Any chance you could do a quick screen recording of what you do? (Screenpresso is great for that.)
                              • ziiarZ
                                ziiar
                                Embedding doesn't want to work with me but here:
                                  hm. And no errors in the Ruby Console?
                                  Can you send me that test file?
                                  Btw, when you tried to map the cube - you had some faces selected - that will limit the mapping to the selected faces. (But it should have at least mapped those...)
                                  It went a bit fast in the video, so I'd like to try to play with the model myself. But you might want to slow down a bit when you pick the U and V direction. It matters where on the edge you click.
                                  • ziiarZ
                                    ziiar
                                    Hey, my computer blew up yesterday and have since reformatted. I reinstalled everything and it appears to be functional now. I'm not really sure what was going on. Thank you though, and thank you for making the plugin, it's really been helping alot!
                                      Sorry to hear about your computer. But good to hear the plugin problems didn't persist.
                                      I suspect it was a permission/virtualstore issue.
                                      Sent from my SGP311 using Tapatalk HD
                                      • SKYNET-71S
                                        SKYNET-71
                                        Hi, i downloaded the trial version of VERTEXTOOLS 1.1.5, it is OK. QuadFacetools is loaded into the System Preferences window, but can not find it in Tools, even in Plugins. Help please. Thanks.
                                        SKYNET-71
                                        • tt_suT
                                          tt_su
                                          SKYNET-71
                                          Is Vertex Tools related at all to this question?
                                          Do you have TT_Lib2 installed?
                                          What version of SketchUp are you using?
                                          Are there any errors in the Ruby Console (Window > Ruby Console) or during startup?
                                          It should be under the Tools menu if correctly installed.
                                          • I
                                            ivreich
                                            Hey thomthom
                                            Was recently trying to use quadface tools in conjunction with s4u's "to components" plugin, which comes quite close to a working panelisation workflow.
                                            The only problem is that the components can only be mapped to faces, which are coplanar, i.e. triangles or coplanar quads. Is there a way to build in functionality into quadface tools to recalculate a quadface mesh into coplanar quads?
                                            I seem to remember paracloud had a similar feature.
                                            Cheers
                                            Joel
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 33
                                            • 34
                                            • 17 / 34
