    Dimensioning in Layout not measuring up...
    layout
    14 Posts 9 Posters 4.8k Views 9 Watching
    • drewD Offline
      drew
      I think that you all are on the right track. What I am actually working with is a building, placed on a Google Earth image accessed thru SketcUp. I placed the buiding on the location, rotated it to the proper orientation and modified the axes to be parralel and perpendicular to the building, also maintaining true North.
      I created scenes of each of the buildings elevations by aligning the view, then changed the camera to parrellel projection. I updated and saved the scenes and sent them to Layout 3. Now this is where the dimensioning gets off and measures angles in 3D rather than orthographically.
      So I'm thinking that it has something to do with the axes change. Any thoughts?
      drew
        Drew, I put the dimensions in my drawing in inside of LayOut. Those aren't created using sketchUp's Dimension tool. It does show some of what we'd like to be able to do with the Dimension tool automatically. though.
        LO's Dimension tool really doesn't seem to have anything to do with the axes in SU. It's more of a 2D dimensioning thing.
        • mariochaM Offline
          mariocha
          @arail1 said:
          The moral of this story - Layout dimensions work in 2D views but not in perspective views.
          Exactly !!
          I would add;
          Dimensions in SU works very well, and are linked to model, so they follows modifications. They should be used the most.
          LO dimensions are good for minor or quick additions and 2Ds.
          my 2¢. 😄
          %(#008000)[Mario C.
          • arail1A Offline
            arail1
            I would half agree.
            The attached image is from Rhino which has some advantages over SketchUp - the layout size of dimensions is controllable unlike in SketchUp where the dimension size goes wonky when you zoom in and out, and you can set standard dimension styles - slash vs ticks, font, etc.
            But Rhino has some downsides also - notice that it's a raster image. I can output the geometry with clean vector lines from Rhino but if I want to have dimensions I'm stuck with raster.
            Ultimately, I'm disappointed that the layout functions of SketchUp continue under the reign of Trimble to be a separate program. Much as I can see why that makes sense for someone building the elaborate pages that are often shown in these threads, for someone like myself who is being hammered left and right by clients and fabricators for rapid fire changes throughout the day, it's not very useful. Ideally I want to be able to work right in the modeling field with full annotations - dimensions, text, leaders, etc in 3D.
              For me, dimensions in LO work well enough and I find no need to use those in SketchUp. We'll see more improvements in the next version and I'm fine with that.
                sonder
                If Layout didn't work like this, then you could not dimension perspectives. To me this is a strength, not a weakness.
                • JQLJ Offline
                  JQL
                  I just have trouble dimensioning in 2D when I mix layout and skecthup lines. But then I turn off auto-scale and choose the scene scale for dimensioning.
                  If you are having trouble with dimensions on 2D views why don't you disable auto-scaling and dimension with a chosen scale.
                  Like Sonder says if you want to dimension something in full perspective mode, layout does that perfectly.
                  Sketchup dimensions have two problems that should be adressed.
                  1 - Angular dimensioning (you can download a plugin for that)
                  2 - Styles are not controlable in Layout.
                  Layout dimensions have limited styles features for managing extension lines styles independently from the dimension line and auto placement of numbers when they don't fit in dimension lines. Sketchup has a feature for placement of text outside the dimension line that should be available in Layout too.
                  www.casca.pt
                  Visit us on facebook!
                    Jim57
                    Mariocha—
                    Dimensioning in Sketchup, while convenient, does not work well.
                    Dimensions are fixed in space in SU. Shifting the perspective often puts them in awkward places.
                    Transferring the drawing to Layout then makes even more of a hash of it. First, there is no easy reference in SU to tell you how far away the dimension is in 3-space, and often measurements are at an inconsistent distance, or out of proportion to the drawing. With each edit, there is a risk of shifting perspective, then having to go back to SU, re-edit, re-save, refresh Layout, and check every view for conflicts.
                    Would that it were not so, dimensioning in Layout is a nightmare.
                    Jim
                    • mariochaM Offline
                      mariocha
                      Well Jim,
                      I guess I have been working with SU for so long now, and got so used to it, cause I seem to always find a way to make dimensions work for me. Be it in parallel views or 3D. It does take a while to integrate dimensioning in 3D. One has to forget 2D habits.
                      Using the Advanced settings, especially "Hide when foreshortened", helps a lot.
                      Yes, It, indeed, involves a lot of switching between SU & LO. It got faster with 2013.
                      %(#008000)[Mario C.
                      • Mike LuceyM Offline
                        Mike Lucey
                        Guys,
                        I have little difficulty dimensioning what I need to in SketchUp or Layout. Then again my dimensioning is pretty straightforward, plans and sections.
                        I find one really has to think ahead and plan for dimensioning awkward views. Not ideal I know but thats what we have for the moment.
                        Hopefully dimensioning ability will improve for LayOut in particular. We have to remember that the application is was called 'LayOut' for good reason, not DraftOut or similar. It was brought out initially as a convenient way to show SketchUp output. In all fairness it has come a long way since version one and I imagine will continue to improve as time goes on.
                        To be honest, I would have to say that LayOut has had more improvements than SketchUp over the past couple of years, so this gives me hope that it will continue to improve. Maybe to a level that the 'Layout' name does not properly describe the ability on the application.
                        Mike
