    [Plugin] Arcs Circles +
    74 Posts 30 Posters 67.4k Views 30 Watching
      rv1974
      Didier, first off thank you for your efforts and sharing!
      There are however some serious issues with ellipse tool (did not checked the others in deep)
      1.it'd extremely nice if ellipse tool could draw inside the groups\comps (while editing).
      Actually many tools of yours don't work 'inside'.
      2. Ellipse is extremely buggy\unstable (lots of freezing\crashing; sometimes there's only preview,- no final curve).
      aaa.skp
      • Didier BurD Offline
        Didier Bur
        @rv1974: bug fixed, and now can draw inside groups/components.
        DB
          trimguy66
          Thank You!!
          This is a plugin I will be using on a daily basis 😍
            Always not Option surfaces ?
              rv1974
              Thanks! Works smooth now, no crashes\freezing.
              Minor bug remained: while inside some group, it still does not draw on external greyed out geometry.
                tabehe
                Thank you very much for all your great plugs.
                • DETXD Offline
                  DETX
                  πŸ‘ this is what i wait for long time, thank.
                  so i can draw arc,circle like auto cad. πŸ’š
                  • utilerU Offline
                    utiler
                    @dtrarch said:
                    :thumb: πŸ‘
                    Didier
                    Thanks so very much.
                    Just plain good to have
                    dtr
                    Couldn't say it better myself! This has been one of my basic requests for SU to develop!
                    Thanks mate!!!!
                    Just Curious...
                    • U Offline
                      unearthed
                      Thanks very much Didier - three-point circles were one big part of my wish-list
                      Growplan - People ∩ Plants ∩ Place
                      windows 7 64b, 4GB RAM, SU 8.0.16846
                      Gimp, QGIS, Vectorworks 12, Bricscad 11
                      • mitcorbM Offline
                        mitcorb
                        Very good to have more options as a set. Thank you.
                        • cottyC Offline
                          cotty
                          A question to "Arc, center, 1 point, length": it is possible to define (VCB) the length of the arc or is it only possible with the mouse?
                          my SketchUp gallery
                            Didier Bur
                            [*]it is possible to define (VCB) the length of the arc or is it only possible with the mouse?
                            you can type a length in the VCB. If it doesn't work on your side, plz report the issue .
                            DB
                            • cottyC Offline
                              cotty
                              I can enter a length, but it is not accepted/assigned to the arc. I tried the input before and after mouse move. There is no reaction to the return key in the vcb...
                              my SketchUp gallery
                                Didier Bur
                                @Cotty: Unzip the attached file and overwrite your "arcscircles.rbs" file with the attached one. I'm pretty sure this will solve the issue. πŸ˜‰
                                Regards,
                                arcscircles.zip
                                DB
                                • cottyC Offline
                                  cotty
                                  Regards,
                                  Yes, it does!
                                  Thank you!
                                  (What was the reason for this?)
                                  my SketchUp gallery
                                    Didier Bur
                                    [*]What was the reason for this?
                                    The released plugin was older than the version I used myself... 😳
                                    DB
                                      @Didier
                                      Will you be formally reissuing it as v2.0.2 ?
                                      The download link and PluginStore etc are now out of date ?
                                      πŸ˜•
                                      PS: I've done the update for you...
                                      http://sketchucation.com/forums/viewtopic.php?p=484650#p484650
                                      Hope that's OK...
                                      • sbpronhS Offline
                                        sbpronh
                                        Hi! Thanks foor the plugin but I get this message (see attachment).
                                        Regards!
                                          Didier Bur
                                          Thanks TIG πŸ‘
                                          Apparently the plugin has a problem with "additionnal Plugins Folder" ?
                                          DB
                                            You need to set a reference [class variable or module::Constant] to the 'container' in the loader .rb to get where it is, and work the tree to your folder from there...
                                            Usually it's the Plugins folder, but with custom-folders it is not !
                                            Compiled .rbs files mess up on code FILE..., so you need to use that in the .rb loader, setting it before it loads other files.
                                            You should never use the Sketchup.fine_support_file() method, because that always looks in the main Plugins folder, and so misses custom-plugins folders... πŸ˜’
                                            • 1 / 4
