    [Plugin] Arcs Circles +
    74 Posts 30 Posters 67.4k Views 30 Watching
    • E Offline
      el.antuan
      Wow! Thanks in deed!! 😄
      "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
      • CadFatherC Offline
        CadFather
        nice to see Didier in action.. thanks! 👍
          jpalm32
          Very good. Thanks!!!
            rv1974
            Didier, first off thank you for your efforts and sharing!
            There are however some serious issues with ellipse tool (did not checked the others in deep)
            1.it'd extremely nice if ellipse tool could draw inside the groups\comps (while editing).
            Actually many tools of yours don't work 'inside'.
            2. Ellipse is extremely buggy\unstable (lots of freezing\crashing; sometimes there's only preview,- no final curve).
            aaa.skp
            • Didier BurD Offline
              Didier Bur
              @rv1974: bug fixed, and now can draw inside groups/components.
              DB
                trimguy66
                Thank You!!
                This is a plugin I will be using on a daily basis 😍
                  Always not Option surfaces ?
                    rv1974
                    Thanks! Works smooth now, no crashes\freezing.
                    Minor bug remained: while inside some group, it still does not draw on external greyed out geometry.
                      tabehe
                      Thank you very much for all your great plugs.
                      • DETXD Offline
                        DETX
                        👍 this is what i wait for long time, thank.
                        so i can draw arc,circle like auto cad. 💚
                        • utilerU Offline
                          utiler
                          @dtrarch said:
                          :thumb: 👍
                          Didier
                          Thanks so very much.
                          Just plain good to have
                          dtr
                          Couldn't say it better myself! This has been one of my basic requests for SU to develop!
                          Thanks mate!!!!
                          Just Curious...
                          • U Offline
                            unearthed
                            Thanks very much Didier - three-point circles were one big part of my wish-list
                            Growplan - People ∩ Plants ∩ Place
                            windows 7 64b, 4GB RAM, SU 8.0.16846
                            Gimp, QGIS, Vectorworks 12, Bricscad 11
                            • mitcorbM Offline
                              mitcorb
                              Very good to have more options as a set. Thank you.
                              • cottyC Offline
                                cotty
                                A question to "Arc, center, 1 point, length": it is possible to define (VCB) the length of the arc or is it only possible with the mouse?
                                my SketchUp gallery
                                  Didier Bur
                                  [*]it is possible to define (VCB) the length of the arc or is it only possible with the mouse?
                                  you can type a length in the VCB. If it doesn't work on your side, plz report the issue .
                                  DB
                                  • cottyC Offline
                                    cotty
                                    I can enter a length, but it is not accepted/assigned to the arc. I tried the input before and after mouse move. There is no reaction to the return key in the vcb...
                                    my SketchUp gallery
                                      Didier Bur
                                      @Cotty: Unzip the attached file and overwrite your "arcscircles.rbs" file with the attached one. I'm pretty sure this will solve the issue. 😉
                                      Regards,
                                      arcscircles.zip
                                      DB
                                      • cottyC Offline
                                        cotty
                                        Regards,
                                        Yes, it does!
                                        Thank you!
                                        (What was the reason for this?)
                                        my SketchUp gallery
                                          Didier Bur
                                          [*]What was the reason for this?
                                          The released plugin was older than the version I used myself... 😳
                                          DB
                                            @Didier
                                            Will you be formally reissuing it as v2.0.2 ?
                                            The download link and PluginStore etc are now out of date ?
                                            PS: I've done the update for you...
                                            http://sketchucation.com/forums/viewtopic.php?p=484650#p484650
                                            Hope that's OK...
                                            • 1 / 4
