    MAJOR MISTAKE IN SKETCHUP
    13 Posts 8 Posters 1.3k Views 8 Watching
      TC2 AKA THUNDERCARPET
      also hi im new!
      anyways I did a MAJOR Mistake. I forgot to save my file, BUT I uploaded it to warehouse then when going through my files I pressed the wrong button and perm. deleted.
      • KrisidiousK Offline
        Krisidious
        Sketchup automatically makes a backup file. check for it. it's will have the .skb file extension.
        By: Kristoff Rand
          Yea.. Sketchup didn't make a autosave.
            TECHDAVE02
            There still should be backup a ".skb" you may need to use a "open with" search for a skb.
              So you've uploaded it to the Warehouse but deleted it from your computer? Or did you delete it from the Warehouse, too?
                I never saved a file I uploaded it to the warehouse
                but I accidently deleted IT FROM the warehouse.
                  I believe if you closed SketchUp without saving the file, the backup file would have been removed and since you've deleted it from the warehouse, you are kind of out of luck. Call it a teaching moment and make sure in the future that you save your file on your computer even if you are going to upload it to 3DWH.
                  It'll be good practice to draw it again.
                  • Mike LuceyM Offline
                    Mike Lucey
                    ..... also I find that re-draw time is often down by 50%. Maybe its because the 'file' may be stored in one's brain πŸ˜„
                      it was my first model to use my own doors and windows instead of sketchup. Ever since my original one Thundercarpet, I used nothing but sketchup doors and windows. And this was finally going to change it.
                        Hi Beginner, will this work on files accidentally deleted from the 3D Warehouse? In the OP's case that's what he did. He didn't delete it from his hard drive. He just never saved the file on his own computer.
                        • beginnerB Offline
                          beginner
                          Hi TC2 AKA THUNDERCARPET,
                          In the past, I have used various software to undelete files.
                          Recently tried FreeUndelete - it worked.
                          Normally, I would go for one which doesn't need installation and 'Save/Recover' goes to a different drive.
                          Any installation or files saving on the same drive (after files are deleted) can reduce your chance to recover deleted files.
                          When you delete...recover immediately and good luck.
                          Next time you will use Ctrl+S every step, every line you draw to be sure that you have something on your drive πŸ˜‰
                          Regards, SU 'beginner'
                            curro
                            Hi, I think you are the author of a Warehouse model called Googleport.
                            I'm interested in using an Sketchup animation of this model as a background for a video project I'm working on.
                            I've been searching some info about rigths to Warehouse models but couldn't find anything.
                            Is there any rights restrictions on the use of the model?
                            Best regards.
                            • ely862meE Offline
                              ely862me
                              Hi ! Welcome !
                              Elisei (sketchupper)
                              Come and See EliseiDesign
