    Spiral corridoor/passage problem (Follow Me Tool)
    3 Posts 2 Posters 242 Views 2 Watching
      MattsDesigns
      Hi guys
      I've been using the follow me tool to extrude a square shape around a short downward spiral. If you imagine a short and downward spiral corridor in your head-
      I need the floor and ceiling to stay parallel with the ground (if Sketchup had a ground).
      The Follow Me tool causes the square profile to bank around the spiral which looks nice but isn't what I'm after right now!
      Thanks.
      • TIGT Online
        This 'skewing' of profiles extruded with FollowMe is a known limitation of the native tool...
        That is why the 'FollowMe And Keep' plugin [FAK] was created πŸ˜„
        Download/install from the SCF PluginStore [under the Resources menu above].
        This will do your extrusion as you wish, keeping the profile 'level' as it goes around the 3d curve...
        πŸ€“
          MattsDesigns
          Ah thankyou πŸ˜„
