    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • srxS Offline
      srx
      Wonderful plugin. Here is Serbian translation. Just to feel the excitement of taking part in an international project 😄 .
      fur_lang_srb.txt
      www.saurus.rs
        tak2hata
        I upload to v2.0.6.
        Include the language file for Serbian by SRX.Thanks!
        Hi,menes.
        I try it!
        finished
        component for leavs
        Component for leaves lay along to X-Axis(RED) with litte slope.
        And place it with large Z value of "direction" and "force" in fur dialog.
        It make like this placement.
        Thanks.
        by TAK2HATA
        • N Offline
          nektares
          i loved this plugin already, and now it´s even better! Arigato Gozaimasu Tak2Hata
            menes
            Thank you very much indeed! TAK2HATA
            Will try and let you know
              menes
              Thanks TAK2HATA
              You put me in the right way 😍 thank you!
              My values were different
              Main Detail
              type : leaf top jitter :8
              Density: 60.000 width jitter: 19
              Max n. :60.000 stiffness jitter : 50
              length :1 valid distance: 0,000
              rootwidth : 0,200 direction (x): 0,000
              stiffness : 1 direction (y): 0,000
              divide :2 direction (z): 1
              force (x):0
              force (y):0,000
              force (z):-30
              now the only thing to try ,it's to avoid many leaves at the bottom of the branches and have more on the top.
              • thkian92T Offline
                thkian92
                Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
                  mwm5053
                  Great plugin 👍 I updated to 2.0.6 but not getting sliders or realtime preview like video shows I get the older dialog style. I'm using latest SU8 Pro on Mac 10.7.5
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                    tak2hata
                    Hi,Walt.
                    I will test it on Mac.
                    Please wait.
                    Thanks.
                    by TAK2HATA
                      mwm5053
                      2011 iMac
                      V2 Twilight
                        tak2hata
                        Hi,Walt.
                        I tested on mac.
                        Screen shots here.
                        files in plugin folder
                        work fine on mac.
                        I think the problem is folder.
                        The webdialog lost the sight of "JS" folder or "CSS" folder.
                        But I think no problem about the non-alphabetical character file names on mac.
                        So please tell me your plugin folder.
                        Thanks.
                        by TAK2HATA
                          mwm5053
                          Path can be seen at bottom of screen shot.
                          2011 iMac
                          V2 Twilight
                            tak2hata
                            I think there is no problem.....
                            The problem becomes the mystery.
                            I will create test code for you.
                            Please wait.
                            by TAK2HATA
                            • Z Offline
                              Zacchia
                              Hi tak2hata
                              Many thanks for your wonderful plugin! See attached an idea, hope you can understand 😒 It is just an idea.
                                tak2hata
                                Hi,Walt.
                                I create the test ruby for you.
                                test ruby
                                It shows the folders for fur and Test Slider on Webdialog.
                                Select from menu bar.
                                Plugins -> Fur Test For Walt
                                It will show like this.
                                Show like this
                                Hi,Zacchia.
                                I understand your idea.
                                But It will add new many properties.
                                They take long time.
                                Wait for Fur v3.0.
                                Now I must sleep soon for tomorrow.
                                Thanks.
                                by TAK2HATA
                                  mwm5053
                                  Here we go still no slider.
                                  2011 iMac
                                  V2 Twilight
                                  • thkian92T Offline
                                    thkian92
                                      No existing randomize size of elements, Components? 😲
                                        tak2hata
                                        Ummm...
                                        It is difficult.
                                        I consider well.
                                        Please wait.
                                        Hi,Pilou.
                                        In Fur webdialog,
                                        TopJitter(%) will randomize the size of placing component.
                                        Or Use Crowd Dialog.
                                        Hi,thkian92.
                                        I tested on Sketchup13.It works well.
                                        I have some questions.
                                        Was the error mesasge show on starting sketchup?
                                        Does fur Toolbar exits on your sketchup.
                                        Did you install fur correctly?
                                        Sketchup V8,too?
                                        Thanks.
                                        by TAK2HATA
                                          Tested on V7 😉
                                          Very cool! 😎
                                          Does exist something for avoid "collisions" of volumes?
                                          And seems Preview positions of the crowd don't gives the good result?
                                          Number is good but not the position! 😲
                                          Does it possible in the Crowd Menu to have something who gives random size
                                          but not a rotation ?
                                          What the "Stand Up" (Yes / No) is supposed to do ?
                                            tak2hata
                                            Hi,Pilou.
                                            This tool is fur tool.
                                            To interference solids will make too many raytest checks.
                                            So it will be too slow to use.
                                            The purpos of preview is chechking the styles.
                                            The show full preview will too slowly to use fine.
                                            I limit the number of fur in previwe to make it fast.
                                            So preview position is not same to generating.
                                            Sorry for my poor technology.
                                            Hi,Walt.
                                            This is last test.
                                            Please open Ruby console in sketchup.
                                            (menu bar -> windows -> ruby console)
                                            And copy and paste this line.
                                            wdlg=UI;;WebDialog.new( "Fur TEST", true, "T2H_FUR_DIALOG", 300, 680, 150, 150, true);wdlg.set_url("http://jqueryui.com/slider/");wdlg.show_modal
                                            like this picture.
                                            2013.06.30screenshot1
                                            And press enter key to run the script.
                                            Webdialog will be shown.
                                            The right state of display is here.
                                            2013.06.30screenshot2
                                            I am not able to solve this problem when there is no slider.
                                            If the slider is shown,I think the prbolem caused to "CSS" folder.
                                            Thanks.
                                            by TAK2HATA
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 32
                                            • 33
                                            • 27 / 33
