    [Code] Sketchup.send_action() : Arguments to
    22 Posts 8 Posters 9.5k Views 8 Watching
      driven
      is this an exception? [as in a mac thing...]
      > Sketchup.send_action('viewPerspective;')
      true
      > !Sketchup.send_action('viewPerspective;')
      false
      Edit:
      I've been looking for a replacement for Sketchup.send_action('viewParallelProjection:') which returns True, but doesn't 'switch views' on mac.
      **!**Sketchup.send_action('viewPerspective:') does, I'm wondering if it also 'switches views' on PC or would I need to have both in a cross platform script.
      EDIT Edit: Sketchup.send_action('viewParallelProjection:') is working now?
      it not on the list, but I had tried it... maybe I had a typo...
      So does Sketchup.send_action('viewParallelProjection:') work on PC's... john
      • K
        ktkoh
        Sketchup.send_action('viewParallelProjection:') does not work on the PC. It returns true or false but does not change the view.
        Sketchup.active_model.active_view.camera.perspective = false This command will change based on the true or false value
        Keith
          No action for the Follow Me tool? (That works on both platforms.)
            driven
            don't know what works on a PC, but since your probably missing the mac one...
            Sketchup.send_action('selectExtrudeTool;')
            I'll add this to my list...
            I've got a osascript test runner, for running the lot if you want it...
              Excellent! I didn't realise that was it's internal name. Doh!
              Yea, run the lot and see what you get.
                I think early versions of SketchUp called it the 'Extrude Tool', later it was renamed 'FollowMe' but the original 'coded' name remains - which is like 'Scenes' are really 'Pages', 'Guides' are really 'Clines' etc, and other foibles that you can probably list too !
                  Yea - there's lots of legacy strangeness to discover when traversing the API.
                    driven
                    possibly new for v2013 on mac at least
                    Sketchup.send_action('closeDocument;')
                    Sketchup.send_action('newDocument;')
                    Sketchup.send_action('saveDocument;')
                    Sketchup.send_action('openDocument;')
                    Sketchup.send_action('printDocument;')
                    @Dan, thanks for the trigger to test them...
                      Some of those have been around BUT 'undocumented' for some time [v8M2].
                      The 'saveDocument:' is particularly useful because calling model.save(model.path) does NOT save the model BUT returns 'true'.
                      So if you want to ensure the model is saved before saving it as another name, that send_action is needed...
                      Here's a list that I have for those v8M2 changes - some were documented but * == undocumented & ! == broken on MAC:
                      addBuilding: !
                      copy: *
                      cut: *
                      editDelete: *
                      getCurrentView: *
                      getModels: *!
                      getPhotoTexture: !
                      newDocument: *
                      openDocument: *
                      paste: *
                      placeModel: *
                      printDocument: *
                      saveDocument: *
                      select3dTextTool: *
                      selectionZoomExt: *
                      shareModel: *!
                      showRubyPanel:
                      uploadComponent: *!
                      viewShowGuides: *
                        driven
                        This is my latest list, some may be mac only, some new, some missing
                        Sketchup.send_action('addBuilding;') #!   dosn't work on mac
                        Sketchup.send_action('getPhotoTexture;') #!   dosn't work on mac
                        Sketchup.send_action('openDocument;') # dialog drop-down sheet
                        Sketchup.send_action('printDocument;') # direct print of current view  @current settings
                        Sketchup.send_action('saveDocument;') # dialog drop-down sheet
                        Sketchup.send_action('editHide;')
                        Sketchup.send_action('editRedo;')
                        Sketchup.send_action('editUndo;')
                        Sketchup.send_action('editUnhide;') #!   dosn't work on mac
                        Sketchup.send_action('editUnhideAll;') #*  does work on mac
                        Sketchup.send_action('editUnhideLast;') #*  does work on mac
                        Sketchup.send_action('fixNonPlanarFaces;')
                        Sketchup.send_action('pageAdd;')
                        Sketchup.send_action('pageDelete;')
                        Sketchup.send_action('pageNext;')
                        Sketchup.send_action('pagePrevious;')
                        Sketchup.send_action('pageUpdate;')
                        Sketchup.send_action('renderHiddenLine;')
                        Sketchup.send_action('renderMonochrome:')
                        Sketchup.send_action('renderShaded;')
                        Sketchup.send_action('renderTextures;')
                        Sketchup.send_action('renderWireframe;')
                        Sketchup.send_action('selectAll;') #NEW?  does work on mac but not('editSelectAll;')
                        Sketchup.send_action('selectArcTool;')
                        Sketchup.send_action('selectAxisTool;')
                        Sketchup.send_action('selectCircleTool;')
                        Sketchup.send_action('selectDimensionTool;')
                        Sketchup.send_action('selectDollyTool;')
                        Sketchup.send_action('selectEraseTool;')
                        Sketchup.send_action('selectFieldOfViewTool;')
                        Sketchup.send_action('selectFreehandTool;')
                        Sketchup.send_action('selectImageIglooTool;')
                        Sketchup.send_action('selectLineTool;')
                        Sketchup.send_action('selectMeasureTool;')
                        Sketchup.send_action('selectMoveTool;')
                        Sketchup.send_action('selectNorthTool;')
                        Sketchup.send_action('selectOffsetTool;')
                        Sketchup.send_action('selectOrbitTool;')
                        Sketchup.send_action('selectPaintTool;')
                        Sketchup.send_action('selectPolygonTool;')
                        Sketchup.send_action('selectPositionCameraTool;')
                        Sketchup.send_action('selectProtractorTool;')
                        Sketchup.send_action('selectPushPullTool;')
                        Sketchup.send_action('selectRectangleTool;')
                        Sketchup.send_action('selectRotateTool;')
                        Sketchup.send_action('selectScaleTool;')
                        Sketchup.send_action('selectSectionPlaneTool;')
                        Sketchup.send_action('selectSelectionTool;')
                        Sketchup.send_action('selectTextTool;')
                        Sketchup.send_action('selectTurnTool;')
                        Sketchup.send_action('selectWalkTool;')
                        Sketchup.send_action('selectZoomTool;')
                        Sketchup.send_action('selectZoomWindowTool;')
                        Sketchup.send_action('viewBack;')
                        Sketchup.send_action('viewBottom;')
                        Sketchup.send_action('viewFront;')
                        Sketchup.send_action('viewIso;')
                        Sketchup.send_action('viewLeft;')
                        Sketchup.send_action('viewParallelProjection;') #* does work on mac •toggle
                        Sketchup.send_action('viewPerspective;') #* does work on mac •toggle
                        Sketchup.send_action('viewRight;')
                        Sketchup.send_action('viewShowAxes;')
                        Sketchup.send_action('viewShowAxes;') #*  does work on mac •toggle
                        Sketchup.send_action('viewShowGuides;') #*  does work on mac •toggle
                        Sketchup.send_action('viewShowHidden;') #*  does work on mac •toggle
                        Sketchup.send_action('viewTop;')
                        Sketchup.send_action('viewTwoPointPerspective;') #* does work on mac
                        Sketchup.send_action('viewUndo;')
                        Sketchup.send_action('viewZoomExtents;')
                        Sketchup.send_action('viewZoomToSelection;')
                        Sketchup.send_action('showRubyPanel;')
                        Sketchup.send_action('cut;')
                        Sketchup.send_action('copy;')
                        Sketchup.send_action('paste;')
                        Sketchup.send_action('pasteInPlace;')
                        Sketchup.send_action('editDelete;')
                        forgot the bottom one, and I think I have a few others... somewhere...
                          Mythos
                          Is there any action to edit a group/component (similar as double clicking on a group)?
                            No. 😞
                            I have PM'd you a suggestion with a method using view.pick_helper.path_at[-2], to select the picked object's container, then using the [forced open] Outliner to open that now selected group/instance for editing...
                            • Dan RathbunD
                              Dan Rathbun
                              Has anyone found a cross-platform string to send the model to Layout ?
                              On the PC only this works:
                              Sketchup::send_action( 23051 )
                              I'm not here much anymore.
                              • Dan RathbunD
                                Dan Rathbun
                                John confirmed that Sketchup::send_action("sendToLayOut:") works on Mac.
                                So that gives us a cross-platform method
                                <span class="syntaxdefault">def send_active_model_to_layout</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">  return nil unless Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_pro</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  if </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">respond_to</span><span class="syntaxkeyword">?(;</span><span class="syntaxdefault">platform</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">&&<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">platform </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">platform_win </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||<br /></span><span class="syntaxdefault">  RUBY_PLATFORM </span><span class="syntaxkeyword">!~</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">/(</span><span class="syntaxdefault">darwin</span><span class="syntaxkeyword">)/</span><span class="syntaxdefault">i<br />    Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> 23051 </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  else<br />    Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"sendToLayOut;"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />end<br /></span>
                                EDIT: inserted Pro only bailout statement to return nil if not SketchUp Pro.
                                  driven
                                  it's been a while and maybe everyone has lost interest, but I found a few more for the mac list...
                                  the big question is, how many of these run on a PC?
                                  single # denotes a Menu Title, ## Item Title, ### hard coded shortcut combo...
                                  # SketchUp
                                    Sketchup.send_action('showAboutBox;')  ## About SketchUp
                                    Sketchup.send_action('showSketchUpPreferences;')  ## Preferences...
                                    Sketchup.send_action('manageLicenses;')  ## License...
                                    Sketchup.send_action('checkWebUpdate;')  ## Check Web for Update...
                                    Sketchup.send_action('hide;')  ## Hide SketchUp  ### ⌘H
                                    Sketchup.send_action('hideOtherApplications;')  ## Hide Others  ### ⌘H
                                    Sketchup.send_action('unhideAllApplications;')  ## Show All
                                    Sketchup.send_action('terminate;')  ## Quit SketchUp  ### ⌘Q
                                  # File
                                    Sketchup.send_action('newDocument;')  ## New  ### ⌘N
                                    Sketchup.send_action('openDocument;')  ## Open...  ### ⌘O
                                    Sketchup.send_action('clearRecentDocuments;')  ## Clear Menu
                                    Sketchup.send_action('performClose;')  ## Close  ### ⌘W
                                    Sketchup.send_action('saveDocument;')  ## Save  ### ⌘S
                                    Sketchup.send_action('saveDocumentAs;')  ## Save As...  ### ⇧⌘S
                                    Sketchup.send_action('saveCopy;')  ## Save A Copy As...
                                    Sketchup.send_action('saveAsTemplate;')  ## Save As Template...
                                    Sketchup.send_action('revertDocumentToSaved;')  ## Revert
                                    Sketchup.send_action('sendToLayOut;')  ## Send to LayOut
                                    Sketchup.send_action('importFromGoogleEarth;')  ## Add Location...
                                    Sketchup.send_action('clearLocation;')  ## Clear Location
                                    Sketchup.send_action('toggleTerrain;')  ## Show Terrain
                                    Sketchup.send_action('browse3DWarehouse;')  ## Get Models...
                                    Sketchup.send_action('shareWithGoogleEarthCommunity;')  ## Share Model...
                                    Sketchup.send_action('runImporter;')  ## Import...
                                    Sketchup.send_action('runPageLayout;')  ## Page Setup...  ### ⇧⌘P
                                    Sketchup.send_action('runDocumentSetup;')  ## Document Setup...
                                    Sketchup.send_action('printDocument;')  ## Print...  ### ⌘P
                                  # Edit
                                    Sketchup.send_action('editUndo;')  ## Undo  ### ⌘Z
                                    Sketchup.send_action('editRedo;')  ## Redo  ### ⇧⌘Z
                                    Sketchup.send_action('cut;')  ## Cut  ### ⌘X
                                    Sketchup.send_action('copy;')  ## Copy  ### ⌘C
                                    Sketchup.send_action('paste;')  ## Paste  ### ⌘V
                                    Sketchup.send_action('pasteInPlace;')  ## Paste In Place
                                    Sketchup.send_action('editDelete;')  ## Delete
                                    Sketchup.send_action('eraseConstructionGeometry;')  ## Delete Guides
                                    Sketchup.send_action('selectAll;')  ## Select All  ### ⌘A
                                    Sketchup.send_action('deselectAll;')  ## Select None  ### ⇧⌘A
                                    Sketchup.send_action('editHide;')  ## Hide  ### ⌘E
                                    Sketchup.send_action('editUnhide;')  ## Selected
                                    Sketchup.send_action('editUnhideLast;')  ## Last
                                    Sketchup.send_action('editUnhideAll;')  ## All  ### ⇧⌘E
                                    Sketchup.send_action('editLock;')  ## Lock
                                    Sketchup.send_action('editUnlockSelected;')  ## Selected
                                    Sketchup.send_action('editUnlockAll;')  ## All
                                    Sketchup.send_action('makeComponent;')  ## Make Component...  ### ⇧⌘G
                                    Sketchup.send_action('makeGroup;')  ## Make Group  ### ⌘G
                                    Sketchup.send_action('closeGroupOrComponent;')  ## Close Group/Component  ### ⇧⌘G
                                    Sketchup.send_action('intersectWithModel;')  ## With Model
                                    Sketchup.send_action('intersectSelected;')  ## With Selection
                                    Sketchup.send_action('intersectWithContext;')  ## With Context
                                  # View
                                    Sketchup.send_action('toggleToolPalette;')  ## Large Tool Set
                                    Sketchup.send_action('toggleSolidModelToolPalette;')  ## Solid Tools
                                    Sketchup.send_action('toggleGoogleToolPalette;')  ## Location
                                    Sketchup.send_action('toggleWarehouseToolPalette;')  ## Warehouse
                                    Sketchup.send_action('togglePageTabsDsiplay;')  ## Scene Tabs
                                    Sketchup.send_action('viewShowHidden;')  ## Hidden Geometry
                                    Sketchup.send_action('sectionToggleDisplay;')  ## Section Planes
                                    Sketchup.send_action('sectionToggleActivation;')  ## Section Cuts
                                    Sketchup.send_action('viewShowAxes;')  ## Axes
                                    Sketchup.send_action('viewShowGuides;')  ## Guides
                                    Sketchup.send_action('toggleShadows;')  ## Shadows
                                    Sketchup.send_action('toggleFog;')  ## Fog
                                    Sketchup.send_action('toggleDisplayEdges;')  ## Edges
                                    Sketchup.send_action('toggleDisplayBackEdges;')  ## Back Edges
                                    Sketchup.send_action('toggleProfiles;')  ## Profiles
                                    Sketchup.send_action('toggleDepthQue;')  ## Depth Cue
                                    Sketchup.send_action('toggleExtensions;')  ## Extension
                                    Sketchup.send_action('toggleGlobalTransparency;')  ## X-ray
                                    Sketchup.send_action('renderWireframe;')  ## Wireframe
                                    Sketchup.send_action('renderHiddenLine;')  ## Hidden Line
                                    Sketchup.send_action('renderShaded;')  ## Shaded
                                    Sketchup.send_action('renderTextures;')  ## Shaded With Textures
                                    Sketchup.send_action('renderMonochrome&#058;')  ## Monochrome
                                    Sketchup.send_action('toggleHideRestOfModel;')  ## Hide Rest of Model
                                    Sketchup.send_action('toggleHideSimilarComponents;')  ## Hide Similar Components
                                    Sketchup.send_action('pageAdd;')  ## Add Scene
                                    Sketchup.send_action('pageUpdate;')  ## Update Scene
                                    Sketchup.send_action('pageDelete;')  ## Delete Scene
                                    Sketchup.send_action('pagePrevious;')  ## Previous Scene
                                    Sketchup.send_action('pageNext;')  ## Next Scene
                                    Sketchup.send_action('slideshowStart;')  ## Play
                                    Sketchup.send_action('pageOptions;')  ## Settings
                                    Sketchup.send_action('toggleToolbarShown;')  ## Hide Toolbar
                                    Sketchup.send_action('runToolbarCustomizationPalette;')  ## Customize Toolbar ...
                                  # Draw
                                    Sketchup.send_action('selectLineTool;')  ## Line  ### ⌘L
                                    Sketchup.send_action('selectFreehandTool;')  ## Freehand  ### ⌘F
                                    Sketchup.send_action('selectArc3PointTool;')  ## Arc  ### ⌘J
                                    Sketchup.send_action('selectArcTool;')  ## 2 Point Arc
                                    Sketchup.send_action('select3PointFitArcTool;')  ## 3 Point Arc
                                    Sketchup.send_action('selectArcPieTool;')  ## Pie
                                    Sketchup.send_action('selectRectangleTool;')  ## Rectangle  ### ⌘K
                                    Sketchup.send_action('selectRectangle3PointTool;')  ## Rotated Rectangle
                                    Sketchup.send_action('selectCircleTool;')  ## Circle
                                    Sketchup.send_action('selectPolygonTool;')  ## Polygon
                                  # Camera
                                    Sketchup.send_action('viewUndo;')  ## Previous
                                    Sketchup.send_action('viewRedo;')  ## Next
                                    Sketchup.send_action('viewTop;')  ## Top  ### ⌘1
                                    Sketchup.send_action('viewBottom;')  ## Bottom  ### ⌘2
                                    Sketchup.send_action('viewFront;')  ## Front  ### ⌘3
                                    Sketchup.send_action('viewBack;')  ## Back  ### ⌘4
                                    Sketchup.send_action('viewLeft;')  ## Left  ### ⌘5
                                    Sketchup.send_action('viewRight;')  ## Right  ### ⌘6
                                    Sketchup.send_action('viewIso;')  ## Iso  ### ⌘7
                                    Sketchup.send_action('viewParallelProjection;')  ## Parallel Projection
                                    Sketchup.send_action('viewPerspective;')  ## Perspective
                                    Sketchup.send_action('viewTwoPointPerspective;')  ## Two-Point Perspective
                                    Sketchup.send_action('cameraMatchNewPhoto;')  ## Match New Photo...
                                    Sketchup.send_action('editPhotoMatch;')  ## Edit Matched Photo
                                    Sketchup.send_action('selectOrbitTool;')  ## Orbit  ### ⌘B
                                    Sketchup.send_action('selectDollyTool;')  ## Pan  ### ⌘R
                                    Sketchup.send_action('selectZoomTool;')  ## Zoom
                                    Sketchup.send_action('selectFieldOfViewTool;')  ## Field of View
                                    Sketchup.send_action('selectZoomWindowTool;')  ## Zoom Window
                                    Sketchup.send_action('viewZoomExtents;')  ## Zoom Extents
                                    Sketchup.send_action('viewZoomImage;')  ## Zoom to Photo
                                    Sketchup.send_action('selectPositionCameraTool;')  ## Position Camera
                                    Sketchup.send_action('selectWalkTool;')  ## Walk
                                    Sketchup.send_action('selectTurnTool;')  ## Look Around
                                    Sketchup.send_action('selectImageIglooTool;')  ## Image Igloo
                                  # Tools
                                    Sketchup.send_action('selectSelectionTool;')  ## Select
                                    Sketchup.send_action('selectEraseTool;')  ## Eraser
                                    Sketchup.send_action('selectPaintTool;')  ## Paint Bucket
                                    Sketchup.send_action('selectMoveTool;')  ## Move  ### ⌘0
                                    Sketchup.send_action('selectRotateTool;')  ## Rotate  ### ⌘8
                                    Sketchup.send_action('selectScaleTool;')  ## Scale  ### ⌘9
                                    Sketchup.send_action('selectPushPullTool;')  ## Push/Pull
                                    Sketchup.send_action('selectExtrudeTool;')  ## Follow Me
                                    Sketchup.send_action('selectOffsetTool;')  ## Offset
                                    Sketchup.send_action('selectOuterShellTool;')  ## Outer Shell
                                    Sketchup.send_action('selectUnionTool;')  ## Union
                                    Sketchup.send_action('selectDifferenceTool;')  ## Subtract
                                    Sketchup.send_action('selectDifferenceNDTool;')  ## Trim
                                    Sketchup.send_action('selectIntersectTool;')  ## Intersect
                                    Sketchup.send_action('selectBooleanSplitTool;')  ## Split
                                    Sketchup.send_action('showSolidModelToolsMenu;')  ## Split
                                    Sketchup.send_action('selectMeasureTool;')  ## Tape Measure  ### ⌘D
                                    Sketchup.send_action('selectProtractorTool;')  ## Protractor
                                    Sketchup.send_action('selectAxisTool;')  ## Axes  ### ⌘F
                                    Sketchup.send_action('selectDimensionTool;')  ## Dimensions
                                    Sketchup.send_action('selectTextTool;')  ## Text
                                    Sketchup.send_action('doThreeDText;')  ## 3D Text
                                    Sketchup.send_action('selectSectionPlaneTool;')  ## Section Plane  ### ⌘Y
                                  # Window
                                    Sketchup.send_action('performMiniaturize;')  ## Minimize  ### ⌘M
                                    Sketchup.send_action('performZoom;')  ## Zoom
                                    Sketchup.send_action('showModelPropertiesPanel;')  ## Model Info  ### ⇧⌘I
                                    Sketchup.send_action('entityProperties;')  ## Entity Info  ### ⌘I
                                    Sketchup.send_action('orderFrontColorPanel;')  ## Materials  ### ⇧⌘C
                                    Sketchup.send_action('showComponentBrowser;')  ## Components
                                    Sketchup.send_action('showStyleBrowser;')  ## Styles
                                    Sketchup.send_action('showLayerPanel;')  ## Layers
                                    Sketchup.send_action('showOutliner;')  ## Outliner
                                    Sketchup.send_action('showPagePanel;')  ## Scenes
                                    Sketchup.send_action('orderFrontFontPanel;')  ## Show Fonts  ### ⌘T
                                    Sketchup.send_action('showRubyConsole;')  ## Ruby Console
                                    Sketchup.send_action('showShadowsPanel;')  ## Shadows
                                    Sketchup.send_action('showFogSettingsPanel;')  ## Fog
                                    Sketchup.send_action('showPhotoMatchPanel;')  ## Match Photo
                                    Sketchup.send_action('showSoftenEdgesPanel;')  ## Soften Edges
                                    Sketchup.send_action('showInstructor;')  ## Instructor
                                    Sketchup.send_action('browse3DWarehouse;')  ## 3D Warehouse
                                    Sketchup.send_action('browseExtensionStore;')  ## Extension Warehouse
                                    Sketchup.send_action('toggleInspectors;')  ## Hide Dialogs
                                    Sketchup.send_action('getPhotoTexture;')  ## Photo Textures !!!!!!!!!!!! not working
                                    Sketchup.send_action('arrangeInFront;')  ## Bring All to Front
                                  # Help
                                    Sketchup.send_action('showWelcomePanel;')  ## Welcome To SketchUp…
                                    Sketchup.send_action('showOnlineHelpCenter;')  ## Knowledge Center
                                    Sketchup.send_action('contactUs;')  ## Contact Us
                                  # Orphans
                                    Sketchup.send_action('fixNonPlanarFaces;') ## Model Info >> Statistics >> Fix Problems
                                  I may have missed some...
