    Visual Problems on one model, others fine
    9 Posts 3 Posters 763 Views 3 Watching
    • kuponoK Offline
      kupono
      Using SU 8 Pro, a 1.2MB model has suddenly gone visually wacky with major aliasing. It was working fine, then it wasn't. If I open an old 20MB model, it works fine. Rebooting did nothing.
      I'm using an old machine with a built in graphics driver, Mobile Intel(R) 4 Series Express Chipset. I know this isn't a recommended setup, but it's been working fine for me.
      I had the same problem with all models using SU 2013 and uninstalled it
      What can cause a file to just go bad?
      Funky Visuals
      • Chris FullmerC Offline
        Looks like you got an issue with an object being far away form the model origin. Or you might have a component with an origin set far away from the geometry of the component.
        Can you upload the model here for us to take a look at?
        • kuponoK Offline
          kupono
          I saved various components from the problem model and opened them individually with the same visual funk. I opened a different "good" model that didn't have the visual virus, and imported the funky model into it. It looked fine--no jaggies. I saved that component, then opened it by itself, and--drum roll please--it looked fine. Importing then exporting fixed it.
          For some reason, out of the blue, the model went bad. Not only that, but all of it's offspring were bad too. The open-gl settings are the same on both the good and the bad models. In fact, the bad model was originally a component saved from the good model.
            Well, I still have the same answer for you as before. πŸ˜„
            • kuponoK Offline
              kupono
              lots of jaggiesApologies for not uploading a file previously. The problem resurfaced on a new machine. I've attached a small subset of the model with the same rendering issue.
              Thx
              Sketchup Pro 2013
              The screen quality of a 28MB model I'm working on just went bad. It went from clean edges to jaggies all over the place with edges that should be hidden, exposed. No changes were made to the OpenGL settings, or other settings of any kind. I had just placed a section plane. It's as if the model exceeded SU's capacity for rendering. This happened to me on the same model and others before, but on an older laptop with Intel integrated graphics. In response I bought a new laptop with the following specs.
              i7-3630QM CPU @ 2.4GHz
              16GB ram
              NVIDIS GeForce GT750M, with the latest driver: 9.18.13.2049 (openGL compatible). The NVIDIA control panel is set for application control of anti-aliasing.
              With this new machine, prior to the current breakdown, the image quality was good, though there was some aliasing at close zoom. Other, smaller models displayed with excellent quality with no or extremely little aliasing at zoom.
              SU installed with these OpenGL settings:
              Hardware acceleration checked,
              Use fast feedback checked,
              #63, True Color Medium, Shadows=Yes, anti-aliasing = 0x.
              I changed this to setting:
              #40, True Color Medium, Shadows=Yes, anti-aliasing = 4x.
              Despite the anti-aliasing difference there was no improvement in the display.
              Oddly enough, once I had selected #40, #63 was no longer available. It disappeared from the available options. When I unchecked hardware acceleration and restarted, settings #101 and #102 became available, both with 0x anti-aliasing. Neither worked well. Upon rechecking hardware acceleration, setting #63 (shadows) made a reappearance along with #13 (no shadows). Neither selection helped the display, though selecting #13 made #63 disappear again. I chose setting #40 for want of anything better.
              The OpenGL settings dialog is kind of a black box in which selection results don't seem to make any logical sense. It's like turning your car steering wheel right, but continuing straight, or maybe turning left. I have no idea what maximum texture size does. It had no effect on my display whatsoever.
              Now for the oddest behavior.
              Having some experience with this in the past with my old laptop, but with SU8 Pro, I tried a strategy that I've had success with. I selected a component of the large problem model (LPM) and did a save-as. I closed SU, then opened the saved skp file. This subset of the large model, was only 8.5MB. I hypothesized that if the LPM had exceeded some king of SU limit, this small problem model (SPM) should be well under that limit and render properly. As in the past, this was not the case. The SPM rendered with the same jaggies, exposed hidden lines and general visual mayhem as the large model had. So much for the exceeding limits hypothesis.
              With the old machine I discovered that if you import a problem model into a working model, the problem goes away. So, I closed the SPM, created a new model, then imported the SPM into it. As expected, it displayed as it should. No jaggies, no weird behavior. The problem disappeared.
              If it worked for the SMP it should work for the LPM, and it did. I imported the LPM into a new model and it displayed fine. That's all well and fine, but the question is why?
              I believe I can conclude that:
              • because I've observed this behavior on two very different systems, the problem is not hardware related.
              • because the exported SPM had the same problems as the LPM, it's unlikely that a SU capacity was exceeded.
              • if the capacity of SU wasn't exceeded, and it's not a hardware issue, it could be a corrupted file.
              If it's a corruption problem, what would have caused it? In this case, nothing had changed with any settings, or on the model. I had just placed a section plane when the display went wonky, though I had recently placed many section planes without any problems.
              Has anyone else had this experience?
              • kuponoK Offline
                kupono
                Anssi on the Sketchup forum suggested I switch from parallel projection to perspective. I did and the the rendering was instantly restored to perfect. I switched back to parallel and the rendering remained perfect. That's a mighty simple fix for a problem that's been vexing me for a while. Odd behavior though for sure.
                  Yeah, that is odd. When you switch to perspective, it jumps waaaaaay out, which indicates that the parallel camera is position super far away from the geometry, but is somehow zoomed in super close. Its that distance between the camera object and the model that is causing the problem. I'm not sure how you got it into that state, but I'm glad you've got a fix.
                  Do you run any plugins that might affect the cameras? Any renderers or camera tools or anything?
                  • jeff hammondJ Offline
                    hey chris.. i managed to make this happen.. (amongst a few other oddities which may occur instead when doing this)..
                    get a normal looking perspective view of a model.. zoom way out til the axis start jumping/disappearing etc.. switch to parallel projection.. observe πŸ˜„
                    here's one that's more weird than kupono's example:
                    hmmmm.skp
                    switching to perspective then zoom extents will bring it back to normal
                    • kuponoK Offline
                      kupono
                      Nope, no renderers, camera tools or other plugins that may affect this.
