    SU 2013 - SLOOOOOW on orbit and group exit?
    12 Posts 6 Posters 863 Views 6 Watching
      samyell77
      Installed SU 2013 yesterday and am finding it pretty laggy compared to the previous version. On exiting groups, orbiting and zooming too there is a fairly long pause while SU thinks about it. Frustrating!
      Anyone finding this?
      Sam
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
      • mitcorbM Offline
        mitcorb
        Hi samyell:
        You didn't indicate your graphics card(s). Just in case it is a display issue.
          samyell77
          Hi Mitcorb
          its an ATI FirePro V4800
          Have added a file with my complete machine spec...
          My colleague has the same machine and the same problems but another colleague with a laptop is running with no issues?
          Sam
          DxDiag.txt
          SU Pro 2016
          PC Windows 10
          16gb RAM
          • mitcorbM Offline
            mitcorb
            Hi.
            Google searching "ati firepro v4800" gave one address that had the product. AMD indicated that this device supports OpenGL 4.2 Looking at your txt document- I may have missed it- there was no mention of OpenGL. That doesn't mean it is not there.
            The standard suggestions are to try Hardware Acceleration on/off in the Window>Preferences>OpenGL parameters.<
            And, you can verify how the card is implemented on your system of course, by going to windows Control Panel and adjusting.
            While this article may not apply to your case, perhaps you would want to read:
            http://productforums.google.com/forum/#!topic/sketchup/lRIB-0AlAIQ
            The several responders also visit this forum.
              samyell77
              Im using Pro ....
              Turned hardware acceleration off and it seems a little better. Mitcorb - I'll read the page you sent shortly to see if there is anything else I can try. Thanks for your help and speedy response.
              Sam
              SU Pro 2016
              PC Windows 10
              16gb RAM
                That sounds like a graphic card/driver issue then. It shouldn't be faster to turn off Hardware Acceleration. Have you tried to update your drivers?
                  samyell77
                  Will try now...
                  SU Pro 2016
                  PC Windows 10
                  16gb RAM
                  • Chris FullmerC Offline
                    @anton_s said:
                    Yeah... The API on SU2013 Make was made slow on purpose, so that we would urge to buy Pro.
                    Hi Anton, that obviously is untrue, please stop saying it. Thanks!
                    • mitcorbM Offline
                      mitcorb
                      I found a bookmark regarding the OpenGL/graphics card issues that I should have remembered. This is an excellent reference for a lot of issues:
                      https://sites.google.com/site/sketchupsage
                        samyell77
                        Thanks - much appreciated. Not got to the bottom of it yet as have been rushing to get something done (typical timing!) but will take a look at the bookmark you sent and see if I can suss it.
                        Cheers
                        Updated driver and it had no effect on one (very old and messy) file but another one Im working on now seems to be ok. Will test tomorrow with more time....
                        SU Pro 2016
                        PC Windows 10
                        16gb RAM
                          Anton_S
                          Nvm, I was wrong 😳
                            srknytgn
                            I was troubling with the same issue, but I've found that it was not arise from driver update. By erasing SectionCutFace plugin the problem was resolved. You may try to examine what plugin cause this.
