    Toolbar Help
    extensions
    4 Posts 3 Posters 562 Views 3 Watching
    • C
      chaluga
      Hey,
      I have taught sketchup for five years at the middle school level and yesterday updated to version 13. Took me a few minutes to get used to some of the changes. Figured out how to install plugins and collect them in a folder to later put on the other 30 machines in my lab.
      When I installed the plugin toolbar editor it wouldn't run citing a javascript error. I have created dozens of tutorial videos and help pages for my students based on a menu/toolbar style. I had large tool set along the left side in a double column. When I try to put large tool set on the left in 13 it makes a single column and you can't see stuff. Even at small icon (I wouldn't use.. too small) its not all there.
      End of the school year and I need help. Is there an easy way to get double column toolbar on left side of screen ?
      Is there another plugin/extension that would do this ?
      thanks for any help !
      23 school days left !!!
        Version 2013 only supports single row/column toolbars.
        So make two [or more] bars the desired length/height and simply dock them side by side.
        It's not so hard to redo the code into two bars ?
        There is no magic solution to this - just some work. πŸ˜‰
        • BoxB
          And with only 23 days to go you are probably better off sticking with SU8 for now and upgrade for next school year.
          • C
            chaluga
            Genie out of the bottle, can't go back to version 8 since many of my students worked on project at home in version 13.
            As far as writing code I don't have the background to do that. For now I just scaled large toolset in three columns and have it floating close to the edge.
            Anyone else have a problem with toolbar editor extension not working ?
