    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      @krisidious said:
      On SU 2013 Win, I'm getting this error on startup.
      no such file to load -- 3darcstudio/3darcstudiotree.rbs
      Error Loading File 3darcstudiotreeloader.rb
      The file is in the location specified.
      I just downloaded and installed SU 2013 Make on Windows 7. And copied the 3darcstudio zip content to the plugin directory.
      Seems to work fine.
      Are you really sure you copied the subdirectory "3darcstudio" into the SU 2013 Plugins (not the Google old one)?
      • ppoublanP Offline
        ppoublan
        @chris fullmer said:
        So instead of
        t = Geom::Transformation.scaling(scale_factor)
        Do this:
        t = Geom::Transformation.scaling(scale_factor,scale_factor,scale_factor)
        That way it won't write the scale value to the 16th position, but will in fact do the math and distribute it across the entire matrix.
        Thanks Chris, I will change the code according to your sample.
        • Chris FullmerC Offline
          @driven said:
          PM Chris Fullmer re the scaling, I think he may have an answer...
          Tis True! This is a known bug introduced in 7.1. Scaling globally by applying a scale factor to the 16th matrix position is bugged. So instead of
          Do this:
          If you need a code snippet to reset the scale of a component to a bug-free transformation matrix, I could post that as well.
          Besides the fact that some renderer's don't take this global scale feature into account, a lot of video cards also do not. We've had reports that fog will not work correctly on components with the global scale, and face-me components also do not account for it. So if the leaves are set to face-me, it can cause a lot of craziness πŸ˜„
          I guess we can take this discussion over to the developers forum if you want to talk more about it. Looks like an awesome plugin!
          • ppoublanP Offline
            ppoublan
            @solo said:
            @pixero said:
            @solo said:
            This is awesome, sure there are a few small things but wow! this is going to be a zinger of a plugin.
            Anyway to get a console/applet for modifying the parameters and an update button?
            If you rightclick on the tree you can change parameters. Is that what you wanted?
            I saw that, what I'd like is a console/applet where I can do all the changes and update without clicking out to see results then right clicking to make more changes.
            I think I understand this request. I was myself really disappointed when I wanted to add more input parameters with the poor input types that can be used with UI class.
            It will take some time to build it as I'm really a beginner with html and applets. Does someone could confirm SU 2013 has or not better features to build user input data interfaces ? Or should I go any way with Applets and html code ?
            Yours
            Pascal
            • KrisidiousK Offline
              Krisidious
              everything seems to be in it's rightful place.
              By: Kristoff Rand
                Do you have FULL security permissions to the Plugins folder AND all of its contents - files and subfolders...
                v2013 will be installed with the defaults, not how you might have adjusted the settings for v8 Plugins...
                I'm wondering if you don't have permission to 'read' from the subfolder in v2013... πŸ˜•
                Another possibility is that the subfolder/files are NOT actually where you think they are - the dreaded 'VirtualStore' issue... Windows over zealously protecting you from yourself without telling you what it's done...
                Look in C:/Users/UserName/AppData/Local/VirtualStore
                If there are any subfolders matching the SketchUp 2013 Plugins folder, then your security permissions are definitely skewed... πŸ˜’
                • ppoublanP Offline
                  ppoublan
                  @driven said:
                  hi
                  One request I would have is to allow loading from other Folders/Directories, it appears to be hard coded to Plugins Folder.
                  Hi John,
                  Could you explain what do you means by "allow loading from other Folders/Directories". Is it to be able to save and load tree templates from other dirs ? I'm building my "todo" list but for this feature I do not know how to manage PC and Mac files and directories from the same code. This is easy with builtin sketchup plugin directories. Will have a look.
                    Krisidious
                    that virtual folder did exist and there were file from Version 8 in it... some en files, a template and some appliance components. but no files from 2013.
                    as for permissions... CREATOR/OWNER has none, and when I try to set them it just re-sets to blank. User and Trusted installer, has all permissions, administrators has them all checked and greyed out.
                    By: Kristoff Rand
                    • ppoublanP Offline
                      ppoublan
                      To be sure if it has to do with folder rights and virtual store, try starting Sketchup with admin rights (right click on sketchup icon and choose run as admin..."), and see if the error still occurs.
                        Krisidious
                        Tried and still the same error.
                        By: Kristoff Rand
                          Can be apply other things than trunck ? (as textures/material or as components)
                          Can be apply other things than branch ? (as textures/material or as components)
                          Can be apply other things than leaf ? (as textures/material or as components)
                          • ppoublanP Offline
                            ppoublan
                            Can be apply other things than trunck ? (as textures or as components)
                            Can be apply other things than branch ? (as textures or as components)
                            Can be apply other things than leaf ? (as textures or as components)
                            Hi Pilou,
                            If your question is how to add your own textures and leaves/flowers types, here is how it works now :
                            • textures available are all "*.jpg" files that exists in the 3darcstudio plugin dir.
                            • leaves/flowers components are all "*.skp" files that exists in the 3Darcstudio plugin dir.
                              So you can easily add your own by copying your files into this dir.
                              Be careful when defining your own components to make the origin of the component at the beginning of the leaf, and the leaf pointing to the sky (z direction), with size arrong 10 cms long.
                            • ppoublanP Offline
                              ppoublan
                              Tried and still the same error.[/quote]
                              Arghh...! do not understand why. Maybe try to delete files and copy them again to be sure file has not been corrupted. Does it work with SU8 ?
                                Krisidious
                                No, it doesn't work on either 8 or 13... Tried deleting. nothing changes.
                                Just my luck.
                                By: Kristoff Rand
                                  Cool! β˜€
                                  πŸ˜‰
                                  http://www.web-libre.org/medias/img/articles/a501bebf79d570651ff601788ea9d16d-2.jpg
                                    Let's try some testing with the Ruby Console...
                                    Copy paste these lines + <enter>
                                    path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
                                    Then this
                                    File.exist?(path)
                                    which will return 'true' or 'false'...
                                    If 'false' that's plain weird as you can 'see' it !?
                                    Check the exact spellings, compared to the error messages etc the 'loader text is '3darcstudio/3darcstudiotree.rbs'
                                    If it's 'true' then try...
                                    load path
                                    If it's 'true', then the code in the rbs file has loaded and the menu/toolbar etc should be available, as if the Extension had been loaded and activated...
                                    What happens ?
                                      Krisidious
                                      Then this
                                      File.exist?(path)
                                      True
                                      load path
                                      I get. on Load Path
                                      Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
                                      (eval):155
                                      (eval):155
                                      By: Kristoff Rand
                                      • ppoublanP Offline
                                        ppoublan
                                        @kaas said:
                                        Hello Pascal,
                                        Just had a go with the plugin. It works really fine already!
                                        My 2 cts:
                                        1. if I right-click and adjust any part of a tree it also generates new elements for every other part of the tree. I understand changing the branches should also change the position of the leaves but changing the leaves atm also changes the trunk, not really what you want if you're fine tuning a tree
                                        2. i might be a nice feature if one could control the size / length of the branches (size decrease or increase by x %) depending on the position on the tree (higher up the tree = make branches less long by 50% etc).
                                        3. ditto for the leaves - for instance smaller leaves near the end of a branch.
                                        edit: 4. adjusting a tree reloads all materials and textures. If you-re fine-tuning a tree and already edited one of your materials you have to do that again and again.
                                        Greetings,
                                        Max
                                        The tree is entirely rebuilt each time a single parameter is changed (as almost all parameters have impacts on others"). Something I do not know how to fix.
                                        But the lenght of the brenches in fact are varying based on their position on the tree as you are asking for. This is managed by the "tree shape" parameter (pyramidal, spherical, ...) . See the pdf doc for this parameter.
                                          kaas
                                          Hello Pascal,
                                          My 2 cts:
                                          edit: 5. the textures for the bark must be located in the 3d arcstudio directory. The same for the models of the leaves. Many people have all their content on (shared and backupped) network drives. It would be great if one could make a redirection to external folders for the textures and a different one for the leaf-models.
                                          Greetings,
                                          Max
                                          • ppoublanP Offline
                                            ppoublan
                                            @krisidious said:
                                            I get. on Load Path
                                            (eval):155
                                            (eval):155
                                            Strange. Really seams the file is corrupted. Could you try deleting all local files from 3darcstudio, and downloading it again after emptying your browser cache from the web site (http://www.3darcstudio.com)
                                            Looks like Sketchup unable to read/interpret source code rbs file :
                                            • the script start with : =begin and =end remarks lines so they should be ignored
                                            • no "." dot character used without the number 0 before, maybe wrong interpretation of the decimal point
                                            exact size of rbs file on my computer is 193Β 410 octets
                                            • 16
                                            • 17
                                            • 2 / 17
