    ? about file size/polygon count
    25 Posts 5 Posters 1.9k Views 5 Watching
      mac1
      Follow good techniques is your best bet vs worrying about specific numbers. Follow tips here https://sites.google.com/site/sketchupsage/faster
        Rose123
        Mac -thanks for the link, there is good info there. I do a lot of those, but I would like to know if there's a recommended size range for a manageable model (one that focuses on home interiors).
        • KrisidiousK Offline
          Krisidious
          @rose123 said:
          Krisidious -what kind of models do you make that are so large? Are these houses, as I see from your sig? What in them makes them so large? Lots of imported, high-res textures?
          I ask because I am specifically wondering what a range for a house should be. No landscaping, mostly just a focus on the interior. Or a size for just one room, like an elaborate kitchen or bath.
          Actually that one I described is a car, really 4 cars all in one. However some of my houses get pretty big. normally the culprit on large file size is plants, trees, furniture and land and normally these can be optimized for better use.
          Most of my houses end up being under 50 megs.
          This building is 42 megs and it's fully furnished.
          By: Kristoff Rand
            Rose123
            Wow, great models! Thanks for the info.
              Krisidious
              Thanks... Now it's your turn.
              By: Kristoff Rand
                Rose123
                your turn
                http://i83.photobucket.com/albums/j320/DrawMeAPicture/myhouse_zps52e7b0a9.png
                • Alan FraserA Offline
                  Alan Fraser
                  Actually, file size isn't all that important...except as a general indication of complexity or if you need to email it to someone.
                  What really counts is the amount of geometry in the model. This translates as the number of nodes/endpoints that SU has to keep track of.
                  Generally, your faces are going to be quads or tris, with the odd circle or arc thrown in for good measure, so the number of edges tends to be around 4x the number of faces.
                  There are exceptions, however...like if you decided to model a sycamore tree containing a leaf component that, although it was only a single face, had a nicely detailed outline needing 50 edges. No use congratulating yourself that you modeled a tree with only 2000 faces if it has 100,000 edges. A few of those babies are likely to slow you to a crawl.
                  My general rule of thumb is that in most arch-viz/interior design situations you are unlikely to get closer than about 3 ft from anything in your renders...so detail it accordingly. For interiors which don't require a plan view, I'd tend to use 2D plants. If necessary, stick them in a 3D pot so they interface more convincingly with the floor or tabletop
                  3D Figures
                    Rose123
                    Alan -so is it possible to have a low file size, but high in geometry (and hence run slow)?
                      Alan Fraser
                      Absolutely, Rose. I started a notorious thread some years ago called Geometry is Everything.
                      It had a repeated component of an image-mapped Corinthian column...1000 of them if I remember correctly. It was 125Kb...that's Kb not Mb...and killed most people's system stone dead. πŸ˜„
                      EDIT:
                      Correction. Apparently it was 187Kb...but only 100 columns
                      columns.skp
                      3D Figures
                        Rose123
                        Froze mine up for a bit, too. That's a lot of columns! Ok, I see your point, it's geometry, not file size. Thanks!
                          Rose123
                          Another one for Krisidious. I'm off to put some columns in it now...
                          http://i83.photobucket.com/albums/j320/DrawMeAPicture/5-23-20135-57-51PM_zpsc7d6ac7f.png
                            Krisidious
                            that looks challenging. and decrepit.
                            By: Kristoff Rand
                              Rose123
                              Ok, one more question, if you don't mind! In the statistics I can see the number of edges, faces, etc. Is there a range for that in which a model should fall? Like what would be small vs large?
                                Krisidious
                                Well I would say that once you get past 100,000 faces you're going to star noticing... When you go to rotate around your model view you will notice at some point that SU will make your model into a ghost of itself to rotate more quickly and easily. This is the first clue you're getting too big.
                                By: Kristoff Rand
                                  Rose123
                                  A ghost of itself? I just get a freeze and the message, "The program is not responding."
                                    Krisidious
                                    The entire model will change to a type of greyed out, simplistic version of itself often showing a bunch of group/component constraints.
                                    You get program not responding while rotating around the model? Or while performing a function?
                                    One thing about SU, at least the old version, is that while it's thinking you should not attempt to do anything within the software and you might consider not doing anything with your computer period, until it finishes thinking. some plugins that are doing critical calculations use the progressbar.rb to show you what's going on, some don't... You'll learn one indicator is what type of cursor you can see at the time. black for ready to work, white for thinking. Others might be able to shine more light on this for you.
                                    By: Kristoff Rand
                                      Rose123
                                      I think I have a different SketchUp, the low-rent version or something, lol. Don't know about old, I have 8. I've never gotten a different color cursor or a grayed out model. If the file (geometry, whatever) is too big, it just runs slow and then freezes up.
                                        Krisidious
                                        V8 is just the last version as of a day or so ago. V2013 is the latest.
                                        You could share your model and we could look at it. You could try Goldilocks 2.0 to find what is so big... http://sketchucation.com/forums/viewtopic.php?p=281153#p281153
                                        What are your system specs?
                                        By: Kristoff Rand
                                          Alan Fraser
                                          Normally, SU will go through a progressive series of display abbreviations as you attempt to navigate a complex model.
                                          In that columns skp I posted earlier, when it's first opened, you will probably find the SU initially refuses to do anything at all for quite a few seconds. However, once it 'gets used to' the model you will most likely find that you can actually rotate it...but you'll lose shadows, all the texturing on the columns...and all the fine detail up top, like the acanthus leaves, is replaced with simple bounding boxes.
                                          3D Figures
                                            Rose123
                                            Alan -oh, I understand now about the display abbreviations. Yes, I've seen that.
                                            Krisidious -I wasn't referencing one model in particular, just in general. Re my system specs, just standard off the shelf. What I have noticed is the difference a specialized video card makes in display, screenshots and exports. At work we have GTX 6000 series cards. I mention this because I've seen past posts from people complaining that their exports look jagged, and answers that suggested plugins and other stuff, but not the video card.
