    Sketchup 2013 issues
    208 Posts 53 Posters 21.6k Views 53 Watching
    • Chris FullmerC Offline
      Hi Ken, the little sad face means that for some reason the icon for the toolbar was not found. Try deleting any plugins that have those little sad faces and try re-installing official versions of them. Thanks!
      • kenK Offline
        ken
        Could I make a small suggestion. Since I can have Sketchup 8 and Sketchup 2013 open, could the header in Sketchup 2013 have the label "Sketchup Pro 13" so that I don't make a mistake in what version of the program I am running.
        Ken
          Not a bad suggestion. Its too late at this point, but it could be a feature for the future. For now, you can differentiate by the default tool icons, if that helps.
          • arail1A Offline
            arail1
            Not impressed.
            I've entered my SU8 serial number, the serial number I just got after paying for an upgrade, my name, my company name - nothing works. I've never had any problems upgrading to the next version of SketchUp - it's always been seamless, easy, no thought required.
            This on the other hand is confusing - what are they asking for - the license from my SU8 version? The new license they just sent me? Doesn't matter because neither one works.
            So, the first appearance of Trimble SketchUp and - no improvements (according to people who successfully downloaded the program) and a mess of an upgrade process.
              Hi Arail, sorry its not working for you - yet!
              SketchUp 2013 uses a new license, so the one from SU 8 is not valid. But if you were given a new license number, then you should be able to enter that information and get it to upgrade. PM me if you can't get it to work, thanks!
              • KrisidiousK Offline
                Krisidious
                I didn't even know this was out... Where have I been? how much is the upgrade? Answer $95.00
                Now what do I get? Ummm is the only new feature the Extension manager? Everything in SU and Layout looks the same to me.
                By: Kristoff Rand
                  circus
                  I am running on a mac OS X 10.6.8? Sketchup 2013 will not install? Does anyone know if there is a work around for this....for I havent the cash to purchase a new computer?
                  P.
                  • jeff hammondJ Offline
                    P.
                    what mac can run 10.6 that can't go to 10.7?
                      circus
                      ?? I am on a mac book pro, Processor 2.16GHz Intel Core 2 Duo Memory 4 GB, while I haven't tried to upgrade to 10.7 or later, and not being technically minded, I was lead to believe that I am unable to upgrade?
                      p.
                      • arail1A Offline
                        arail1
                        Toolbar question:
                        Where are the toolbar icons stored?
                        There is a tool on the Getting Started Toolbar (Send to Layout)that I tried to drag to another toolbar but I dropped it between toolbars accidentally and it disappeared. How can I get it back?
                          Click on Reset in the toolbars window. That should put the button back.
                          • Dan RathbunD Offline
                            Dan Rathbun
                            (1) Open the "Toolbars..." dialog.
                            (2) Select the "Getting Started" toolbar.
                            (3) Press the "Reset" button.
                            (4) Hold the "CTRL" keyboard key when you drag buttons so they copy instead of move.
                            I'm not here much anymore.
                            • arail1A Offline
                              arail1
                              Thanks all. That works.
                              • kenK Offline
                                ken
                                I am surprised the number of toolbar icons that were 32x32 or 24x24 instead of 16x16 for small. It wasn't that visually apparent in Ver 8, however, it was apparent in Ver 2013.
                                I went though and changed all the icons that were not at 16x16 and now my toolbar displays looks OK if not great.
                                Ken
                                • arail1A Offline
                                  arail1
                                  Interesting to note that I got my first sales pitch from Trimble (for a laser level) - 1/2 day after giving up my info to purchase an upgrade.
                                  • charly2008C Offline
                                    charly2008
                                    I have copied my plugins folder from Sketchup 8 into Sketchup 2013. So far no problems except for these two plugins. In Sketchup 8, this error message does not appear! I am a bit perplexed because these plugins are not available in the original folder of SketchUp 8.
                                      It seems there isn't. I used Jim's custom toolbar plugin with some additional buttons for toggling hidden geometry, parallel and perspective camera, profiles, endpoints etc (which do not have toolbar buttons) but unfortunately that plugin does not seem to work in SU 2013.
                                        Krisidious
                                        So no way to add other native commands to a custom toolbar?
                                        Google icons can't be moved to Sandbox bar?
                                        By: Kristoff Rand
                                          Krisidious
                                          Well, at least this is good news for Jim and his custom toolbar plugin.
                                          By: Kristoff Rand
                                            Why would it be good news if it does not work?
                                            • 11
                                            • 4 / 11
