    [Plugin] Animatex v1.0.6
    38 Posts 13 Posters 33.2k Views 13 Watching
    • ElibjrE
      Elibjr
      Nice!
        Can you input a GIF animated as texture ?
        • renderizaR
          renderiza
          Not at the moment but maybe in the future something like that can be implemented.
          Here are some plugins that can play a sequence of images much like a gif;
          [Plugin][Code]SKMtools,MaterialTools,ImageTools110225:
          http://sketchucation.com/forums/viewtopic.php?p=293677#p293677
          [Plugin] jpg_gif (Updated 22/12/2010):
          http://sketchucation.com/forums/viewtopic.php?t=33054
          Again thanks everyone for the questions & comments! ๐Ÿ‘
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          • renderizaR
            renderiza
            Just realized texture don't animate if face is inside a group or component so will be try to solve that in the future.
            • renderizaR
              renderiza
              Animatex v1.0.2 Released!
              Now with v1.0.2 you can animate multiple faces on each of the three separate layers that can control different x,y,z speeds.
              Will make quick video soon explaining the new features so expect that soon.
              http://s8.postimg.org/ux2hecd6d/animatex_dlg.jpg
              • renderizaR
                renderiza
                Animatex v1.0.3 Released!
                Now with v1.0.3 you can animate multiple faces on each of the three separate layers that can control different x,y,z speeds. Animatex now works while transitioning between scene camera animation without lag. Will make quick video soon explaining the new features so expect that soon.
                http://s23.postimg.org/4i96v6fvf/animatex_dlg.jpg
                • renderizaR
                  renderiza
                  Animatex v1.0.4 Released!
                  Animatex works with groups now!
                  Note: Thanks to TIG and Thomthom for helping me solve the issue on the development forum!
                  • CadFatherC
                    CadFather
                    Thanks Rafael - from strength to strength. ๐Ÿ‘
                      raineysky
                      Renderiza,
                      First off this is a very nice plugin. Question: Will it work with round objects like pipes? I would like to simulate water flowing through a pipe. Also, can I make the water flow to the left instead of the right? Probably a dumb question but I can't change the direction.
                      Thank You,
                      Paul
                      Edit: Figured out the second question. Make it a negative number ๐Ÿ˜„
                        raineysky
                        Thank You!!!
                        • renderizaR
                          renderiza
                          raineysky :: Will it work with round objects like pipes?
                          The plugin will animate any face with a texture that is inside or outside of a group but it can't be nested in a group withing another group and also it is not working with face inside Component Instances at the moment. ๐Ÿ˜•
                          With this in mind you can have animated textures on round objects but since the texture x,y,z coordinate are set by face and not globally like for example projected faces, it will mess the uvs coordinates if you used projected texture if that make any sense.
                          Now you pointed out that you are using water so it may still look decent...I might include an example of this on my upcoming video. ๐Ÿ‘
                          raineysky :: Also, can I make the water flow to the left instead of the right?
                          You can use negative sign to specify x,y,z to move in opposite direction. For example;
                          x= -1 , y= -6 , z= -10
                          Hope this helped...Cheers!
                          • renderizaR
                            renderiza
                            I corrected the message since 2nd time I read it wasn't what I wanted to mean so here is another try on that sentence...
                            Cheers!
                              raineysky
                              Thank You for the videos. This plugin is awesome!!! I finally got water flowing through the pipes ๐Ÿ˜ฎ
                              • lovesketL
                                lovesket
                                A very good plugin RESPECT ....! Now together with mover2 are two my lovely plugins ever for sketchup...The only think on Animatex is the large page during the work.. is not practic, if is possible to change page, like mover2 for example...is better..thnx
                                • renderizaR
                                  renderiza
                                  Animatex v1.0.5 Released!
                                  Hi, this is a small update for Animatex.
                                  Now Animatex is an extension that you can see under Window > Preferences > Extensions. With a quick click, you can learn some info about plugin and can even turn it on and off.
                                  Also this update attempts to fix some buttons that were not showing on some web-dialogs and also removed some that were not needed.
                                  http://s22.postimg.org/o7b7revj5/dlg.jpg
                                  • renderizaR
                                    renderiza
                                    Animatex v1.0.6 Released!
                                    Hi, this update was all about to make Animatex follow the requirements to be posted on Extension Warehouse. The plugin is still in revision but hopefully you will see it soon but why wait go ahead an download it now from SketchUcation. ๐Ÿ‘
                                    Cheers!
                                      What screen recorder are you used for the videos?
                                      • renderizaR
                                        renderiza
                                        I used Active Presenter which is free.
                                        http://atomisystems.com/activepresenter/free-edition/
                                        I also use Frapswhich only captures viewport and ignores things like cursor, toolbars and so on. This screen capturing software reduce lag and preserve frame rate really well but its not free.
                                        http://www.fraps.com/
                                        Cheers!
                                          thx for the infos! ๐Ÿค“
                                          • P
                                            Pic Assaut
                                            Realy Great plugin i think that the last version'll be one of the best tools for Designers
