    [Plugin][WIP] Layers Panel - Dev
    45 Posts 11 Posters 12.6k Views 11 Watching
      @jiminy-billy-bob said:
      @thomthom said:
      Safest thing is to keep everything in your own namespace.
      It thought I did. Can you show what piece of code is wrong ?
      The snippet that modified Sketchup::Layer .
      @thomthom said:
      (note I flipped the quotes)
      Is there a reason for that ? It's better that way ?
      Because with double quoted strings you can do interpolation - like this "Hello #{some_variable}" where as in single quoted you cannot.
      • jiminy-billy-bobJ
        jiminy-billy-bob
        Ho, ok. I assumed TIG's work was clean. But this snippet is actually 4 years old, I guess he wasn't aware of that back then.
        Thanks !
          Basically, any modification of the Ruby or SketchUp API classes is bad practice. So are global variables.
          There's some old code lingering around from the days before people started to figure out what best practices where.
          • jiminy-billy-bobJ
            jiminy-billy-bob
            If I understand ruby classes correctly, I have to rewrite the code, right ?
            I can't have something like layer.delete() while keeping it in my own namespace. Am I right ?
              Correct. Make a method under your own namespace that takes the layer as an argument.
              Not as pretty, but it'll work and it will be safe from clashing with anything else.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Ok, here is a new version.
                • Added Toolbar and menu item (Window > Layers Panel), with toggle
                • Change things you TT told me : Undo, +operator, filename...
                • Deleting layers now work properly. The method is wrapped in my namespace. When a layer has geometry, you are promped to choose to delete the content or move it to the default layer.
                • Added a menu for some options. For now you can only purge layers.
                • I also don't have bugsplats anymore. Don't know why exactly... If people get some, please tell me.
                Still no saving, I'm getting used to ruby before attacking this big piece.
                Also, I can't get my WebDialog callbacks to work if the dialog is not in a global variable. I tried local, instance, and class variables, nothing works. What am I doing wrong ?
                Layers Panel 0.02.rbz
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Hmm, so a class variable in a class ? That makes sense ^^
                  Thanks for the tip, I'll try that.
                  • renderizaR
                    renderiza
                    I hope that naming the Class "TEST" didn't confuse you since the class name doesn't have anything to do with the variables (var test = true) in html. 😕
                    I guess what i am trying to say is that the "var test" in html has nothing to do with "Class TEST" in ruby.
                    Not sure if you are confusing them both but just in case. 💚
                    Note: Will edit the name of the class on my last post to "PLUG".
                    [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                    • renderizaR
                      renderiza
                      If you want to change something from ruby to web-dialog you can do this...
                      In Html & Javascript:
                      <html>
                         <head>
                            <title>Example</title>
                         </head>
                         <body onLoad="startup(), stopwatch(this.value);">
                         </body>
                      </html>
                      <script>
                      var delay = 1000/5 ; #this will update 5 frames per second
                      var timerID = false ;
                      var test = true ;  #this is the value you will change from ruby
                      function startup() {
                      nextFrame();
                      function stopwatch() {
                      SD=window.setTimeout("stopwatch();", 100);
                      function nextFrame() {
                         try {
                            test = test
                            setFrame() ;
                            top.timerID = self.setTimeout("nextFrame()", delay) ;
                         } //try
                         catch (e) {
                            alert("push_frame; " + e) ;
                      } //nextFrame()
                      function setFrame() {
                      url = 'skp;push_frame@' ;
                         url += '&test=' + test;
                      window.location.href = url ;
                      </script>
                      In Ruby:
                      module SU_PLUG
                         class PLUG
                            @@model = Sketchup.active_model ;
                            @@dir = File.dirname(__FILE__) # this plugin's folder
                            @@path = File.join(@@dir, '/Folder/')
                            @@dlg = "test.html" ;
                            @@test_dlg = nil ;
                            def initialize()
                               @test_1_file =  File.join(@@path, @@dlg)
                               if @@test_dlg == nil
                                   @@test_dlg = UI;;WebDialog.new("Test", false, "Test", 300, 600, 70, 95, true) ;
                                  @@test_dlg.add_action_callback("push_frame") do |d,p|
                                     push_frame(d,p)
                               @@test_dlg.set_size(300, 600) ;
                               @@test_dlg.set_file(@test_1_file) ;
                               @@test_dlg.show() ;
                            end #def
                            def push_frame(dialog,data)
                                params = query_to_hash(data) ;  # parse state information
                                if params['test'].to_s == "true"  #Example of a  condition.
                                   change = false
                                   script = "top.test= " + change.to_s + ";"    #this sets test=true to test=false
                                   dialog.execute_script(script);   #this execute it
                            end #def
                            def unescape(string)
                            if string != nil
                            string = string.gsub(/\+/, ' ').gsub(/((?;%[0-9a-fA-F]{2})+)/n) do
                            [$1.delete('%')].pack('H*')
                            return string
                            end #def
                            def query_to_hash(query)
                            param_pairs = query.split('&')
                            param_hash = {}
                            for param in param_pairs
                            name, value = param.split('=')
                            name = unescape(name)
                            value = unescape(value)
                            param_hash[name] = value
                            return param_hash
                            end #def
                         end #class
                      end #module
                      Hope this helps and again very good plugin!
                      • Dan RathbunD
                        Dan Rathbun
                        Ruby uses 2 space indentation. HTML & Javascript 4 space indentation.
                        NOTHING uses 3 or odd number spaced indents !
                        I'm not here much anymore.
                        • Dan RathbunD
                          Dan Rathbun
                          See this other post: Re: Webdialog scripting issues
                          Use local vars INSIDE methods as temporary variables. They get garbage collected when the method ends.
                          Use @@vars INSIDE modules or for class-wide access.
                          Use @vars in class instance methods (define and init them inside the initialize method.)
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            Thanks a lot, I'll try that.
                              Only Python require a certain indentation - Ruby, HTML and JS doesn't care. It's just coding convention within the team/project you're working with.
                              • I
                                iannuzzi
                                Please, don't ever give up on this plugin, it'd save my life! I wish I could help
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  I won't give up ! 😄 I just don't have time curently. I will at the end of july.
                                  No worries
                                  • KrisidiousK
                                    Krisidious
                                    just posting so I'll get updates on this thread.
                                    By: Kristoff Rand
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      I made another thread to discuss the behaviour of the plugin : http://sketchucation.com/forums/viewtopic.php?f=323&t=52225
                                      Feel free to participate 😄
                                      • L
                                        Litchi
                                        Thanks for your present!This is a great plugin, but I have a problem,I created a layer group,which contains a number of layers,but when I restart the plugin Panel,everything was back to the way they were,the group disappeared, the new layer still exist。
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          Yep, it doesn't save anything yet ^^
                                          See the first post :
                                          ToDo :
                                          • **Saving ! For now, every time you refresh the webdialog, or exit SU, the sorting/nesting disappears.**So it's useless as is.
                                          It will come. Just not now 😄
                                          It's obviously at the top of my todo list.
                                            driven
                                            hi
                                            I just wondered if you had ever seen this, it has some nice ideas, to take forward
                                            404 Not Found
                                            (sketchucation.com)
                                            I did some work on the mac version, but Chris and Jim had already done the tricky bits...
                                            • 1 / 3
