    Saint Mary Star of the Sea - 3D Virtual Model by Skp members
    20 Posts 4 Posters 5.7k Views 4 Watching
    • KrisidiousK Offline
      Krisidious
      The autocad files looks as though this will go much more quickly than I had thought... Hard to resist imported autocad files in sketchup.
      By: Kristoff Rand
      • charly2008C Offline
        charly2008
        Hi facer,
        I imported the CAD drawing, cleaned up and made ​​faces. That should be the first step.
        Charly
        St Mary model_1303_21mar.skp
        • facerF Offline
          facer
          @charly2008 said:
          Hi facer,
          Charly
          Good to see you are "keen to go". Before anyone goes any further please wait until I
          tidy up the plan a little. Nothing too major but it will reflect the current layout.
          I am now in the process of:
          1. removing confessionals that are not in use
          2. updating the furniture layout
          3. adding the new glass entry wall
          4. setting out a logical grid for reference.
          When I complete the first two items above I will update the DropBox SketchUp plan
          and also post to the forum.
          Charly would it not be better to keep all the plans in one location as the Dropbox.
          I can see the advantage of posting to the forum as it gives a "window" into the process.
          I think your process is a good one as it enrolls and motivates SketchUcation members to get
          involved.
          I think it best in future that I first receive a copy of the plan or assembly first and
          then OK it for issue. This will ensure that everyone is "singing from the same page".
          Good work, thank you for your effort.
            TECHDAVE02
            Just too much fun!!!
            HAVING TO MUCH FUN
              Krisidious
              I'm also not religious but find the architecture of churches very interesting and enlightening... The older the better.
              By: Kristoff Rand
              • facerF Offline
                facer
                DROPBOX - being updated - empty at present
                Please note that the DropBox is presently empty. Files and data are being re-organized
                into a simpler and more rational format. This may take a few days.
                Regards,
                Ray
                • facerF Offline
                  facer
                  Sorry, I changed the title. Try this link:
                  DropBox is being updated - nothing there at present
                  Regards,
                  Ray
                  @krisidious said:
                  The drop box link isn't working for me... says "nothing is here".
                  • facerF Offline
                    facer
                    Dave,
                    Some of you are getting ahead the rest of us but I have to agree it is "fun" to see the building rise up. Like the great church builders of the middle ages found a good result takes time.
                    I have upload extensive photos of the South Elevation Gr Floor level which is my primary focus.
                    This is the elevation that will be the next phase of the stone restoration work.
                    Currently the church is raising funds for this stage and I am hoping to use the
                    SketchUp model to assist in this fund raising endeavor.
                    (note the estimate of $1500 - $2500 approx (Aust) per sq. metre for straight walling - expensive due to the detail of the work plus factors as scaffolding, hoists etc.)
                    FOLDER: St. Mary pics - Elevation South Gr Fl
                    These will be followed with the Top level photos of the windows.
                    I should clarify that I am receiving no commercial remuneration from this exercise.
                    I am not a Christian and have no direct relation with the church. My office is
                    5 minutes walking distance away. For the past 20 years I have "used" their church
                    as my private meditation hall. I pick the right times when it is almost empty and hence perfect for contemplation and I know of no other building as calm and refreshing.
                    They have an "enormous task" ahead of them so I thought I would give a little back.
                    If the SketchUp model can assist their efforts I will be satisfied.
                    I appreciate the assistance being offered by the SkethUcation community and I am interested to see where this "journey" will lead. I should also confess that I am a Canadian, not an Aussie.
                    Cheers,
                    Ray
                    • facerF Offline
                      facer
                      Regards,
                      Ray
                      To all,
                      Dropbox is now available. There are extensive pictures internal and external:
                      https://www.dropbox.com/sh/cqer0p46144ksi2/FrFViA_-z6
                      The church had full dwg drawings including sections undertaken in the past using
                      photogrammetrics. As soon as the full set of drawings have been received they will be updated
                      to the DropBox.
                      Note the dwg elevation drawings are accurate and have precedence over the
                      drawn plan. The plan was prepared independently of the photogrammetric process by the architects.
                      photogrammetrics by:
                      http://www.cassisiarchitects.com.au/
                      architects:
                      http://paularch.com.au/contact.html
                      Regards,
                      Ray
                      • facerF Offline
                        facer
                        DROPBOX - updated
                        All dwg drawings have now been received and are available at the Dropbox.
                        Refer to folders:
                        St Mary Plans 1_Elev_dwg .......St Mary Plans 2_Elev_Sect dwg
                        West elevation photos have also been uploaded to the Dropbox, this completes the
                        full interior and external photographic overview. Photos of church details will
                        be taken and uploaded as the model evolves.
                        For more information on the Photogrammetry used on this and other projects see:
                        Architectural examples undertaken:
                        http://www.angeli3d.com/exampl-1.html
                        Parliament House Melbourne
                        http://www.angeli3d.com/parliame.html
                        Thank you for your continuing support on this exercise.
                        Regards,
                        Ray
                          TECHDAVE02
                          To new elements using new " photogammetry " CAD Drawings.
                          Key map
                          East Buttress No1
                          • facerF Offline
                            facer
                            St. Mary update 20 June 2015
                            The external model of St. Mary Star of the Sea has been completed
                            by the dedication of David Asher of Windsor Ontario, Canada.
                            A SketchFab "entry Section" can be viewed at:
                            St Mary Star of the Sea_02 - 3D model by facer0001
                            model by David Asher - St Mary Star of the Sea_02 - 3D model by facer0001
                            Sketchfab (sketchfab.com)
                            The materials and white lines are not what we want but at present I am
                            not sure of how to improve of the original SketchUp model
                            We are currently working on preparing "audio clips" that can be integrated into
                            the St. Mary 3d Virtual Model shown in SketchFab. This has been aided by the
                            generous donation of a Nagra-Pico by Nagra.
                            Nagra PICO - Nagra
                            Nagra (www.nagraaudio.com)
                            Our marketing stragegy for generating donations for the Restoration works at St. Mary Star of the Sea are:
                              a. Complete a good 3d model on SketchFab that will lend itself to VR (virtual reality) cardboard viewers.
                              b. Have a liminted number of "audio clips" (eg. Entry doors, Stained glass on Entry Elevation,
                                  and North Elevation - the renovated elevations that have street views.)
                              c. Have some test "coffee chats" at Josies on Wednesday (good backroom) or in
                                  in the Crypt under St. Mary.  These sessions would demonstrate the use
                                  SketchUp on a laptop and SketchFab VR on an i-phone.
                              d. Once the "bugs" have been ironed out and delivery is "smooth"
                                 we hope to get local newspaper and radio spots to discuss the project.
                            Thank you everyone to date for your comments and suggestions.
                            • facerF Offline
                              facer
                              Sketchfab Model of
                              St_Mary_Star_of_the_Sea_01 "work in progress"
                              https://skfb.ly/QKBO
                              • facerF Offline
                                facer
                                Progress Update at 11 Aug 2017
                                St. Mary Star of the Sea Sketchfab
                                Front Entry, a cut away model - small scale, quicker to download
                                LINK:
                                musical track: Lord, Help Me to Tell Your Story http://www.internetevangelismday.com/music.php
                                Note: repeating track - sound can be turned off using music slide opened by clicking music symbol.
                                Full model - larger file, slower to download
                                LINK
                                Note: This model is on St. Mary Star of the Sea - Sketchfab website (free plan or version)
                                (note annotations limit 5 and 1 sound track mp3 re entry door - as an example - 5 MB max allowed)
                                Note: sound can be turned offusing music slide opened by clicking music symbol.
