    SImple plugin- care to help?
    20 Posts 6 Posters 872 Views 6 Watching
    • Subsonic MikeS Offline
      Subsonic Mike
      SDmitch, I am stitching faces together. I just want a plugin that means when a face is made, when a triangle is made, i dont have to click again to keep drawing the line
      Cotty, I have that box enable.
      I will post more when I get back from school, bye for now
      Micahel
      Design Crash Learn
      • BoxB Offline
        I agree it would be a handy feature to be able to turn on and off, so let me see if I can describe it.
        The normal action of the pencil tool is for a line to form behind the cursor even after clicks until such time as it forms a closed loop. The closing of the loop forms a face and the line drops from the pencil. So stitching between two lines means, click line one, click line two, click line one, face forms line drops off, click line one again to start next loop, click line two, face forms line drops...............
        Better would be if able to ignore the natural drop at the form loop stage so that stitching becomes.
        Click line one, click line two, click line one, face forms, click line two, face forms, click line one, face forms.........
        Tig's 2D tools does it, but obviously not in 3D. Also tools on surface, but it needs a surface to start with and that kinda defeats the purpose.
        • cottyC Offline
          cotty
          @cotty said:
          Ok, my suggestion stops working after a face is created. Workaround:
          • group the faces
          • make lines (without faces)
          • explode faces groups
          • plugin makefaces to add missing faces
          A screencast for these steps...
          my SketchUp gallery
          • sdmitchS Offline
            sdmitch
            Mike, I sent you, via PM, a plugin to try. I think it will do what you want.
            http://sdmitch.blogspot.com/
              Is there a reason why you wouldn't just use one of the plugins to automate stitching the curves together. If your time is that valuable, I'm sure you could save more time using Curviloft or one of the other tools to do what you want to do manually.
                Subsonic Mike
                The reason I wanted a plugin like this is because the loft tool sometimes fails to stich two faces and so I have to go manual
                Design Crash Learn
                  Is it possible that the times it fails it's because of the way you've got things set up? Maybe a simple change to the way you're drawing would allow the plugin to work and then you're all set.
                    Subsonic Mike
                    Im not sure, I just have 2 quite different curves and it connects the top to the bottom, it doesn't bother me to much
                    Design Crash Learn
                      Perhaps if you posted a sample SKP file in which you have trouble getting Loft to work, the problem could be sorted out so you could avoid having the problem at all.
                        Subsonic Mike
                        Na, it works well enough and I have what I came for so I don't really want to continue discussing my lofting technique. It works well enough, for now πŸ˜›
                        Thanks all
                        Michael
                        Design Crash Learn
